the first 6 robots have byes to the 2nd round
Tim robotourny2005
Tim robotourny2005
You probably need some more detailed rules
For example:
your views of walker weight
how many entries per person
weight classes
Clusterbot rules
Flying rules
Accuracy rules
Flipper pwoer rules
Spinner speed rules
and there are others.
Tim robotourny2005
By accuracy I meant how carefully will you scrutinise the stats to see if they are realistic.
Flipper power measures how far soemthing is flipped, not how many eg. firestorm has a vast number of flips but they dont go very far, in contrast chaos 2 has many less, but they are more powerful.
Spinner speed generally is at 1000, 1500 or 2000rpm, that means for a weapon with a 3m circumferance a blade could travel at approximatly 2.3km per second, which is kinda unrealistic.
Flying robots are robots that fly.
Walker limits are usually 150kg or 200kg depending on preference.
Ask some other people if you want more rules, as Im not that up on the rules, as my tournaments have had quite basic rulesets.
(Message edited by alex_holt on August 24, 2005)
Tim robotourny2005
Name- Couldnt Risk A Potato (CRAP)
Weight- 100kg
Shape- Box
Weapons- 2 X 46947rpm vertical discs
it acuracy is 97%
Robot 2
Name- Even Couldnt Risk A Potato er (even craper)
Weight- 100kg
Shape- circle
Weapons- 4 X 46947rpm horizontal discs
it acuracy is 97%
Tim robotourny2005
martyn and dave shep have got automatic byes
and the arenas are
death arena where theres 6 cpzs
normal arena
and gravitys delight an arena where theres 3 arena floor flippers
and house robots m2,101,atomic 2,die an 473kg bot with 5 flippers on front and back and 3 along the sides and its got a head with a flamethrower inside it,G5 a very first of its kind a 521kg clusterbot 1 of them has got a drill the other ones got a machine gun and grovity which is gravity with a wig on
and this is how the robots are set out
name
weight
speed
weapon
srimech Y or N
summary
tracks Y or N
walker ^ ^ ^
strengths
weaknesses
and i hope thats answered everything
Tim robotourny2005
Shape: Invertible box
Speed: 20 MPH
Weight: 95 KGs
Weapon 1: A front drum, spinning at 46947 RPM using a customised motor and drive train to give it near instant acceleration, able to rip any kind of armour to shreds.
Weapon 2: Rear flipper with 20 flips.
Armour: 3 MM of a customised alloy, which is lighter than Polycarb but completely invincible.
Drive: 4-wheel drive running off a customised drive-train, providing it with 30 HP
GC: 0 all over thanks to customised skirts, which will not be gotten under by ANYTHING. The only reason this can move is because it has such a powerful drive.
Strengths: Everything is customised
Weaknesses: Flipper has limited flips.
(Message edited by pcbore on August 25, 2005)
Tim robotourny2005
Speed: 20 MPH
Weight: 95 KGs
Armour: 3 MM of a customised alloy, which is lighter than Polycarb but almost completely invincible.
