The Norman Sheppard Tribute Tournament
    Hey hey hey, where am I?
    1. Wedginator rEVILution
    2. Denial
    3. Darth Dread
    4. Ryujin
    5. Killobite Recharged
    6. Super Gore GTI
    Stats found at link at bottom of page, just click on heavyweights.
    Team Gore
    http://www.geocities.com/kodybluz/kodybluz2http://www.geocities.com/kodybluz/kodybluz2
      Soz, Kody, but one of those bots will have to go. Dave said at least one real robot per person, remember?
      *holds up Cmon, the Chaos! banner*
        All righty then Ill erase Ryujin and take Storm 2
        Team Gore
          slammer 5, achilles i have to enter, in addition to that archangel of the abyss, tengu 6, odyseus 2 and hector
            Chaos in the garage
            1 - Steve - Full
            2 - Richard - Full
            3 - Aaron/Tom - Awaiting bots
            4 - Andy - Awaiting bots
            5 - Matt F - Awaiting stats
            6 - Alex - Awaiting bots
            7 - Martyn - Awaiting stats
            8 - Matt R - Awaiting stats
            9 - Dave - Awaiting 2 more bots (I do have stats)
            10 - Chris - full
            11 - Kody - full
            12 - *Scott*
              oops noticed bout the real bot; take out tengu and put in supernova assuming nobodies already got it
                Thanks for the spot mate
                1. Razer
                2. Stratos-Fear
                SHAPE- A sort of 4Wheel Drive Wheely Big Cheese.
                COLOUR- Stealthy Black and Grey
                WEIGHT- 100kg
                DIMENSIONS- (L) With Flipper: 155cm, Without: 62cm (W) With flipper: 124cm, Without: 26cm each wheelpod. (H) 26cm
                SPEED- 15mph, high acceleration
                TURNING CIRCLE- 0
                GROUND CLEARANCE- Dead zero at front, rising to about 1-2cm at rear.
                ARMOUR- 4-7mm RSP-707 T6, Dave found this, it has the same density as aluminium but is almost as strong as titanium.
                WHEELS- 4, 4wd
                DRIVE- 2 24v LEM130€™s, geared for good speed and acceleration, powered by 3 x 24v 3Ah NiCad battlepacks.
                WEAPON 1- 130cm pneumatic flipper. This thing is powered by THREE 420mm x 80mm full pressure rams, running off three nitrogen tanks, with one extra as a buffer. It has a travel of 115 degrees. This should comfortably launch another heavyweight far into the air, better than WBC due to the increased power and length of the flipper. 3000psi Nitrogen, or 1000psi CO2 powered.
                SRIMECH - Axlebot, therefore it€™s invertible and can€™t be flipped.
                SKIRTS- None
                NOTES- Could probably flip about a tonne, and launch a heavyweight far, far into the air. Possibly the first 4 wheeled axle bot? Due to the shock, can probably kill another heavyweight in one or two flips. Overflip is now redundant because the flipper flops over due to the hollow axle connecting the two drive boxes. The flipper rides the ground, and due to the speed and low, low angle can easily breach any skirts.
                SUMMARY- Prepare to be launched into the stratos-fear!
                STRENGTHS- THAT flipper, acceleration and speed.
                WEAKNESSES- Armour is sacrificed a bit for extra power.
                3. Scottishly Fictional
                SHAPE- Modified Storm 2 shape, with a concave front.
                DIMENSIONS (LWH)- 75cm x 72cm x 16cm
                COLOUR- Scottish flags all over
                WEIGHT- 100 kg
                SPEED- 20mph
                TURNING CIRCLE- 0
                GROUND CLEARANCE- 0 at front, 5mm elsewhere
                ARMOUR- 6-12mm titanium
                WHEELS- 6, sellotape
                POWER- 2 x LEM130s at 36v, 4 x 3Ah Battlepacks
                WEAPON 1- Ramming spikes
                WEAPON 2- Small 5kg disc in the scoop, in a little indent. This is powered by an S28-150 Magmotor at 24v, since 36v fries it. Interchangeable with a 20mm titanium anti-spinner scoop without an indent for a drum, which also has a rear mace on a chain for some FBS action, baby, yeah!
                SRIMECH - Invertible
                SKIRTS- No
                NOTES- The weapon bay could be interchangeable if I€™m sufficiently bored enough to create new weapons.
                SUMMARY- Storm 2 with a proper, reasonably damaging weapon
                STRENGTHS- Speed, ramming, active weapon
                WEAKNESSES- Lack of skirts could leave sides open to agile flippers.
