BriteSpark Enterprises!
    1. Wedge Devolution Steve McG
    2. Killotine: Evo
    3. SDIV
    4. Whirligig 4.0
    5. Clawdius Decimus Murderous
    6. Chameleon
    7. Tony the T-Ram Engine
    8. Tails
    9. Mario Brothers Tony P
    10. AK-47 Slapper
    11. Shovearound 2
    12. Hurricane Hugo 4
    13. Vampire Killer
    14. Aquarius
    15. Novastorm
    16. Mr Slave
    17. Agro 3.5 Rich S
    18. Battle Raptor 4
    19. Death Adder 3
    20. Drilla Killa 7
    21. MORD 2
    22. Snakebite 4
    23. SYNDOS
    24. Tenderizer€™s Revenge
    25. Tengu 7 Alex H
    26. Dante
    27. Hector
    28. Baldur Gamma
    29. Allanon
    30. Archangel of the Abyss
    31. Sorrow
    32. Kali
    33. Die Ceratops Re-Invertus Chris M
    34. Orka Mk 4
    35. Cyclone Force 2.5
    36. Leprosy Infection
    37. Mega Masher
    38. No, Not Steven What€™isname
    39. Axe-O-Lotl
    40. Obliteration
    41. Quocunque Jeceris Stabit Dave S
    42. Calm Down Dear (It€™s Only a Robot)
    43. Son of Wedgie
    44. The Circle Revisited
    45. P.C.C
    46. Flipping Mad RKACG
    47. A Large Red Bus Drove My Love Away
    48. Chalkie 3G
    49. Flippa Frenzay Mk 7 Matty McD
    50. No Close Shave 3
    51. Not Another pushover 3
    52. Wind Chiller
    53. Ripoff Yet Again
    54. Growling Storm 3.5
    55. The Axe Attaxe
    56. I€™ve Got a Crush on You
    7 spaces filled, 5 to go! Thanks to everyone who has entered so far and Ill see ya all when I get back on Saturday evening. I want ALL the spaces filled or else!! :wink:
      Flaming Hell
      Weight: 100kg
      Dimensions: 90x90x60 cm
      Weapon: a triangular spinning cage with 3 sharpened bot openers on each end, weighing 5kg each, spinning at 3000 RPM, powered by a Lemco on 36v
      Power: 2x Bosch 750 motors at 24v (its been made so that the cage motor gets 36v but the drive only gets 24, as the drive is ok as it is on 24V)
      Shape: circular base with triangular cage atop
      Speed: 15mph
      Drive power: 4bph
      Notes: small electric actuators in the rotor arms in order to self right. They have been shock proofed so that the weapon impact will not bust them, and the cage spins 2mm from the ground. Small bearings for the cage and the far set apart wheels give it increased stability for a FBS
      Turning Circle: 0cm
      Armour: 3mm titanium
      Wheel Type - 4 small wheelbarrow type wheels (no need for great traction)
      Strengths: Power of cage
      Weakness: Unpredictable bounce off from an opponent
      Hell Machine
      Weight: 100kg
      Dimensions: 140x100x60 cm
      Weapons: Lemco motor powered axe (run through gear box) that can deliver an axe blow of 3 tons (according to my calculations) and rear linier actuator operated lifting arm that can flip 600kg
      Srimech: Side arms and rear arm
      Speed: 15mph
      Transmission: a 4 wheeled Tornado set up(36v and same gearing), but with a pair of Mag C40€™s in place of the Bosch motors, and a set of NiMh in place of the heavy Lead Acids the real thing uses.
