And you would have to prove that none of those fibres was over the length limit
Inspiration/innovation in weaponry
Oh crap... in dubio pro reo? judges would have to prove one WAS longer?^^
Anyway... not planning to use it and hoping nobody else does, but interesting thing to think about.
So, throwing in another idea that will most likely never see the arena: If there is no limit to the "strings", a curtain of pendulum-like things could also work, but by taking energy from a spinner and just swinging instead of getting destroyed. like a net or things like that are used to catch arrows, they move along a little way with them, absorbing the energy. but making such a curtain-like armor that doesn't just get shredded (or could count as chainmail) is another thing... most systems like that rely on being way heavier than the projectile or whatever they try to absorb energy from. that'll be a problem for us.
Not anymore! Some still do and some drivers like to be cautious on the acceleration ramp, but PP3D can get up to highly damaging speeds in about 3 seconds, Carbide probably similar if not quicker.Originally posted by team death View PostIspinners tend to take an age to speed up, its the nature of getting that heavy weight disc
to maximum revs
seeing that chainsaw covered in fibres reminds me of what to do if confronted by leatherface from the chain saw
massacre movie-make sure you're wearing a heavy wool jumper a Wooly hat and wool long johns-multiple layers
if you have time
No but seriously......
Musing about walking robots and the lack of them in competitions.
I have an idea that you could use overhead camshafts from an engine to push down on
cam followers and maybe little rubber feet-this would be classed as a walker because the drive is linear rather
than rotary or tracked, there would be a puzzle about reversing the motion but forward left
and right are easy enough and if the rule is as before that your'e allowed 200kg -thats a lot
of weight to play with for weapons and armour ect - the patter of all those tiny feet on the
arena floor would be amazing, I won't have time to build it myself but its a free idea for someone
That mechanism, if I have interpreted it correctly, would be a shuffler not a walker.
Under the new season 3 rules that would gain you a 15kg bonus bring the maximum weight to 125Kg
True walkers have a 35kg Bonus? (double check that) so they can weigh up to 145kg under the new rules.
As for entanglement, you are not allowed chainsaw fabrics or similar. Chain, cable or rope are basically the only things permitted and up to 1m in length maximum per continuous strand.
It was in the lightweight division, check this vid out https://www.youtube.com/watch?v=qPBebQIzkXc
walkers, robots with internal combustion engines, whats not to like !
