Robot Wars Q&A
  • #76
    Robot Wars Q&A
    Bah! Blinked and missed that one!
    • #77
      Robot Wars Q&A
      Steve got it !!! Demolisher beat Armadillo to win the S2 FW comp.
      Martyn: 4
      Tim: 2
      AJ: 2
      Frank: 1
      Chris: 1
      Bex: 1
      Dan: 1
      John: 1
      Steve McG: 1
      Next Q:
      15: Who was the first robot to use the flywheel principle for a weapon
      (Hint: Its not Hypno-disc or Caliban)
      • #78
        Robot Wars Q&A
        Daisycutter / Daisychopper (cant remember which)?
        • #79
          Robot Wars Q&A
          Technically it was both DaisyCutter and Wild Wild Willy, both from Series 3.
          DaisyCutter had an actual vertical flywheel weapon, whereas WWW had a flywheel powered axe.
          • #80
            Robot Wars Q&A
            wrong on both counts. Hypno-disc does use the flywheel principle for a weapon, but it appeared before Daisycutter and Wild Willy, and Hypno-disc wasnt the first to use it. Think earlier...
            • #81
              Robot Wars Q&A
              Does Roadblock count?
              • #82
                Robot Wars Q&A
                Ill take a stab in the dark and say Torque of the Devil (with its rear spinny blade thing)
                • #83
                  Robot Wars Q&A
                  What about Killertron? They had an axe that was attached to a flywheel. It probably doesnt count though because I dont think the flywheel was spun up before the axe was fired but I might be wrong.
                  • #84
                    Robot Wars Q&A
                    I think Anthonys right but then again Im going to take a wild guess Krazee Tokyo(I think thats how you spell it).
                    • #85
                      Robot Wars Q&A
                      Steve got that one, Killertron did use a flywheel, but it was driving a weapon, not being used as one.
                      New Q will be up soon
                      • #86
                        Robot Wars Q&A
                        Ok, new Q
                        Which robot was built in 5 hours ?
                        • #87
                          Robot Wars Q&A
                          The Prince of Darkness. And it still crossed the Gauntlet end line twice.
                          • #88
                            Robot Wars Q&A
                            Very good Steve
                            I liked The Prince of Darkness, it was very amaturish, but it won both the gauntlet and the robot snooker outright
                            Martyn: 4
                            Steve McG: 3
                            Tim: 2
                            AJ: 2
                            Frank: 1
                            Chris: 1
                            Bex: 1
                            Dan: 1
                            John: 1
                            • #89
                              Robot Wars Q&A
                              Since when did Ozzy Osbourne take part in effing Robot Wars?
                              • #90
                                Robot Wars Q&A
                                Whens the next question?
