As my first antweight robot Pump 'N' Milla, will have 0.8mm aluminium armour.
My second antweight robot Little Lucy Luxury will have 0.8mm aluminium & polycarbonate (0.6mm or 0.4mm thick) to deflect spinners, should I build a plastic chassis for the aluminium & polycarbonate armour to be bolted on or should I just build the aluminium armour & cover it with polycarbonate cover?
My third antweight robot is going to be called C Through Wacky, which is a simple round invertible robot made out of polycarbonate. How do you bend polycarbonate with shattering?
I've add these pic to show you the materials that I got for all 3 antweight robots of mine.
just to confurem - Pump 'N' Milla's armour will be 0.8mm aluminium only
- Little Lucy Luxury's armour will be 0.8mm aluminium & polycarbonate (not sure what thickness would be right)
- C Through Wacky's armour will be just polycarbonate
