Spektrum dx6 setup
This topic is closed.
    Spektrum dx6 setup
    Hmmm ...been a while since Ive done this Ady.
    Try simply swapping over your receiver connections first...... Swap over Ele and Rud plugs.
    (Message edited by woody on July 19, 2007)
      Spektrum dx6 setup
      Then if that doesnt work ......put it back as it was ......then swap over the output of the electronize controllers... the wires that supply the motors.
      Take the R.H. output and swap over to the L.H. side and Visa Versa
        Spektrum dx6 setup
        ok, will have a go again in the morning, thanks for you help, i love these last minute glitches.
          Spektrum dx6 setup
          Its a common problem .......I just cant remember the fix without having the bot in front of me and fiddling.
            Spektrum dx6 setup
            Hey your lucky. I just had 2 fires in 2 robots, both scheduled to turn up Saturday.
              Spektrum dx6 setup
              Bum!
                Spektrum dx6 setup
                sorted straight away, it was just a case of swapping the rud and ele over in the reciever, as you said. thanks
                • #23
                  Spektrum dx6 setup
                  • #24
                    Spektrum dx6 setup
                    does anyone know, is it ok to use a Br 6ch channel reciever in a DX7 transmitter?
                    • #25
                      Spektrum dx6 setup
                      Quote ......
                      Q: Will the DX7 work with AR6000 receivers that are included with the DX6?
                      A: Yes. The AR6000 receiver included with the DX6 works perfectly with the DX7 transmitter. The AR6000 receiver is designed for parkflyer and Mini helicopter use only and, even when used with the DX7 transmitter, the AR6000 must only be used in parkflyer type of aircraft. The Model Match feature functions perfectly when using the AR6000 with the DX7 transmitter.
                      Which indicates that it will be compatible with the BR6000
                      • #26
                        Spektrum dx6 setup
                        I think i remember reading somewhere that you can (maybe the Spektrum website specs on DX???) but i wouldnt take my word for it.
                        • #27
                          Spektrum dx6 setup
                          yes you can. the DX7 is backwards compatible with the dsm(1) technology like the BR6000 and will work great. The DX6 is not dsm2 compatible, so receivers like the ar7000 or ar6100 will not work on a DX6.
                          • #28
                            Spektrum dx6 setup
                            thanks for that, i have a few BR6000 recievers, and just ordered another spectrum. decided to get a dx7 this time.
