you can only enter one robot for each country and theres gonna be 32 countries and ill make it fair.
World cup
World cup
To-Shay Guys,
Im entering Mad Cow
Dimensions-95cm length, 80cm width, 40cm height.
Weight-100kg
Shape-low wedge/sloped rear with Biohazard like side and rear skirts
Wheels-4 inner wheels
Speed: 20 mph
Weapon:A rear-hinged flipper. There is a strip on the bottom of the flipper, allowing the flipper to get under bots with skirts. The flipper is 750psi. There is the option of removing the strip and putting a small titanium plate that extends the flipper out 15cm. It could be used against dangerous spinners. There are two spikes at the back to prevent the robot flipping itself over.
Motors-2 LEM-COs running at 36v
Power-4 x 36v 3600mAh NiCD packs
Armour-6mm titanium all around
Ground Clearance-0mm front, 0mm around the sides/back with skirts.
Turning Circle-0m
Strenghts-Powerful flipper, nippy around the arena.
Weakness-People are always in awe of it.
(Message edited by kevin on September 17, 2005)
World cup
Fiery storm type thing
Weight-100kg
Shape-firestorm shaped
Speed: 20 mph
Weapon: A high pressure version of firestorms flipper
Ground Clearance-0mm front, up to 5mm everywhere else
Turning Circle-0m
Strenghts-powerful flipper, is easily mistaken for firestorm so people overestimate it and therefore try to pull off compelx manouvers which would work againts a good machine, but this machien can counter them because its not precision driven
Weakness - its design wasnt thought through at all, may do a double flip when self righting
Summary: its firestorm but at high pressure