                4. Hefty Kick in the Balls
                SHAPE- Reminds of Cerberus in S3 or 4, I think. Tapered rear with front scoops.
                COLOUR- Grey, with Scottish flag scoops.
                WEIGHT- 100kg
                LENGTH- (L) 78 cm without disc, 151cm including skirts and wheel pods, (W) 105cm without, (H) 23cm without disc, 76cm with disc.
                SPEED- 15mph
                TURNING CIRCLE- 0
                GROUND CLEARANCE- 0 at front and skirts, 1cm everywhere else.
                ARMOUR- 5mm titanium, 12mm titanium front
                WHEELS- 2, interior wheels.
                DRIVE- 2 x 36v Mag S28-400s
                POWER- 4 x 36v Battlepacks
                WEAPON 1- 75cm vertical disc, powered by two LEM130s at 36v, which spins at 2000rpm. Instant spin-up time.
                WEAPON 2- Like you€™ll get past the first.
                SRIMECH - None, though my driving, the skirts and the will ensure it doesn€™t get flipped. Actually it could possibly do an IG-88 due to the speed of the disc and the short length of the body.
                SKIRTS- Side skirts, hinged.
                NOTES- Should easily destroy a lot of bots and the scoops can both aid get under a lot of flippers and fend off other robots€™ weapons
                SUMMARY- Destructive, indiscreet and designed to give the other bot a hefty kick in the balls!
                STRENGTHS- Weapon, stylishness, and scoops
                WEAKNESSES- Armour kinda sacrificed for extra weapon power.
                5. Lunch Box
                SHAPE- Sortof sculpted wedge
                COLOUR- Grey, with Scottish flag flipper
                WEIGHT- ~100 kg
                SPEED- 15mph
                TURNING CIRCLE- Absolute 0
                GROUND CLEARANCE- 0-5mm
                WHEELS- 4, inside
                POWER- 2 x Mag S28-400€™s, driven by a worm gear reduction, then a chain, at 36v
                WEAPON 1- Full Pressure front hinged flipper, powered by two big rams and two CO2 tanks. Going for the OOTAs baby, yeah
                WEAPON 2- Secondary rear scoop
                SRIMECH - But of course :wink:
                SKIRTS- None, for manoeuvrability
                NOTES- Inspired by Launch Pad, in both name and weapon depts.
                SUMMARY- A mobile launching pad, going for OOTAs, front hinged style
                STRENGTHS- Strong flipper, backed up by decent drive.
                WEAKNESSES- Short fights are probable.
                6. Glasgow Kiss
                SHAPE- Weirdly shaped, see picture.
                DIMENSIONS (LWH)- 86cm x 87cm x 22cm
                COLOUR- Groovy tie dye effect, dude! Like someone€™s been painting the sports centre€¦
                WEIGHT- 100kg
                SPEED- 15mph
                TURNING CIRCLE- 0
                GROUND CLEARANCE- 0 at front, 1cm elsewhere.
                ARMOUR- 5mm titanium. I can€™t weight check this, since Rhino doesn€™t like calculating the area of the body
                WHEELS- 4, sellotape type
                POWER- 2 x Mag S28-400€™s powered by 24v of 9Ah Nicads.
                WEAPON 1- Double headed axe, powered by two pneumatic cylinders at 1000psi CO2 on a rack an pinion system
                WEAPON 2-
                SRIMECH - Of course, with the axe.
                SKIRTS- None, due to curved sides.
                NOTES- Each axe-head is different.
                SUMMARY- A spiritual replacement of Axe Murderer.
                STRENGTHS- That axe.
                WEAKNESSES- Could be flipped by an agile flipper.
                • #23
                  Team Aussie Entrants
                  Team SpunOut Robots are:
                  Ze Newie
                  Automatic SCHMUCK
                  Generator
                  Team Disctructive Technologies Robots are:
                  Rogue
                  Intensity
                  (TBA Flipper)
                  Stats and stuff up tonight when I update our website.
                  • #24
                    Sorry, edit the above for obvious reasons:
                    Team SpunOut Robots:
                    Automatic Schmuck
                    Ze Newie
                    Team Disctructive Technologies Robots (2 from these 3):
                    Rogue
                    Intensity
                    (TBA Flipper)
                    Team Aussie Bots:
                    Generator (n00b)
                    Real Robot:
                    Razer.
                    • #25
                      My stats are found In Fowler Fic Wars 3...please take note of the changes below, and I am still waiting to find out what a suitable weight for LIs drum.
