Originally posted by Max
									View Post
		Good point Nick, hadn't spotted that... Just stick a TZ85 on each pole then and job's a goodun :P (Kidding.. though could be an interesting experiment as to what a TZ can do :L)
 . Based on the thermal resistance from the junction to the case and from the case to a heatsink and calculating the RDS at a realistic 40 deg. C ambient temperature, the sheet shows the current handling without a heatsink and the thermal resistance of the heatsink needed at various current ratings. I have modelled several other common FETs in the sheet and it has proven to be quite accurate. I had to guess the thermal resistance from the junction to air, so the power handling could be higher.
