I think the way RR were doing it was running them at very reduced power, I remember someone saying the disc was running at 7% (could be wrong on that though) on a bot that was part of them demo. Your idea would be something that the EO's themselves decided on I think.
You need to have an arena of the correct grade before spinning discs can take part. Grade 1 arenas are heavy and difficult to transport, setup and run hence why no one runs them atm.
The rules for the grades are in the safety section of the FRA site.
it's a shame in some respects, but i very much doubt there will be a spinner proof hw arena anytime soon. with the new advances in spinner technology the arena would have to be far stronger than the rw arena. so thicker polycarb, metal floor, solid roof. which means the arena costs more, is bigger, and alot heavier. i believe there was a subject about roaming robots possibly bringing back spinners in 2011 but extremely reduced although this was decided against due to the extra cost of more vans to transport the arena around the country. in a way i am glad spinners aren't aloowed currently as this would make england heavyweight competitions alot like american ones, either a heavily armoured highpower box wins or a spinner powerful enough to get rid of the boxes.
i do hope spinners are brought back even at a reduced rate (ie max 500 watt motor, 15kg max weight of disk, max 1000rpm) , after watching supernova on robot wars the other day i've had an urge to strap a huge flywheel powered by a drill motor to an electric wheelchair!
won't happen anytime soon. Plus there's no drive in the heavyweights to have destruction. Last heavyweight comp I was at there was negative feelings shall we say when there was actual destruction between machines.
Featherweight competitions have a completely different mentality that you need to be able to run spinners
i do see what you mean
at the featherweight fights, everyone seems to really enjoy seeing the bots they have build get damaged, then you get the fun or running it in the arena with duck tape holding them together