      Turning Circle: 0m
      Ground clearance: 0 at the scoop and wedge edge, 2mm the rest of the way around
      Wheel Type: Go-kart
      Body Shape: scoop fronted, wedged back
      Armour: 8mm Grade 5 Titanium and 2mm stainless steel
      Colour: Black with flame face on scoop and name in blood writing on side, devil head on rear wedge
      Strengths: Enormous pushing power (About 12hp), EXTREMELY powerful axe, relentless in attacking (until a robot is immobile)
      Weakness: Dislikes spinners, doesnt like weapons that use carbon
      Weight: 100kg
      Dimensions: 150cm x 80cm x 120cm
      Shape: low angled box with disc on the front like 13 black and rear 259 disc, style
      Weapons: A front mounted Horizontal spinning disc and a rear mounted vertical spinning disc, both running at 4500rpm and delivering a blow of 75kj
      Top Speed: 13 mph
      Transmission: 4 Rubbertex coated aluminium wheels (Rubbertex is a grippy rubber substance used on the K*bot tables) run on a Smidsy type wheel system, and run by a pair of Bosch 750€™s and a bank of Ni-cads to give me more weight for armour
      Armour: 8mm Titanium
      GC: 3mm either side and back, 7mm under the disc at the front, variable at the sides of the disc
      Srimech: powerful electric arms mounted on the top
      Turning Circle: 0cm
      Strengths: devastating weapons
      Weakness: carbon based weapons
      Notes: will NEVER turn the vertical flywheel into an opponent as it will throw SH over. Also, counter-acting discs (vertical and horizontal) will keep it stable, and if it is flipped, it does a funny jig in the air before coming down, most of the time, right way up
      Dimensions: 120cm x 80cm x 40cm
      Weight: 100kg
      Shape: steep wedge front, elongated wedged tail (not used as a weapon)
      Weapon: 1000psi 2 pivot pneumatic flipper that can generate enough momentum and force to throw a 100kg robot 25ft up and 20ft across
      Top speed: 18mph
      Transmission: just like Razer€™s
      GC: 0 at the front, 2mm down the side, 4mm at the back end
      Turning Circle: 0cm
      Armour: 6mm aluminium and steel alloy
      Strengths: Can win with one weapon shot
      Weakness: None
      Notes: 4 wheels, the rear two of which are Razer type, so the flipper is always facing its opponent
      Name: Jaws of Hell
      Weight: 100kg
      Dimensions (LWH): 130 x 100 x 25 cm
      Body shape: Tornado shaped, but with 6 wheels
      Weapons: a hydraulic tearer. The idea is that the large blade that is edged on both sides punctures the armour of an opponent, and a 3000psi hydraulic ram separates them, causing a huge tear in the armour. The edge is carbon tipped, so Titanium is not even there as far as Im concerned.
      Power: a pair of LEM 130s on 36v running through a Storm 2 transmission (with 6 vulcalon wheels, with small screws in them for that little extra)
      Armour: 4mm Hardox and 2mm stainless steel
      Srimech: invertible
      Speed: 27mph
      Strengths: vicious weapon
      Weakness: Unique weapon, may be mis-understood
      Weight:100kg
      Dimensions: 100 x 100 x 35 cm
      Shape: Low wedge, rounded back
      Weapons: A 750 PSI pneumatic arm that is mainly for self righting but can be used as a weapon, and a set of 3 Kill Saws at the back. The Kill Saws four, 20 inch, carbide tipped, SystiMatic saw blades. The blades are powered by a 48 volt, 3.5 horse power motor and can shred titanium and many other things too.
      GC: 0mm at the front, 1mm the rest of the way
      Wheels: go-karts
      Power: a pair of Bosch 750s on 36v, whereas the weapon is on 48v
      Speed: 18mph
      Armour: 2mm stainless steel and 4mm aluminium
      Strengths: rip-roaring weapon
      Weakness: iffy armour
      Weight: 100kg
      Dimensions: 100 x 100 x 50cm
      Shape: Vortex, but without the motor sticking out the back
      Weapons: A 27kg outer-rim weighted steel vertical flywheel, Powered by a B&S motor at 48v and run through a 40:1 ratio chain and sprocket transmission. The disc runs at 3500RPM but packs a 79Kj wallop (I worked it out; it€™s not that dissimilar from Matildas tail disc).
      GC: 3mm all the way around
      Wheels: 2 x Vulcanised Aluminium hubs
      Power: a pair of Bosch 750 watts motors running on 36v (Like Flaming hell, wired so the drive gets less and the weapon gets more) running through a 10:1 ratio gearbox
      Speed: 12MPH
      Armour: 6mm Stainless Steel
      Colour: Black, with pentagrams and demon faces painted in random places
      Strengths: Devastating Weapon
      Weakness: No srimech as such, but can run on the disc, which is then thrown into reverse which causes the robot to flip over, Stinger Style. Tipped right way up
      And just for the fun of it
      Weight: 100kg
      Dimensions: all 3 are 55cm cubes, but Edd has a triangular flipper shape at the front(like Raging Reality) and Eddy has a slight THz type extension on the front
      Weapons: Ed: Ed has a front panel covered in solid stainless steel spikes, 5 rows of 6 spikes. Edd: Edd is armed with a rear hinged flipper that€™s powered by a soda stream bottle and can flip 150kg, and its Raging reality type shape. Eddy: Eddy has a large headsman axe, a smaller version of THz, driven by an astroflight through a gearbox delivering a 300kg force on the other end.
