ok.. time for me to ask a quetion;
got a magnet in 540 for traction in steel arenas...
used to drive ok with the magnet in and the dewalts for drive (apart from the fire)...
basically when i put the robot down on a sheet of hardox, i loose drive totaly to one side... but the other is fine... lift the robot up, drop it on carpet and both drive trains run fine...
the LED's on the sidewinder that indicate the direction etc of the motors arent even lighting up on the one side when its stuck to some hardox.... but again works perfectly when its driving over wood/carpet/slabs etc...
possible issue with the sidewinder on the one side?
