I have converted k9 to 4wd, will a sabertooth dual 10a run 4 drills on 2 12v sla 7 amp, I have run 2 fine.
Also I am adding a second speed controller for k9's head movement, it's a 12v that I have lying around, will I need to cut a wire for the bec, as the sabertooth power the reciever, if so what colour wire is the bec?
Thanks for any help
Thanks for any help