      Drive: Edd and Eddy are powered by a pair of Astroflight motors powered by 36v NiCad packs with a 2wd system, but Ed has a pair of Mag C40s powering a 4WD system, also powered by 36v NiCad€™s.
      Speed: Ed: 20mph, Edd and Eddy: 15mph
      Armour: 3mm stainless for all of them
      Srimech: Ed is invertible, Edd and Eddy can self right with their weapons
      Colour: see photo on profile
      Strengths: Work well together
      Weakness: Each part is only about 33kg, so can be thrown easy
      Link: 3 progned bar that is slotted into the Eds and is released by a magnetic catch so it fall on the floor when they split.
      Oh, and make sure this tourney is finished, Im getting annoyed with ones that start and dont finish
        Save place please!!!
          Youre not allowed to either AJ:P
            NAME-Disco
            SHAPE- Low box
            COLOUR- blue
            WEIGHT- 100kg
            DIMENSIONS- l: 90cm X w: 78cm X h: 35cm
            SPEED- 15mph
            TURNING CIRCLE- 0
            GROUND CLEARANCE- 5mm under disc and rear, 0mm at sides due to skirts with out skirts 5mm
            ARMOUR- 4mm grade 5 titanium
            WHEELS- 4 internal wheels on same drive as tornado
            POWER- 2 x S28-400 Magmotors @ 36v
            WEAPONS- electric horizontal spinning disc at 3000rpm. Has a 4.00 second spin up time due to the C40-500 Magmotor on 36v with a 2:1 twin tension cog belt reduction. The flywheel produces 31.5Kj€™s at maximum RPM but is lethal at around 1 second. and a mechanical srimech powered by a linear actuator.
            SRIMECH- Yes on top of robot works like a panic attack self righter but it€™s in the top of the robot so it doesnt look like its there.
            STRENGTHS- powerful weapon
            WEAKNESSES- high rear ground clearance
            NOTES- An old face is back but much deadlyer than before, the new motors mean disco can push back against some of the new ram bots.
            NAME- The deer (was crusher chaos)
            SHAPE- Invertible box
            COLOR- the robot and claws are a dark green color
            WEIGHT- 100kg
            DIMENSIONS- 1m x 80cm x 25cm (l,w,h)
            SPEED- 15mph
            TURNING CIRCLE- 0mm
            GROUND CLEARANCE- It has 6mm at the front due to the claws and has 0mm at the sides and rear without skirts 6mm. The skirts also work both ways up.
            ARMOUR- 3.6mm hardox
            MOVEMENT- 4 inner wheels that make the robot invertible
            POWER- 2 x S28 Magmotors on 24v.
            WEAPONS- it has a front pair of horizontal hydraulic crushing claws set up like deers antlers like you fine in extreme destruction. The claws have 3.5 tones of crushing force on the front tips of the claws at the middle is 6tones and right at the back it has 8 tones of crush. The claws are powered by hydraulics through a 120mm bore rams at 3000psi
            NOTES- invertible, wide base means I wont topple while the deer is crushing
            STRENGTHS- Very powerful weapon
            WEAKNESSES- it could be turned into venison
            Shape: circle shaped (like gyrobot)
            Color: Black
            Motivation: Wheels
            Speed: 15MPH
            Weight: 98.1kg
            Height: 140mm
            Length: 700mm
            Width: 700mm
            Weapon: The weapon is a 1300mm 20.4kg Hardox spinning bar @ 2500RPM. The spinning bar is powered by two Lemco 170 on 48v with 1.5:1 gearing. The weapon is spun up to full speed in 4.32secs, but will be savage by 1second. The spinning bar produces a whooping 110kj¡¦s at the full RPM and has teeth under the blade that sit 50mm from the floor to get those nasty thin dietary bots. The whole weapon is mounted on a 75mm silver steel shaft and uses oilite bearings which are mounted in 20mm titanium mounts which are then welded to the titanium monocoque body. The spinning weapon will self-right the robot if it manages to flip itself via a reverse mauler dance preformed numerous times by Tornado-Mer and Killer Byte.
