Hi guys
I wanted to try a little electronics and mechanical test thats become quite popular on the internet, a useless little device known as a 'Leave me Alone' box:
http://www.leavemealonebox.com/
The thing is, I don't have a chip programmer, nor any experience in writing codes and such, but I have heard you can make a purely mechanical and electrical one, but I wanted to run the theory pass you guys.
I was planning to have the switch on the outside(operated by whoever) turning on the motor that controls the arm, arm comes up and flicks the switch to reverse the voltage going to the motor (the voltage from the battery wired in a X across the 4 poles), and when the arm goes down it hits a microswitch to turn the power off to the motor, and so it should remain stationary until the external switch puts the power back the other way to bring the arm out again.
So what do you think ?
