The NSTT: Other-weights
    NSTT Other weights, current entries
    Raptors -
    Hell Boy - Dave W
    Catus-Baby-Catus - Martyn
    Xenophobia - Tony
    Feathers -
    Hells Angel - Dave W
    Storm Vortex - Martyn
    Conundrum - Tony
    Kinetic Energy - Aaron
    Ram-Raider - Chris
    Lights -
    Hell Hound - Dave W
    Typhoon Thunder - Martyn
    Toe Crusher - Tony
    Little Big Bot - Chris
    Middles -
    Hell Fire - Dave W
    Typhoon - Martyn
    Knee Breaker - Tony
    Tom - Chris
    Classic Heavys -
    Mini Disco or Something Else Depends - Martyn
    Atomic - Tony
    Remember next Saturday at Noon is the deadline, you lucky people getting an extra minute to enter
      OK, here is one, hopefully in-weight, if somewhat suicidal, Raptorweight.
      Weight: 6 kilos
      Body Shape: Round, with front cone head
      Speed: 23mph
      TC: 0
      GC: 3mm
      Wheels: 2 inner
      Armour: 4mm fibreglass
      Power: What sort of power would be suitable for a raptorweight? What I do know is that it is very powerful
      Weapons: Fixed 15cm spike, twin rear maces which are actually the wrecking balls from The Gauntlet RW toy.
      Srimech: Err...
      Colour: Brown.
      Inspiration: The freshwater turtle of the same name.
      Strengths: Very fast and very powerful
      Weaknessess: Weak armour and no srimech.
      And here is my Classic Heavyweight
      ORKA MK1
      Weight: 80 kilos
      Body Shape: A simple box
      Speed: Some 15mph
      TC: 0
      GC: 5mm, 0mm at front.
      Wheels; 6 inner
      Armour; 7mm titanium
      Power; 3x 12v batteries, powered by a couple of Magmotors
      Colour; Black with white patches
      Weapons; The robot itself is a weapon. It also has two wedge plates, one at the front, one at the back, for scooping up robots. The one at the front is the right way up, the one at the back is upside down.
      Srimech: The robot runs inverted, and the positioning of the wedge plates means that at least one is usable whatever side the robot is on.
      Inspiration; Ive always liked Orcas. Adding the K made it sound more dangerous.
      Strengths; Power, Invertable
      Weaknessess: Hard to turn
        Raptor Weight: none
        Featherweight: OverDrive
        Lightweight: MiniForce
        Middleweight: The Steel Sandwich
        Classic Heavyweight: Le Nez
        OverDrive, MiniForce and Le Nez can be found on my forum. The Steel Sandwich will be the latest version you know of and Ill try to get a Raptor design up later on.
        http://teamcode14.proboards24.com/index.cgi?board=otherstatshttp://teamcode14.proboards24.com/in...ard=otherstats
          Classic Heavyweight
          NAME- Mini disco
          SHAPE- Low invertible box
          COLOR- blue
          WEIGHT- 80kg
          DIMENSIONS- H: 20cm X L: 78cm X W: 50cm
          SPEED- 15mph
          TURNING CIRCLE- 0
          GROUND CLEARANCE- 5mm under disc, 0mm at sides and rear due to skirts with out skirts 5mm
          ARMOUR- 3mm grade 5 titanium
          WHEELS- 4 internal wheels on same drive as tornado
          POWER- 2 X 750-Watt Bosch motors
          WEAPONS- electric horizontal 4 toothed spinning disc at 3000rpm
          SRIMECH- invertible
          STRENGTHS- powerful weapon
          WEAKNESSES- no rear protection
          Middle
          Typhoon
          Light
          typhoon thunder
          Feather
          Storm Vortex
          Raptor
          NAME- Catus Baby Catus
          SHAPE- Invertible wedge
          COLOR- blue
          WEIGHT- 6kg
          SPEED- 11mph
          TURNING CIRCLE- 0mm
          GROUND CLEARANCE- 0mm under front wedge 4mm everywhere else
          ARMOUR- 2mm aluminum
          WHEELS- 4 inner ones
          POWER- 2X gold motors
          WEAPONS- none just the wedge
          SRIMECH- Its invertible
          STRENGTHS- Invertible, good pusher
          WEAKNESSES- high side ground clernace
            Entries are now closed
            Raptors -
            Hell Boy - Dave W
            Xenophobia - Tony
            Matamata - Chris
            Feathers -
            Conundrum - Tony
            Ram-Raider - Chris
            OverDrive - Andy (Current Champion)
            Lightweights -
            Hell Hound - Dave W
            Toe Crusher - Tony
            MiniForce - Andy
            Middleweight -