            Drive: The drive is a 4WD system powered by 4 x Astro Flight Cobalt 90¡¦s, each producing 1HP on 24v. The drive isn¡¦t designed for hard pushing, but because of the power in the weapon and the supports on the weapon, the drive shouldn¡¦t have to do any pushing, just a lot of running and chasing.
            Batteries: 6 x 24v 3600mAh NiCD Battle packs producing 48v at 9amp.
            Armour: 5mm Grade 5 Titanium monocoque with inner 20mm bulkheads
            Notes: Hell of a dangerous spinning weapon, because the body of the robot is round, it¡¦s hard for anyone to push the robot around as they will just slides around it.
            Weakness- Loopholes
            Strengths
            Weight Calculations:
            Weapon System: 38.4kg (2 x 7kg Lem170, 20.4kg weapon, 4kg mod 2.5 gears)
            Batteries: 12kg (6 x 2kg Battle Packs and cables)
            Electronics: 3kg (Connectors, Solenoid for weapon, Speed controllers, gyro)
            Drive: 13kg (4 x 2.5kg motors + gearboxes & mounts, 4 x 0.75kg wheels)
            Chassis/Armour (monocoque): 31.7kg (Includes all weapon mounts, bearings, bulkheads, supports, battery mounts, electrical foam & rubber shock mounting and bolts)
            Total Weight: 98.1kg
            Name- Dr. Ram, Dr. Ram. Calling Dr. Ram (previously Dr. Flip gold)
            SHAPE- Invertible wedge
            COLOUR- green
            WEIGHT- 100kg
            DIMENSIONS- 25cm X 65cm X 60cm (height X length X width)
            SPEED- around 25mph
            TURNING CIRCLE- 0mm
            GROUND CLEARANCE- 0mm under the front wedge, 6mm for the rest
            ARMOUR- 4mm hardox
            MOVEMENT- uses 6 vulcalon wheels
            POWER- 2 x LEM130
            WEAPONS- the robot uses 2 biohazard style arms one for each way to lift and flip robots, like with storm 2 they are powered off the drive motors
            STRENGTHS- good weapons, excellent pushing power
            WEAKNESSES- high ground clearance
            NAME- Disco tech 2
            COLOR- silver
            WEIGHT- 100kg
            SPEED- 20mph
            TURNING CIRCLE- 0mm
            GROUND CLEARANCE- 6mm under the discs has 0mm at sides due to skirts that will work when flipped
            WHEELS- it has 6 inner wheels
            POWER- Drive: 2 x S28-400 Magmotors @ 36v with a 10:1 Mod 2 spur gear reduction connected to the 6 wheels.
            Batteries: 120 x 3000mAh NiCD cells producing 36v @ 9amp
            WEAPONS- It has 2 spinning each spinning at 3000rpm. Has a 4.00 second spin up time due to the C40-500 Magmotor on 36v with a 2:1 twin tension cog belt reduction. The flywheels produce 31.5Kj€™s at maximum RPM but is lethal at around 1 second. It has one weapon on the front and one on the back
            SRIMECH- Invertible
            NOTES- can spin on the spot
            STRENGTHS- fast, powerful weapons, good pushing power
            WEAKNESSES- easy to flip if discs aren€™t spinning
            NAME- Super Speed Bump
            SHAPE- Invertible wedge with a curved back
            COLOR- Red
            WEIGHT- 100kg
            SPEED- 15mph
            TURNING CIRCLE- 0mm
            GROUND CLEARANCE- 0mm at the front 5mm at the sides and 6mm at the rear to flip it self over
            ARMOUR- 4mm titanium/vanadium armor
            WHEELS- It has 4 wheels 2 at the rear and 2 near the middle
            POWER- 2 S28-400 Magmotors running at 24v
            WEAPONS- it has 2 flippers one on either side of the wedge both are powered by 80mm Bore ram on 1000psi, they can work separately or together normally separately
            SRIMECH- invertible
            STRENGTHS- Powerful flippers, low height WEAKNESSES- easy to flip from the rear (not that it will effect it)
            NAME- Mousey 4 (was Mousey 3)
            SHAPE- Shaped like a mouse with a sort of like front wedge
            COLOR- blue
            WEIGHT- 100kg
            SPEED- 10mph
            TURNING CIRCLE- 0mm
            GROUND CLEARANCE- 0mm at the front 6mm for the rest
            ARMOUR- 5mm grade 5 titanium over that is 3mm flameproof fur
            WHEELS- inside robot, 4-wheel drive
            POWER- s28-400 on 24volts so shouldn€™t burn out
            WEAPONS- flipper on the wedge which self rights the robot
            NOTES- covered in blue fur and has two fire storm style flippers to get it off the wall if flipped on wall
