Dual rate is that I effectively have 2 speeds, based on % of the stick.
So with the switch on 0 I have for instance 50%, and on 1 100%. I then normaly drive on 50% making it easier to manouvre and aim, but when I then need to push or need more speed, I can switch up to 100%.
Sometimes on very slippery arena floors (GRA) Ive even driven on 30% just so I could aim.
Hi kenny, your problem sounds similar to what i had. is yours new? my dip settings are 1 down the rest up, which gives me mixing on both motors. (spektrum mixing is off)
basically mine would work fine for 30 seconds or less and seemed to happen when i was trying to drive it fast and switching direction quickly e.g forwards backwards etc....then the red error light would come on. or sometimes the blue power light would just go off and it was dead, it would also sometimes just go mad on its own 1 motor would go flat out or sometimes both, then it wouldnt respond to the controllers. as soon as i removed the link and plugged it in again, it would work fine and then do the same thing all over. mine i had just brought new and unfortunately was faulty (after dimension got me to do some tests over the phone) and i had to order another one. Technobots sent me 2 as the first went missing and still is, if it arrived before the event on friday then i can let you know. sorry cant be anymore help but if your problems are the same as mine then perhaps its a faulty batch?
also not sure if many people use these controllers and if they have any advice or how they have found this speedo for reliability.
charging batts fully up, in the manual it says if the batterys are flat it can trip out, becuase it cant supply the current needed, will try if still not working will after send it back and get another
