Dinowarrior Destruction...Revamped.
  • #31
    OK, so AJ has filled his spot. But now I need the stats for either Matty or Martyn. Unless someone else enters, its EVERY MAN FOR HIMSELF.
    • #32
      Name-Forklift 2
      SHAPE- Low box with rear anti self flipping wedge
      COLOUR- Yellowy orange
      WEIGHT- 100kg
      SPEED- 18mph
      TURNING CIRCLE- 0m
      GROUND CLEARANCE- 0mm at front due to flipper, 0mm at sides due to skirts 7mm with out, 0mm at rear due to wedge. The skirts are held down by torsion springs
      ARMOUR- 3mm hardox
      WHEELS- has 6 inner storm 2 style wheels
      POWER- 2 x S28 Magmotors on 24v.
      WEAPONS- it now uses a flipping arm that works much like the matadors or Toro€™s the flipper is powered by co2 on a 120mm pneumatic ram, working at 145psi, the flipper front is pretty unique as its front is like that of a fork lift (it has 2 flat bits of metal) this is welded onto the flipper, the arm can toss robots very high and if possible out of the arena. The prongs of the forklift weapon are used to get under the corners or gaps of skirts
      SRIMECH- the flipper self rights the robot but because of the rear wedge thing it self rights like firestorm does i.e. the front wheels will go down first
      NOTES- this is a modified version of my robot from the panic attack forum.
      STRENGTHS- Powerful weapon
      WEAKNESSES- limited co2
      NAME- 25€™s revenge (thanks to Andy for the help on this robot) (was 25)
      SHAPE- Invertible disc like in the rw€™games
      COLOR- The shell is blue with the spinning bars being yellow with the ends tipped with red
      WEIGHT- 150kg
      DIMENSIONS- 80cm diameter X 30cm
      SPEED- 12mph
      TURNING CIRCLE- 0mm
      GROUND CLEARANCE- 6mm both ways up
      ARMOUR- 5mm titanium/vanadium alloy with 2mm polycarbonate laminate to stop the carbon tipped discs
      MOVEMENT - The robot is a shuffler which works both ways up
      WEAPONS- Ok its based on son of whyachi but not quite like it. The robot has the 3 triangle spinning bars like SoW but they are attached to the center outer rim of the robot this spins round at around 3000rpm this is designed to make a robot like SoW that cant be flipped over and immobilized the spinning outer shell is powered by 2 B42-500 Magmotors at 36volts
      NOTES- This weapon idea was come up by me Martyn Forsyth and Andrew Jackson it also flies the Scottish flag
      STRENGTHS- Invertible, has powerful weapon, the top and bottom both ways can€™t be hit by axes or crushers due to the bars
      WEAKNESSES- easy to flip when weapon isn€™t spinning
      Shape: Low Wedge with small rear wedge
      Motivation: it now uses four storm 2 style Vulcalon wheels
      Speed: 12.5 Mph
      Weight: 100kg
      Height: 300mm to top of body, 600mm to the top of the disc
      Length: 1300mm
      Width: 600mm
      Weapon: 500mm Vert. flywheel @ 3000rpm. Has a 4.00 second spin up time due to the C40-500 Magmotor on 36v with a 2:1 twin tension cog belt reduction. The flywheel produces 31.5Kj€™s at maximum RPM but is lethal at around 1 second. The second weapon is also the srimech, this weapon is a low pressure pneumatic flipper running on 10Bar (145psi) running into a single 80mm bore ram. This produces 509kg at the ram and is then transferred into the flipper with a leverage point ratio of 1:1. This is a forward facing flipper like FireStorm and will have no problem toppling the heaviest of robots.
      Chassis: 4mm Grade 5 Titanium monocoque with extra 5mm Titanium ribs to give it more rigidity.