            STRENGTHS- good armor under fur, fur can jam discs
            WEAKNESSES- Limited CO2, it€™s a mouse
            Name-Forklift 2
            SHAPE- Low box with rear anti self flipping wedge
            COLOUR- Yellowy orange
            WEIGHT- 100kg
            SPEED- 18mph
            TURNING CIRCLE- 0m
            GROUND CLEARANCE- 0mm at front due to flipper, 0mm at sides due to skirts 7mm with out, 0mm at rear due to wedge. The skirts are held down by torsion springs
            ARMOUR- 3mm hardox
            WHEELS- has 6 inner storm 2 style wheels
            WEAPONS- it now uses a flipping arm that works much like the matadors or Toro€™s the flipper is powered by co2 on a 120mm pneumatic ram, working at 145psi, the flipper front is pretty unique as its front is like that of a fork lift (it has 2 flat bits of metal) this is welded onto the flipper, the arm can toss robots very high and if possible out of the arena. The prongs of the forklift weapon are used to get under the corners or gaps of skirts
            SRIMECH- the flipper self rights the robot but because of the rear wedge thing it self rights like firestorm does i.e. the front wheels will go down first
            NOTES- this is a modified version of my robot from the panic attack forum.
            STRENGTHS- Power full weapon
            WEAKNESSES- limited co2
            There you go, a random team raven many of whom have come out of retirment for this tourny
              I read the rules a while after asking for a reserved place. If people dont want me in their tournaments, just tell me so. Youve just lost an entry Dan.
                He doesnt not want you. He just dosent want you reserving a place beacuse you take forever to make stats.
                • #23
                  using double negatives are bad very bad
                  • #24
                    Can it, Martyn.
                    • #25
                      *puts Tony in a can on Banked Beans*
                      Im entering no tournaments which dont allow me to reserve a place, simple. I find it absolutely riddiculous.
                      • #26
                        can what exsasctly? the sun the potatos?
                        • #27
                          ORKA MK4
                          Weight: 100 kilos
                          Body Shape: Behemoth
                          Speed: Some 15mph
                          TC: 0
                          GC: 2mm, 0mm at front.
                          Wheels; 6 inner
                          Armour; 7mm titanium
                          Power; 3x 12v batteries, powered by a couple of Magmotors
                          Colour; Black with white patches
                          Weapons; A Behemoth like bucket scoop, made from titanium, and quite capable of lifting 300 kilos. It has a claw like device to grab an oppodent, like the claw on Mantis. The scoop is pnumatically powered, and has about 45 odd flips.
                          Srimech: It has a dorsal fin on top used for self-righting
                          Inspiration; Ive always liked Orcas. Adding the K made it sound more dangerous.
                          Strengths; Weapon
                          Weaknessess: Hard to turn
                          BIO
                          Every big team needs some big star to bring in the crowds. My big name is Orka MK4, representing Team Dinowarrior in all its glory.
                          No one is faster, smarter or more agile than Orka Mk4. When charging, other robots need to get out of his way. He can flip just about ANYTHING that doesnt take the warning, or simply grab hold of them. Hes ready for battle! Are you?
                          • #28
                            DIE-CERATOPS RE-INVERTUS
                            Weight; 100 kilos
                            Body Shape: Wheely Big Cheese
                            Speed; 15mph
                            TC; 0
                            GC; 0mm at front, 3mm at sides and back.
                            Wheels; 2 inner, sticking out only slightly,
                            Armour; 8mm titanium
                            Colour; Green, with Killer Carrot style wrinkles, mouth and eyes. One of the eyes has a plaster over it, the other is a black eye. A few bandages are painted on this time.
