Help With Wheel Attachment
  • Help With Wheel Attachment
    Hey, I need a bit of help to decide whether I got the wrong stuff for my wheels or if I'm just being dumb.
    I bought some Colson wheels with a 1/2" Hex Bore on them, and some 1/2" nuts from Gimson Robotics a while ago and got around to trying to fit them into each other but ran into a problem.
    The nuts themselves are slightly too big for the holes and trying to press the nut into the hole just bent the edges instead of going in.
    The wheels were a pain to get, meaning I'm pretty cautious around them, so I stopped when I saw I was just bending the edges.
    Am I being too cautious with the wheels and should I just keep pushing the nut in, or should I get on the hunt for different nuts? (If the latter, what's a good place to get the nuts?)
    How about filing the sides of the nuts down slightly until they are a tight fit?
      Put the nuts in the freezer overnight, and heat up the wheels in hot water. Maybe that helps.
        Use a caliper to measure both and record the difference in diameter on here.
          Originally posted by typhoon_driver View Post
          Use a caliper to measure both and rrecord thee difference in diameter on here.
          From face to face it's 0.496 inches on the wheel amd 0.560 inches on the nut.
            That's a large difference, no way they are pressing together without something breaking! I still think the option is to reduce the size of the nuts until they fit. Do you want them to be a permanent press fit or do you need them to slide out again?
              The .496 is normal for a plastic 1/2" hex.
              But .560" (14.2mm) isn't even close to 12.7.
              On the other hand, 0.560" is the standard hex size for a normal, commercial 3/8 UNF nut.
              You need something custom made then. A possible solution is to drill out a 5/16" nut with 9.5mm and rethreading it with 3/8unf.
              Oh, I have a few of those already....
                Take a file to the nut and with a bit of patience it would be a snug fit.
