Technically yes, as they don't require tools to undo them. But there is always a possibility that the nut/bit of bolt sticking out gets hit and/or bent during a battle which could jam up the thread and make it extremely difficult to undo. Having said that, I suppose the majority of access-closing methods could get damaged to such an extent in battle...
That's easy enough too do, once the change over is done (should be next couple of weeks) and I've changed the cover, that will take about 20 mins work Theb it's all done
Though im still adding some red led's under the flipper