      Drive: 2 x S28-400 Magmotors @ 36v with a 10:1 Mod 2 spur gear reduction
      Batteries: 90 x 3000mAh NiCD cells producing 36v @ 9amp
      Color- the robot and skirts and flipper are blue and the disc is yellow
      Clearance- it has 0mm at the front due to the wedge it has 0mm at the sides due to skirts its 6mm with out it also has a 0mm at the rear due to the small wedge which is there to replace the problem of the skirt being flipped into the disc. The skirts are NOT hinged and held down by torsion-springs so they shouldn€™t spring up and the rear one shouldn€™t go up into the disc
      Notes- The flywheel is at the back off the robot it goes over the back of the wedge so if I can get a robot up the wedge far enough it will be hit by the disc. The skirts stop the robot landing on its side.
      Achievements- as disco, 3rd seed in ajwars and undethed challenge belt holder in ajwars extreme 1-4 ajwars 3 8th seed, as disco 4, semi finalist of the lord of the ring tourney, WINNER OF THE LORD OF THE RING TOURNEY
      NAME- The deer (was crusher chaos)
      SHAPE- Invertible box
      COLOR- the robot and claws are a dark green color
      WEIGHT- 100kg
      DIMENSIONS- 1m x 80cm x 25cm (l,w,h)
      SPEED- 15mph
      TURNING CIRCLE- 0mm
      GROUND CLEARANCE- It has 6mm at the front due to the claws and has 0mm at the sides and rear without skirts 6mm. The skirts also work both ways up.
      ARMOUR- 3.6mm hardox
      MOVEMENT- 4 inner wheels that make the robot invertible
      WEAPONS- it has a front pair of horizontal hydraulic crushing claws set up like deers antlers like you fine in extreme destruction. The claws have 3.5 tones of crushing force on the front tips of the claws at the middle is 6tones and right at the back it has 8 tones of crush. The claws are powered by hydraulics through a 120mm bore rams at 3000psi
      NOTES- invertible, wide base means I wont topple while the deer is crushing
      STRENGTHS- Very powerful weapon
      WEAKNESSES- it could be turned into venison
      Name- Catus Catus 8.1
      SHAPE- It€™s shaped like a cat about to pounce
      COLOUR- black and white
      WEIGHT- 150kg (it€™s a shuffle bot)
      DIMENSIONS- 90cm X 78cm X 35cm
      SPEED- 18mph
      TURNING CIRCLE- 0mm
      GROUND CLEARANCE- 0mm at the front due to jaws, 0mm at rear due to tail and it now has 0mm side ground clearance due to new side skirts
      ARMOUR- it has 3mm hardox
      MOVEMENT- moves on 8 inner camshafts
      POWER - 2 S28-400€™s on 24volts
      WEAPONS- It has a front pair of growler style crushers shaped like a cats head powered by a 80mm bore ram with 3000psi hydraulics, the rear weapon is a flipping tail powered by 80mm Bore ram on 1000psi pneumatics.
      NOTES- has curved sides to stop landing on side
      STRENGTHS- great weapons, self rights with ease
      WEAKNESSES- Limited co2
      Name- Take me out (thanks to Dave for naming the robot for me)
      SHAPE- Wedge
      COLOUR- Dark grey
      WEIGHT- 100kg
      DIMENSIONS- Height: 20cm, Length: 80cm, Width: 65cm
      SPEED- around 18mph
      TURNING CIRCLE- 0mm
      GROUND CLEARANCE- 0mm at the front due to wedge extender, 5mm at sides and rear
      ARMOUR- 4mm Aluminium Boron Carbite
      MOVEMENT- 4 inner vulcalon wheels, it uses a skid steer system like tornado
      DRIVE- 2 LEM 130€™S on 36 volts
      BATTERIES- custom 3300mAh NiCad Cell 36v BotPack
      WEAPONS- The robot has a 1000psi nitrogen flipper on a 80mm bore on a 100-stroke ram which should make around 3.5 tones at the ram (if I am incorrect please correct me) the nitrogen is stored in 2, 2.2kg canisters, the robot has around 25 flips in a fight, the flipper is on high pressure
      STRENGTHS- Powerful weapon, good drive
      WEAKNESSES- limited supply for the weapon
      • #33
        Thank you. Ill wait a little while longer to see if anyone else enters...if not, Im sorry Matty, I cant take you on board.
