Need to buy a couple of recievers, got a few AR500s which ive never had a problem with but seems they arent made anymore.. just wondered what other people with a dx6i used so i no itd definatly work with mine.
Cheers
The r620 will failsafe to user preset settings. Trick is to power up the Rx with the bind plug in then remove the plug to reduce the flashing from really fast to medium. You then bind the Tx as usually with everything as you'd like it to failsafe.
This is correct, I have 2 R620's on my DX6i and it works as described.
