Hi guys,
I'm in the 'testing' phase at the moment with my feather. So far I have a sheet of plywood with some drill motors mounted to it, some wheels, 2x hacked TZ85s, a LemonRX and a 12v lifepo. Transmitter is a DX6i.
So far, so ordinary. I've mixed the channels on the DX6i so that with one stick the 'robot' goes forward, back, left and right as it should.
Problem is - at low throttle, one motor moves slower than the other. I wondered if the ESC isn't reading the full range of the stick input, so I looked up how to get into the programming mode or initial setup of the ESC.
Can I get into programming mode? Can I buggery! I should add at this point that the TZ85s came 'pre-hacked' by a member of this parish, and I'm reading the instruction manual from when they were brushless controllers, so I don't even know if the method of getting into programming mode is correct.
Can anyone point me in the right direction? Thanks