        • #34
          It is his own fault for not bothering to fulfil his reservation, hence the reason why I use time deadlines not spaces to get rid of the people who reserve entries and not post stats.
          • #35
            HERE IS THE FIRST ROUND LINE-UP
            HEAT 1
            Heart of Fire vs Death Adder 4 vs Take Me Out
            Son of Wedgie vs Black Panther King vs SOR 4.0
            HEAT 2
            Shovearound 2 vs CDD, IOAR vs Dante
            Double Killa vs FP 4.0 vs The Deer
            HEAT 3
            Hurricane Hugo 4 vs Flipping Mad RKACG vs Gigabyte
            Metalmorphosis vs Slaying Mantis F vs Catus Catus 8.1
            HEAT 4
            Mr Slave 2 vs MORD 2 vs Disco 5
            The Circle Revisited vs Archangel of the Abyss vs Wedga Revo
            HEAT 5
            Little Man On A Boat vs Snakebite 4 vs Tengu 7
            HHISTWT vs GeForce 3.0 vs 25s Revenge
            HEAT 6
            Stalker vs Mortage vB vs Psyclone
            SYNDOS vs Slammer vs Forklift 2
            These are the Brisbourne Rumbles that take place during each heat...
            13 Black vs Plunderbird 5 vs Thor
            259 vs Pussycat vs Tornado
            Atomic vs Razer vs Tough As Nails
            Behemoth vs Ripper vs Wheely Big Cheese
            Big Nipper vs Firestorm 5 vs Storm 2
            Bigger Brother vs Gravity vs Supernova
            Bulldog Breed vs Hellbent vs Terrorhurtz
            Constrictor vs IG-88 vs Tetanus Booster
            Crushtacean vs M2 vs Robochicken
            Dantomkia vs Manta vs S3
            Diotoir vs Mantis vs Steel Avenger
            Dominator 2 vs Panic Attack vs Stinger
            Instead of wasting time with these realies, the 12 winners have an all-out rumble in the Grand Final.
            SPECIAL EVENT: HOUSE ROBOT RUMBLE (before final)
            Matilda vs Cassius Chrome vs Growler vs Dead Metal
            Shunt vs Sir Killalot vs Sgt Bash vs Mr Psycho
            See you next week, when I hope to get some fights up.
            • #36
              Could you change the name to Death Adder 3, please, Chris? I dont know why I called it DA4. I will see if I can run into Heart Of Fire with the scoop and send it flying, then attack it with the axe when it comes back down. I will also attack Take Me Out side on with the axe.
              • #37
                Jeez Rich, do you have some sort of grudge aginst me, always attacking me when you get the chance?
                Focus on take me out, Death Adder will be a bitch to attack so ill see if I can run while spinning fast enough to get away. My horrible control wont help though, so well see if I dont tear apart the arena first
                • #38
                  Flip whatever is in the way
                  • #39
                    flip whoever gets in my way
                    • #40
                      eerr....hit and run i think. mainly an axe job as flipper is going to be pointless, use it only if Im actually under them, dont go trying to get under.
                      • #41
                        Not trying to be a bother, but when is this starting?
                        • #42
                          Hopefully, tomorrow. At the minimum Ill be able to write it up tomorrow and post it on Tuesday. Ive been having a holiday. A 3 week holiday. As a result, Ive been in very little mood to write anything.
                          • #43
                            Stupid Edit rules...
                            P.S. Please be aware that fights may be few and far between. Not only do I have to do things like college, but, to be honest, writing battles isnt my strongest writing point anymore.
                            However, regardless, I intend to do this, then finish off with a special Fusion tournament, but Ill explain that in more detail when the time comes.
                            • #44
                              As I have no idea as to how long this is going to take, since Ill probably lack a great deal of free time, Im now only doing the main competition and the House Robot Rumble. Sorry Tom B, but those real robot rumbles are out.
                              • #45
                                Good news. I can finally start the tournament. The first fight should be up by tomorrow, I promise.
