victor speed controller help
  • victor speed controller help
    Ive got a pair of victors driving a motor each, ones fine plugged into the reciever but the other one sends everthing plugged into the reviever into a spaz attack if i plug it in, ive got a spare victor somewhere i may have to end up trying but just wondered if anyone had any ideas?
    Calum
    What happens if the problem Victor is plugged in to the receiver by itself? Also, what is supplying the receiver's power? Victors need more current to drive them than other ESCs, so it could be that the receiver can drive one Victor but not two. Have you tried changing the R/C cable? I' try swapping the cables between the Victors and see if the problem follows the cable.
      Swapped the victor for a spare and its ok now, not sure whats up with it as it was fine last time i used it!
        Take the case off and blast out any conductive crud on the circuit board. the Victors are pretty well sealed against dirt, but it can still cause random issues.
          Yeah i shall give it a blast out and try it again
