The Children In Need Tournament 2005
    If I can enter then Ill enter
    Robots name: Just Plain Bunkers
    Mass: 96KG
    Weapons: A flipper and A Pneumatic Head.
    Can It Self Right: Yes it can with the Flipper
    Velocity: 27MPH
    Turning Circle: 0mm
    Ground Clearance: 15MM at the sides and 1MM at the front and back
    Skirts: Nope
    Wheel Type: 6 Wheels
    Power: 8 Lem130s
    Body Shape: A Bunk Bed style Robot.
    Armour: 7mm 5 Grade Titanium all around
    Colour: My Favourite Colour Green
    Other: It has A Little cute Dragon on the top and the pneumatic head has glowing eyes.
    Summary: Good Nippy Just Plain Cool
    Strengths: Everything
    Weaknesses: One of those cars which can transform Into a dancer See the Vauxhall adverts.
      Power: 8 Lem130s
      That sure is comedy!
        Shape: Sphere shaped, if you hadn€™t already guessed
        Colour: See-Thru
        Dimensions: €¦meh
        Weight: 50kgs maybe?
        Motivation: Four 100mm diameter wheels, with rubber grips.
        Power: Two LEM130€™s at 36v and a 36v NiCad pack.
        Speed: 30mph, fast!
        Turning Circle: Don€™t ask€¦
        Ground Clearance: Variable from 0mm to 8ft in the air
        Skirting: Ha, good joke!
        Armour: A polycarbonate sphere (with a hatch to get inside). Inside, the €˜hamster€™ is made of an Aluminium monocoque covered with orange fur with two googly eyes.
        Weapon: Driving over other robots€¦
        SRIMECH: Always lands in a way it can move because of its ball shape. The hamster inside always lands on its wheels, no matter how badly it gets shaken about.
        Strengths: *sniggers*
        Better Description: A polycarbonate ball with a small robot inside, working in the same way as Psychosprout. The small robot is basically just the radio gear, a speedo, a few motors and some wheels to make it move. It€™s made of Aluminium and is covered in fur, just for fun. Basically it drives around and moves the sphere in the same way a hamster moves in a ball. If it gets flipped or whatever, the €˜hamster€™ inside always lands back on its wheels and drives away again. It€™s very fast, and very light and basically just runs around bumping into and running over things.
        Hows that? Ask if you need any more info.
          Oh, I knew Id forgotten something...
          Y4 has two extra features on (or in) it for the added comedy effect.
          1: It wears a cape, ala Batman.
          2: There is a woopie coushin hidden inside. Everytime the flipper fires, the woopie goes off.
            I dont want to argue, theres been enough of that already, but GGG is a three way cluster, painted like Pudsy (with bandages painted on the underneath), and seeing as theyre not working together, just in as three bots working independantly, its not like it intend to win with it, its just there to fill a spot, in fact its a bot i dont uise in any other tournament because it is meant to be a comedy bot, for someone not in this, you do moan a fair bit, and there, youve got *me* into a rant.
            Martyn, use GGG or use this, heck use both, or use none, whatever, not like i care. Tony, a little advice, and goodness knows im not trying to piss you off, leave the decisions to the guy running the tournament.
            Shape: Boxes (two way cluster)
            Colour: A very gothic creature of the night black and red.
            Comedy aspect: Googly eyes fake fangs
            Weight: 100 kg, 50 kg each
            Speed: 15 mph
            Turning circle: Zero
            Ground clearance: 5mm
            Weapons: Both have two drills on the front
            Armour: 5 mm Ti
            SRIMECH: None needed. Bandages on bottom like Going Going Gone
            Strengths: Creatures of Dahkness (darkness with a lisp you goof)
            Weaknesses: Don€™t like the sun (they burn easy )
              Whoa, easy there. I wasnt trying to piss you off, I was just saying GGG wasnt really a comedy bot. Or at least, i didnt really see what was a joke about it. Sorry for any offense taken.
