So I'll throw my hat in if Martijn's willing to take on another!
Parasite
Shape: Parasite-shaped, like in the picture :V
Colour: black and grey with red/yellow decals
Weight: ~100 kg
Armour:
-5 mm lexan on tops and bottoms of the wheel motor housings.
-7 mm titanium on the side edges and on the upper side of the rear wedge.
-5 mm aluminum on the bottom of the rear wedge. Internal components are held with 2024 aluminum scaffolding
-7mm thick hardox 500 tube frame keeps the bot solid and the weapon steady.
Drive: 2x S28-300 Magmotor
Power: 24 volt NiMH Battlepacks
Motivation: 4x foam polyurethane tires with rubber treads
Top Speed: 10 mph
Ground Clearance:
-Weapon clearance - 0.25-3.0 cm, depending on how high I set the blade for the match
-wheel pod clearance - 4 cm,
-weapon motor housing clearance - 0.2 cm
Turning Circle: 0
Dimensions: 141.224 cm length / 109.347 cm width / 18.15 cm height
Weaponry: 15 kg single bar at ~2500 rpm, ~60 kj
http://www.cloudelectric.com/product_p/mo-es-80a.htm
The weapon motor is a D&D Motor Systems MO-ES-80A Series Wound Single Shaft Motor
20 HP peak, 2.8 HP continuous, 3625 RPM
17 kg weight
36 Volt, 110 Amps
Notes: Uh... won stuff a long time ago. Who knows what on earth it was at this point.
Parasite
Weight: ~100 kg
Armour:
Top Speed: 10 mph
Ground Clearance:
Turning Circle: 0
17 kg weight
36 Volt, 110 Amps
