Hydrogen Generator
  • Hydrogen Generator
    Hi Ive just fitted a hydrogen generator to my old van, I mentioned this to Trevor and Shane whilst drinking before Sundays Championships.
    The unit generates HHO quite well, I have been told you can reduce current demand for this type of unit with a power supply that pulses @ 20Khz I think the speed controllers used in the robot scene might do this job I have a couple of 4QD speed controllers could these be used to power my generator what do you think?
    Hydrogen Generator
    Be interesed to hear how you get on with this, been looking at these on the Net, several different ways of doing it, which have you gone for.
    DaveMac
      Hydrogen Generator
      DIY
      I have made it from a bit of drainpipe with screw cap ends the anode and cathode are 4 pairs of SS plates 75mm*200mm approximately, kept apart with foam tape and all held together with cable ties!
      I get about half litre per minuet HHO and draw about 16 amps!
      This is why I would like the power supply, this is the tricky bit I can get a 30 amp unit off ebay but I would like to have a unit that varies the frequency of the modulation the trick is to harmonise this with the unit or so I have been led to believe.
        Hydrogen Generator
        I would suggest that you do not spend any further money on this...
        If one could use a combustion engine to generate electricity to generate hydrogen from water and then use the hydrogen to power the engine, then the worlds energy needs would have been solved a long time ago.
          Hydrogen Generator
          im having a blond moment, can u explain what the point is ?
          John
            Hydrogen Generator
            I believe the idea is supposed to be to increase combustion efficiency because of the wide flammability limits of hydrogen. I suspect youd need a heck of a lot of hydrogen to affect efficiency noticably and bearing in mind its being generated probably at 15% overall efficiency, youre likely better off just making sure your tyres are at the correct pressure.
              Hydrogen Generator
              Tsk, next thing you are telling me you dont believe in over-unity machines either.
                Hydrogen Generator
                I have to say in respect to Johns comments that he is probably right.
                That said, I do recall reading about the guy who invented the decompression chamber giving his wife the bends and almost killing her a number of times and the bloke who discovered the effects of amonia on the eyes becoming blind because he stuck a bit too much in his own eyes. The way to find out what works is by trying it.
                You carry on with it if you want. You can stick some nice solar panels on the top of the van and run it from a set of batteries charged by the sun, little wind turbine on the top of the van the charge batteries as you move along basically look at where you can scavenge energy from, regenrative braking? etc etc.
                I do have to say though that aside form Johns comments, hydrogen is explosive and if youre not careful the headline Bloke in crap van blows himself up! may be appearing in your local paper some time soon
                Andy
                (Message edited by widow_twanky on July 21, 200
                  Hydrogen Generator
                  leave the van out of it,its class
                    Hydrogen Generator
                    Thanks for the comments guys,
                    John I can see your point I would say from what I read the point is to assist in the burning of the petrol the van uses. A point made by Nick.
                    Jonno the point is I just like this kind of thing,
                    Leo I do believe in overunity even though it seems impossible at the moment.
                    Andy the amount of gas stored at anyone time is very small as it€™s used as soon as it€™s produced but thanks for your concern for my safety.
                    I just wanted to find a power supply that uses PWM and I can adjust the frequency of the pulse as this is supposed to make the thing more efficient.
                    Look the subject up on utube there is some interesting stuff to see.
                    Oh and they have taken the word gullible out of the dictionary .................................................. ...look it up.
                      Hydrogen Generator
                      Over unity might work if those pesky laws of thermodynamics wouldnt get in the way.
                        Hydrogen Generator
                        yeah but do you think i should run my 4x4 on cooking oil ?
                        currently doing about 1200 miles a week. average about 40,000 a year at the moment.
                          Hydrogen Generator
                          Not unless you filter it and mix it with petrol. Also I think you can end up getting fined the same way you can for using red diesel.
                          Andy
                            Hydrogen Generator
                            Companies all over the world are spending millions looking to improve the improve the efficiency of internal combustion engines by just a few percent. And yet not one car manufacturer has fitted a hydrogen generator... must be a conspiracy! Only possible explanation.
                            I just hope Andy was joking when he suggested putting a windmill on top of your car...
                              Hydrogen Generator
                              Windmill? I said wind turbine, big difference. I was not talking about renting it out to Windy Miller to offset the fuel costs!!
                              Mind you the way things are going maybe thatd be a good idea.
                              One thing that concerns me about hydrogen generation is that it seems to work in the same way as easy start. Basically it enriches the fuel and make it burn in a different way. With easy start this burns out parts of the carb and the car essentially gets addicted.
                              Andy
