Weight of hardox
  • Weight of hardox
    can someone tell me the density of hardox? so i can work the weight out for a certain size
    thanks
    Weight of hardox
    Pretty much the same as other steels, just under 8Kg for a 1mm thick metre square.
      Weight of hardox
      7850kg/m^3
        Weight of hardox
        thanks for that,
        i have been told that hardox 450 is only avaiable in 3.2mm+, does this mean there are other grades etc that go lower (thickness wise)
        thanks alex
          Weight of hardox
          Nope, 3.2mm is the thinnest SSAB makes Hardox.
            Weight of hardox
            hardox 400 is available in 3.2mm however this is somewhat of a special thickness and is generally worth 2 to 3 times more than 4mm hardox 400.
