my robot require 2 safty links becasue it uses diffrent powersources for the weapon and drive will this be allowed,reading the rules its my understanding aslong as there next to each other and easy to remove it should be ok?
Links
Links
Yeah should be fine - what you could even do (if using a removable link like what is available from Gimson Robotics for example) is to bolt the two individual links together so you effectively only have to put in/take out one link. You can obviously still use the two to make safe your two different power systems but having them together as one link may make things easier. Im planning on doing this in my next feather (will prevent me from doing anything stupid like losing one of the link ends in the pits