                            Weapons: A huge Wheely Big Cheese style flipper, capable of flipping a tonne or so.
                            Srimech; As the name suggests, the robot runs inverted. Bars prevent side strandings, and the back is rounded, so stranding THAT way is outta the question. The flipper works upside down.
                            Inspiration; Ive always liked Dinosaurs. This is a pun of Triceratops. The Invertus part is pretty obvious.
                            Strengths; The ability to work upside down and still be able to use its weapon, now easier to control.
                            Weaknessess: Tengu VI
                            BIO
                            Orkas cute-on-one-side-pure-hell-on-tuther friend, Die-Ceratops is equally as powerful and as nippy as his buddy. In the arena, he can get to oppodents/victims in record time. Then, once his flipper is underneath them, they can kiss the ground good-bye. Of course, hes teamed with me, and I can be rather protective over him...
                            • #29
                              CYCLONE FORCE 2.5
                              Weight; 100 kilos
                              Body Shape; Storm 2
                              Speed; 25mph
                              TC; 0
                              GC; Side is 0mm due to skirts. Back is 2mm. See set-ups for front GC
                              Wheels; 6 inner
                              Armour; 7mm Titanium.
                              Power; Similar stuff to what Storm 2 uses.
                              Colour; A blue-ish grey tone all over.
                              Weapons; The robot has 5 set-ups, 2 brand new...
                              SET UP 1...A lifter device, similar to Storm 2. In theory, it can lift 190 kilos. The front makes a wedge and results in a 0mm GC. However, the wedge is useless upside down.
                              SET-UP 2...A pair of Kan Opener style claws, with about 4 tonnes of pressure at the tip. Front GC for this and Set-up 3 is 1mm.
                              SET-UP 3...A Disc-O-Inferno style disc, reaching speeds of up to 3000rpm and with similar damage capability to this dangerous bot (I mean, look what it did to Panic Attack).
                              SET-UP 4...Two 30cm long spikes, which, combined with the speed of the robot, can easily penetrate weaker armours (Id say anything 4mm thick or less, minus Steel, is in a bit of trouble).
                              SET-UP 5...The most risky approach, A simple bucket scoop, like X-Terminator. The scoop is static, but can get underneath virtually zero ground clearance. Its front is 0mm.
                              Srimech; The robot runs inverted, the sides are protected by the skirts and back stranding is impossible. Set-ups 2, 3 and 4 work upside down.
                              Inspiration; The original Cyclone was named because it is the name of a storm and it sounds threatening. The force came later, after it became a pusher.
                              Strengths;Raw power
                              Weaknessess;Lack of control, Set-ups 1 and 5 do not work upside-down.
                              BIO
                              When Cyclone Force 2.5 is in the game, every other piece of metal is scrap! Cyclone can travel across the arena with great speed AND power. His interchangable weapon system means NO ONE is safe. Thank goodness hes harmless when turned off.
                              • #30
                                Last one for today...
                                LEPROSY INFECTION
                                Weight; 100 kilos
                                Body Shape; Tetanus Booster
                                Speed; 18mph
                                TC; 0
                                GC; 2mm
                                Wheels; 4 inner, top sticking out. Wheel flaps are situated either side of the wheel to protect them.
                                Colour; A disgusting shade of lime green.
                                Weapons; A very large, very dangerous vertical drum, capable of reaching speeds of 4000rpm. The teeth on the drum are curved upwards so they can flip as well as damage and very sharp at the tip. There is a reason for this...
                                Srimech; The robot is invertable. Bars along the side and back prevent stranding. The wheel flaps, both on top and bottom, are set so the robot can still run inverted without getting stranded. Once upside down, the teeth of the drum gouge out robot parts.
                                Inspiration; Named after the disease which causes the skin to flake and fingers and toes to drop off...namely because the robot does something similar. The basic idea came from an episode of The Simpsons.
                                Strengths; Drum, control is pretty good
                                Weaknessess; Wheels may be vulnerable to axes
                                BIO
                                When youve got sharp teeth, sickeningly bright green paint and a name of a skin disease, battle invitations are pretty remote. So, hes loving life in the Robot Wars arena where he can make others sick. Leprosy Infections drum is killer! And when hes upside down, those teeth start gouging out his prey. Grrr...
                                The rest later.
