Hi all,
My robot is now generally running well, and does just about everything i ask. But there is one thing that is a minor issue that i am sure has been fixed before by one of you. I have two cheap chinese speed controllers which i have set up to use a tank steer method. This is generally fine. The only issue is on my skyfly transmitter when i move my left stick from forward to reverse. If i do not "pause" in the middle, it will not go in to reverse. Swapping sides speed controlles sides and the fault of the reoccurs on the new prevoiusly fine side. So i assume it is a built in "feature" for planes or similar. Does his anyone know how to remove this? I assume a setting somewhere but which one?
Thanks in advance.
Thanks in advance.
