hi people, nite b4 event and the hw is playing up! running 4qd speedos. basically when i press backwards on controller, one motor goes backwards the other goes forwards. both motors work off one stick, forwards works fine on both. any ideas? thanks guys
Urgent help anyone, event tomorrow!!
i have also noticed, when you pressed left or right one motor is supposed to go forwards, the other back , but they are both going forwards. the fault seems to be on one motor, it just goes forward fine but when it is supposed to reverse it goes forward
it might be the mixing on your tx. mabee inputs on rx. just guessing tho. a swap here and there on the rx might do the trick. or if its a programmable tx it might need programming. i could of course be totally wrong.
Id agree with Leo ....check the relays on the duff board.
http://www.4qd.co.uk/serv/nccfaults.html#onedirhttp://www.4qd.co.uk/serv/nccfaults.html#onedir
Also check the relay operating voltage.
The voltage is marked on the relays. Make sure these are correct as 24v relays will not operate from 12v and 12v relays will soon burn out their coils if used on 24v.
36 and 48v versions use the 24v relays but with a resistor in series with the relay coils and other components changed as appropriate.
http://www.4qd.co.uk/serv/nccv.html#coilvhttp://www.4qd.co.uk/serv/nccv.html#coilv
(Message edited by woody on April 27, 2007)
http://www.4qd.co.uk/serv/nccfaults.html#rnehttp://www.4qd.co.uk/serv/nccfaults.html#rne
The fault described in the above link matches your description.
Item 23 in this link (Reverse-ignition diode 1N414
http://www.4qd.co.uk/serv/nccbits.htmlhttp://www.4qd.co.uk/serv/nccbits.html
