Top shop online & links
  • Top shop online & links
    I understand if this has already been asked but where would I get removable links?
    I couldn't find any on www.technobots.co.uk, are there links or online store I should go to?
    i know robo challenge do for featherweights but I'm looking for heavyweight robots.
    Have a look at Anderson connectors like these:http://www.torberry.co.uk/superbaske...120+CONNECTORS. They come in a variety of current ratings and you can hack out the plastic shell to fit a fuse inside, which saves space and wiring complexity.
      Team RCC uses Hobbyking sourced EC 3 or 5 connectors as a removable link.(and about any connections in the wirelooms of our machines)
      Andersons gave us to many self removing links.
        Try these
        http://www.technobotsonline.com/conn...onnectors.html
          Could someone show me a link on tiny speed controllers for antweight on this forum as I can't find it. Thanks.
            Plug: https://docs.google.com/document/d/1...it?usp=sharing
              Thanks for the link Rory. I wanted to ask you Rory I've had a look on the link as research & wanted your advice on which out of N2LV, N2LVHP or N2HV nano speed controllers is ideal for the micro motors that got from BotBitz. The motors are BotBitz GM12 50:1 HV (BB-GM 12-50 HV) 5.0volts.
                N2LV is the best to use for your robot.
                  Ok cheers
