Help with a charger
  • Help with a charger
    Hi all
    Just wondering if anyone can help me, I ahve this charger=
    http://www.ripmax.com/item.asp?itemid=O ... gory=O0150
    it is able to charge li-pos but i can't work out what extra parts i will need for balancing and all the safty stuff. I would use it to chrage my heli batteries. seeing as it is able to charge lipos i don't want to buy another sepeartae chrager for more money
    any help?????
    Thanks Alex
    Re: Help with a charger
    On that link you gave it states that you will need the EQ+6 balancing package to be able to balance the cells with that charger. There are other very slightly cheaper ways to use things like the Astro blinky, but to be honest their system looks pretty reasonable.
    http://www.ripmax.com/item.asp?itemid=O ... gory=O0168
    Theres the link for it. It will plug into the charger and your batteries and most likely balance during charging and wil display the voltage of each cell on the charger screen.
      I'd agree with grant, if you already have that charger then get that balaning pack.
        ok thanks i have bought that setup
        can i check with someone in the know that, that balancer and charger can do thise lipo?
        http://www.hobbycity.com/hobbycity/stor ... _3S1P_25C_
        cheers
          Yes it will. I use the same in my helicopter and similar charger and balancer.