                Shape: A cake shape eg. squat cylinder
                Colour: Black with lime psychadelic swirls all over (kind of like aborgine art)
                Comedy aspect: Its weapon - Ill cover it below
                Weight: 100 kg
                Speed: 20 mph
                Ground clearance: 1mm
                Weapons: On the top are little models of the other contetants (the people) arranged in a ring, next to each is a little arm which picks up little pins from the cetnral reservoir and stabs them into the models (which rotate and are lowered up and down on platforms so you get varying coverage) to produce a devastatign voodoo attack. This is all automatic so happens withotu my help. Also has eight carbon steel spikes around it, and can do a bit of full robot spinning.
                Armour: 12 mm Carbon fibre/titanium composite
                SRIMECH: a large rollcage, which also protects the weapon from beign squashed
                Strengths: Calls upon the dark power of voo-doo to smite its enemies...
                Weaknesses: Has a finite number of pins (about 500).
                • #23
                  *tries coming up with something funny...*
                  one question Martyn, will the arena floor be magnetic?
                  • #24
                    Oh yeah I forgot My robot will have at the sides two lightsabers and on the top at the top Left hand corner theres a toy clone trooper and on the Top Right hand corner theres a toy General Grievous.
                    • #25
                      Ill enter MDU3, you know the stats....
                      • #26
                        Can I reserve a spot for Ed, Edd n Eddy ? My Page of stats seems to of dissapppeared.
                        • #27
                          Stop the entering sign ups are now closed
                          Robots
                          1.Hammy
                          2.Batmobile
                          3.Going going gone
                          4.Martijn
                          5.Tails
                          6.Y4
                          7.Pit Drone
                          8.The Tim Tribute Robot
                          9.Just Plain Bunkers
                          10.Voodoo
                          11. ed, edd n eddy
                          And Martijn no the arena floor isnt magnetic, as its the rw arena just a little different
                          just for fun Diotor 2 and Grannies Revenge 2 will be joing the fun fun fun.
                          (Message edited by martyn on November 13, 2005)
                          • #28
                            Weight: 100kg
                            Dimensions: all 3 are 55cm cubes, but Edd has a triangular flipper shape at the front(like Raging Reality) and Eddy has a slight THz type extension on the front
                            Weapons: Ed: Ed has a front panel covered in solid stainless steel spikes, 5 rows of 6 spikes. Edd: Edd is armed with a rear hinged flipper that€™s powered by a soda stream bottle and can flip 150kg, and its Raging reality type shape. Eddy: Eddy has a large headsman axe, a smaller version of THz, driven by an astroflight through a gearbox delivering a 300kg force on the other end.
                            Drive: Edd and Eddy are powered by a pair of Astroflight motors powered by 36v NiCad packs with a 2wd system, but Ed has a pair of Mag C40s powering a 4WD system, also powered by 36v NiCad€™s.
                            Speed: Ed: 20mph, Edd and Eddy: 15mph
                            Armour: 3mm stainless for all of them
                            Srimech: Ed is invertible, Edd and Eddy can self right with their weapons
                            Colour: see photo on profile
                            Strengths: Work well together
                            Weakness: Each part is only about 33kg, so can be thrown easy
                            Link: 3 progned bar that is slotted into the Eds and is released by a magnetic catch so it fall on the floor when they split.
                            • #29
                              Weight: 100 kg
                              Shape: a pretty flat and invertible cylinder, with one wheel in the middle and two smaller cylinders mounted on the sides, with the bottom end scraping over the floor (also when inverted), these are extremely powerful double headed vacuum cleaners actually
                              Speed: 30 MPH
                              Clearance: a centimeter or so
                              Power: 1 B42-500 Magmotor at 48 volt
                              Movement: 1 wheel
                              Turning Circle: ~ 40 cm I think
                              Features: A one wheeled machine, how does it turn? Simple, the sides contain two powerful vacuum cleaners, when I wanna turn left, the left cleaner will be turned on and the left side will suck onto the floor, meaning the bot will turn, once turned far enough, the cleaner will be turned off. With two cleaners turned on, Ill be practically immovable
                              Armour: 8 mm titanium
                              Strenghts: will keep the arena relatively clean, look at that speed
                              Weakness: cant push, cant damage, look at that speed
                              note to self: never create a funbot again
                              • #30
                                oh yeah the Pneumatic head is shaped like Darth Vaders Mask and when it flips you hear the quote Luke I Am Your Father.
