Anyone give me any advice on how too revive some 3am 24v nicad packs? Their fairly old but are still holding some volts, yet I don't know how to treat them, good hard cycle or a low amp slow one?
How to revive nicad's
Re: How to revive nicad's
You need to cycle them at around 4amp charge ish it don't matter too much, you propably have a few cells gone so you will have to test to find them 1st and replace them as cycling won't work with damaged cells in the pack.
I got so pissed off doing this so I changed to a123s as the charger automaticly balances.
So take off all the heat shrink and test all the cells, if they read 1.2v then their fine, or could I get away with testing the whole pack and buying enough cells to replace them all, then find the old cells?
I've got all the chargers for Nicads so would like to try and use them, won't be cheap but probably still cheaper then buying A123 chargers and batteries
no dont take heat sink off just yet
measure voltage ie 24v
if 24v then charge fully then discharge 3 times or run the bot down street till dead then charge
normally a good charger can cycle theses
if u dont have say 24v then yes have to strip
http://www.ebay.co.uk/itm/10pcs-New-Ori ... 211wt_1114
you'll want atleast 3 packs of 8 cells so you're looking around £130 for batteries plus another £100 for a cellpro 10s charger.
So 24 cells would make me up 6 12v packs as each cell is 3.3v? The old set up was 3 12v nicad packs all into 3 different plugs, so I could make up enough to have a full set of spares put of 24 cells?
Or better to make a 2 24v packs? Can run 24v worth of hawkers on a single lead out of the 3 but still trying to get my head around the wiring and how many packs I could/would have too use and at what voltages
May have to re-do the wiring slightly then to adapt for the new packs
anyone know of any good chargers that are not £100 each, bit steep for £420 in total for a conversion so want too bring that cost down a bit really
How viable would it be to use 8.4v nimh packs of the same 3000mah? would need 3 packs of 3 so 9 packs in total, but comes out at under £200?
http://www.wheelspinmodels.co.uk/i/70479/
Just exploring different ideas here, dont want to run SLA's forever
