Okay... I have an idea in mind and want to know if it would count as a walker (and thereby be eligible for the 100% weight bonus).
Essentially, it's a vertical spinner with the disc support structure mounted on a vertical axle, enabling the disc to be angled to the left or right. A couple of cables connected between the disc supports and a motor acting as a servo would enable the disc angle to be changed. The effect would be, by changing the angle of the axis of rotation of the spinning disc, to lift swing each end of the robot forward alternately - therefore causing it to walk via gyroscopic precession. A movable foot on each end containing magnets (actuated by a large servo lifting it up and down) would allow an additional input for regulating the degree by which each end of the robot lifts up, in addition to providing extra traction when necessary.
(Okay, using movable magnetic feet rather than electromagnets is rule shaving, I'll grant - as electromagnets wouldn't satisfy the weight supported by movable feet part).
Basically, what I'm asking is this - would having the weight of the robot supported by movable feet count even though they're not actually causing the robot to move count?
