Some Questions...
    Some Questions...
    Adrian, i dont think we do, it saysDX6000 on the reciever.
    Woody, what could we do other than buying a failsafe?
    sorry it took me so long to get back
      Some Questions...
      Youve given an odd designation for the receiver ..
      You should have one of these in the bot.
      http://www.moormodels.co.uk/acatalog/info_SPM6000BR.htmlhttp://www.moormodels.co.uk/acatalog...SPM6000BR.html
      Solution ...assuming you havent got the correct receiver ... buy one.
        Some Questions...
        An alternative is perhaps to go the route Terry miles took in the Futaba 6ex FASST thread.
        http://www.fightingrobots.co.uk/discus/messages/59/11311.html?1208250376http://www.fightingrobots.co.uk/disc...tml?1208250376
          Some Questions...
          Im starting this thread off again because weve got some falisafes now.
          Weve still got the wotty and specturm but when the failsafes are plugged in they have no effect. if we use the Technobots tx and rx it works. does this mean we cant use spectrum with the failsafes?
          thankc
            Some Questions...
            Failsafes will not work with a Specktrum receiver ...it always outputs a valid signal.
            As Woody said you wont get any known failsafes to work with a spektrum. My suggestion is get BR6000 Rx from the coopers, i believe they are about to do an order. Or the Futaba system, seems to work ok although Ive never played about with it.
              Some Questions...
              cheers ed, wouild the tx weve got oon the profile work with that?
                Some Questions...
                yes the BR6000 Rx will work with the Spektrum tx
                (Message edited by tom kane on June 24, 200
                • #23
                  Some Questions...
                  thanks guys,
                  • #24
                    Some Questions...
                    sorry about this, is thqat James Cooper or Paul Cooper?
                    • #25
                      Some Questions...
                      james or grant cooper from robochallenge
                      • #26
                        Some Questions...
                        thanks john, well get there in the end :-)
