Featherweight Wheels
    Are you planning on making a new batch of these for drills anytime soon?
      I'm currently looking into it, I have had quite a few requests.
        Do they interface with the GR-EP-45 from Gimson? Looking for a pair of wheels to mount
          It is worth noting that Gimson do also sell a wheel hub that fits the GR-EP-45 perfectly, so you can select a wheel with a flat face and simply drill 4x holes into them and mount that onto the wheel hub like you would a car wheel. Works fine for my Featherweight, which also uses the same motors.
          These wheels won't work with that motor anyway by the looks of things, the shaft is 10mm diameter with a keyway, the wheel's internal diameter is 12mm diameter but then again, AntTazz did mention did say that they might be able to machine to fit so worth enquiring?
            you could use THIS like Ocracoke suggested, or really anything that has the same keyway.
              Thanks for the info. Are the wheels still available to buy in this thread? Can do dm.
                I have delayed making them until the Saturn/Neptune gearboxes are being sold again, until there's a big influx of demand the cost wouldn't be justifyable