            Hell Fire - Dave W
            Typhoon - Martyn
            Knee Breaker - Tony
            Tom - Chris
            The Steel Sandwich - Andy
            Classic Heavys -
            Mini Disco - Martyn
            Atomic - Tony
            Orka Mk 1 - Chris
            Le Nez - Andy
            The Draw
            Right the FWs, LWs and MWs have more than 4 entries in each, so in the time between the end of the heats and the start of round 4, we will have:
            Featherweight Melees (One goes out)
            Hells Angel vs. Conundrum vs. Ram-Raider
            Storm Vortex vs. Kinetic Energy vs. OverDrive
            Lightweight Melee (One goes out)
            Hell Hound vs. Typhoon Thunder vs. Toe Crusher vs.
            Little Big Bot vs. MiniForce
            Middleweight Melee (One goes out)
            Hell Fire vs. Typhoon vs. Knee Breaker vs. Tom vs.
            The Steel Sandwich
            Tactics/predictions if you may
            Stats up onto the NSTT board later on, and the fights will be in the main thread.
            Dave
              Go all out on Hells Angel.
              Smash the hell out of anything unprotected from the top or invertible, aim for the wheels on invertible bots.
              The Steel Sandwich
              Try to leave the fighting to most of the other bots unless someone goes after me, but when one bot is weakened majorly, ill finish it off.
                Right, if Steve decides he wants to enter, he can because he was on holiday.
                • #23
                  Right.
                  FW:
                  Conumdrum, if its the real robot, its armour wont stand to my axe, so Ill concentrated on that
                  LW:
                  Typhoon is a problem, because of the shape, so Ill change the twin pincirs to a singular crusher for this fight and go after typhoon
                  MW:
                  Flip Typhoon over, hes a lot slower than Hell Fire
                  • #24
                    mw 259
                    chw roadblock,pussycat,behemoth and wheely big cheese
                    • #25
                      What part of Entries are now closed. dont you understand?
                      • #26
                        The Im a newbie and have to muck the forum up part *rolls eyes*
                        • #27
                          Why hello my fan fic friends, news has traveled about my Conundrum Mk1, nice to see its still remembered.
                          Little changes since its entry into the database is a Ev Warrior powered drum 2:1 at 24v off of the 3Ah bot packs, also the drum is much more like the one on my profile. The drive is better quality 18v drills running on 24v. Its surprising how much damage this little thing will take but the MDF chassis absorbs a hell of alot and the top and bottom are braced so they wont collapse in under impacts.
                          So if the owner of the tourment will let it Conundrums stats are actually......
                          Weight: 12kg
                          Dimensions: 40 x 35.5 x 13 cm
                          Shape: Rectangle/Box body,
                          Weapons: 2Kg 24v Ev Warrior Powered Drum with hardened steel teeth. Interchangeable with a hinged wedge
                          Transmission: Hi quality 18v drill at 24v, custom Ali wheels with Vulkalon grip.
                          Speed: Unknown
                          Ground Clearance: 3.5mm @ body, 0mm @ Wedge, 2mm @ Drum Teeth.
                          Srimech: Invertible
                          Armour: 6mm MDF and 3mm 6082 T6 Aluminum
                          Strengths: The drum
                          Weakness: Probably the angled side armour but theres nothing but a 40mm air gap behind it anyway.
                          If not then thats no problem and good luck Anthony.
                          Chris - ^_^
                          • #28
                            hey y r u takin the mick out of english newbies 4
                            • #29
                              May I make a suggestion - if you want to learn English, standard english is the place to start, as a lot of people find internet english such as yours quite difficult to comprehend anyway.
                              • #30
                                yeah says u
