CAD packages
  • CAD packages
    Hi
    AS im currently designing my new feather weight which will incorparate lots of tricky building. I thought it a good point to try my hand at some CAD something simple that i can design armour and mounts in. Alsoo that is either on the net or free download would be great
    any ideas?
    thanks alex
    CAD packages
    Rhino 3D
    its a free trial, i use it and love it
      CAD packages
      Yep, I would highly recommend Rhino3D as well.
        CAD packages
        do you have a suitable link?
          CAD packages
          Google is your friend.
          http://www.rhino3d.com/http://www.rhino3d.com/
            CAD packages
            i now have rhinoceros 3.0 evaluation just trying to work it out
            could someone give me a few pointers on how they use it for robots? i have looked for tutorials but they seem to be a bit to specific about certain things
            any help welcome
              CAD packages
              also just saved a bit of work nd i seem to have a limit of 25 saves??????
                CAD packages
                Renders are the things that show you your robot. To have your robot show up in your renders, you have to make surfaces. These surfaces are usually the exterior of your robot unless you want to try and render the inside as well.
                You can make surfaces quite easily. Surface Point will create a surface out of any 4 points you specify. Surface Edge creates a surface out of 4 connecting curves. There are tons of other neat functions. Its really quite fun, try it.
                And yeah, trial versions have 25 limited saves. When you get the full version, unlimited saves.
                  CAD packages
                  Rhino is a NURBS modeller though, so its a little different to most pacakges. I use 3DS MAX 8 from Autodesk.
                  For a good wide use I would use http://www.blender.orgwww.blender.org as a package, Blender is free, open source and is easy to box model with.
                  If you want epic simple, http://www.anim8or.comwww.anim8or.com is your place.
                  Otherwise
                  http://www.wings3d.com/http://www.wings3d.com/
                  http://sketchup.google.com/http://sketchup.google.com/ + http://www.kerkythea.net/joomla/http://www.kerkythea.net/joomla/ (use the two in conjunction)
                  Im no proffessional and Im 16 so Im no good to instruct you with anything. But feel free to use my robot model as a guide if you feel it helps, I used a box modelling technique.
                  http://www.ewe-squad.com/plei/Misc/Collage%201.jpghttp://www.ewe-squad.com/plei/Misc/Collage%201.jpg
                  If you want to go into it further I can show you some wireframes from this model, or give you the model to import to have a gander at.
                  Each of the packages has different benefits and downfalls, if you want simple, then Anim8or is best + it has an internal rendering system, though its not very advanaced.
                  Wings 3d is an opensource 3d program that is subdvision based (creating vertexes and then smoothing them all over)
                  Rhino, what you have is a different type. It uses Non Uniform Rational B splines to model with. Often this is good for organic modelling, but not as good for box modelling, which is better for a robot imo. The difference is youll notice is that most models use a series of verteces to define a point on a surface, NURBS is different in that it uses splines to define the average forsurfaces and lines.
                  http://en.wikipedia.org/wiki/Image:NURBstatic.svghttp://en.wikipedia.org/wiki/Image:NURBstatic.svg
                  Notice how the green points have an average that determins the final curve for the spline line.
                  http://www.oman3d.com/tutorials/3ds/mosque/001_top_vertices2.gifhttp://www.oman3d.com/tutorials/3ds/..._vertices2.gif
                  Above are standard vertices for shapes. The little squares are EXACTLY what are in the model, and so they are easy to extrude, bevel and move about unlike NURBS.
                  Personally I reccommend using a VERTEX based modeller for robotics becuase they are better and easier to box model.
                  But either way I suggest to test some of the ones I gave you to see what is right for you.
                  For more information:
                  Lists a load of modelling programs to use, free and buyable.
                  http://en.wikipedia.org/wiki/3D_computer_graphics_softwarehttp://en.wikipedia.org/wiki/3D_comp...phics_software
                  Will give you a bit of information about the two types of modelling and will give you core links.
                  http://en.wikipedia.org/wiki/3-D_modelinghttp://en.wikipedia.org/wiki/3-D_modeling
                  Hope I could help some!
                  (Sorry if I sound patronising, I dont quite know how to word things properly, I see you have a large post count so I apolagize if I seemed to talk down at all)
                  David
                  (Message edited by david b on May 29, 200
                    CAD packages
                    (if that was partly directed at me...)
                    Its okay. I realize some people turn their noses up at some programs, so I dont bother to win people over, I just give suggestions.
                      CAD packages
                      Oh no, Rhino is fine, I use an extension on 3DS MAX called PWR Nurbs, which is exellent and has a NURBS as its base. In my experience I just thought box modelling was much easier than sub d modelling or NURBS.
                      No intention to insult you, my apolagies.
                      My post was aimed more at the topic starter
                        CAD packages
                        Ah, no harm done, good sir.
                          CAD packages
                          CAD is differnt then Computer Modelling. We make real things with CAD. Im a mechanical draughtsman and I dont like people using the wrong programs.
                          Find someone wholl lend you a copy of Autodesk Inventor or SolidWorks. Much quicker and easier then Rhino. The version of Inventor Im currently using has dynamic modelling and FEA which have come in rather handy and Im sure SolidWork will have the same as they both copy each other. With these programs you dont ever have to worry about NURBS or that sort of junk. You build the parts and assemble them together, not draw lines and calculate surfaces so they look right.
                            CAD packages
                            Thanks Daniel no the info was very helpful ill try those other downloads as they sound a bit easier to start with
                            thanks alex
                              CAD packages
                              Just gone onto the blender site i have got to this page
                              http://www.blender.org/download/get-blender/http://www.blender.org/download/get-blender/
                              do i need both downloads or just the left hand one?
                              (i use windows XP)
                              Thanks