                      Axe-O-Lotl will be up soon.
                      • #26
                        1.Disco 5
                        2.The deer
                        3.Call out hook
                        4. Panicking
                        5.Take me out (no fights)
                        6.Gravity (newest version)
                        Shape: Low Wedge with small rear wedge
                        Motivation: it now uses four storm 2 style Vulcalon wheels
                        Speed: 12.5 Mph
                        Weight: 100kg
                        Height: 300mm to top of body, 600mm to the top of the disc
                        Length: 1300mm
                        Width: 600mm
                        Weapon: 500mm Vert. flywheel @ 3000rpm. Has a 4.00 second spin up time due to the C40-500 Magmotor on 36v with a 2:1 twin tension cog belt reduction. The flywheel produces 31.5Kj€™s at maximum RPM but is lethal at around 1 second. The second weapon is also the srimech, this weapon is a low pressure pneumatic flipper running on 10Bar (145psi) running into a single 80mm bore ram. This produces 509kg at the ram and is then transferred into the flipper with a leverage point ratio of 1:1. This is a forward facing flipper like FireStorm and will have no problem toppling the heaviest of robots.
                        Chassis: 4mm Grade 5 Titanium monocoque with extra 5mm Titanium ribs to give it more rigidity.
                        Drive: 2 x S28-400 Magmotors @ 36v with a 10:1 Mod 2 spur gear reduction connected to two Kart Tyres.
                        Batteries: 90 x 3000mAh NiCD cells producing 36v @ 9amp
                        Color- the robot and skirts and flipper are blue and the disc is yellow
                        Clearance- it has 0mm at the front due to the wedge it has 0mm at the sides due to skirts its 6mm with out it also has a 0mm at the rear due to the small wedge which is there to replace the problem of the skirt being flipped into the disc. The skirts are NOT hinged and held down by torsion-springs so they shouldn€™t spring up and the rear one shouldn€™t go up into the disc
                        Notes- The flywheel is at the back off the robot it goes over the back of the wedge so if I can get a robot up the wedge far enough it will be hit by the disc. The skirts stop the robot landing on its side.
                        Achievements- as disco, 3rd seed in ajwars and undethed challenge belt holder in ajwars extreme 1-4 ajwars 3 8th seed, as disco 4, semi finalist of the lord of the ring tourney, WINNER OF THE LORD OF THE RING TOURNEY
                        NAME- The deer (was crusher chaos)
                        SHAPE- Invertible box
                        COLOR- the robot and claws are a dark green color
                        WEIGHT- 100kg
                        DIMENSIONS- 1m x 80cm x 25cm
                        SPEED- 15mph
                        TURNING CIRCLE- 0mm
                        GROUND CLEARANCE- It has 6mm at the front due to the claws and has 0mm at the sides and rear without skirts 6mm. The skirts also work both ways up.
                        ARMOUR- 3.6mm hardox
                        MOVEMENT- 4 inner wheels that make the robot invertible
                        POWER- 2 x S28 Magmotors on 24v.
                        WEAPONS- it has a front pair of horizontal hydraulic crushing claws set up like deers antlers like you fine in extreme destruction. The claws have 3.5 tones of crushing force on the front tips of the claws at the middle is 6tones and right at the back it has 8 tones of crush. The claws are powered by hydraulics through a 120mm bore rams at 3000psi
                        NOTES- invertible, wide base means I wont topple while the deer is crushing
                        STRENGTHS- Very powerful weapon
                        WEAKNESSES- it could be turned into venison
                        NAME- Call out hook (thanks to Matty. H for help with the weapon description)
                        SHAPE- low box wedge (like storm 2 but not invertible)
                        COLOUR- white
                        WEIGHT- 100kg
                        SPEED- 23mph
                        TURNING CIRCLE- 0mm
                        GROUND CLEARANCE- 0mm at front wedge, 0mm at sides due to skirts 6mm with out 6mm at rear, varies under weapons
                        ARMOUR- 4mm hardox
                        WHEELS- 6 inner Vulcalon wheels
                        POWER- 2 x S28-400€™s Magmotors on 24v.
                        WEAPONS- Weapon- On the top of the machine, there is a 360-degree rotating turret, on which can be mounted 2 weapons. The first one is a large CO2 powered lifting arm, running off a 80mm ram at a pressure of 750psi. It has a hook shaped arm on the end, which is designed to pull up and puncture wheels, whilst lifting at the same time, and also to enable it to penetrate skirts. This ought to lift around 268kg around 40cm into the air at maximum. The other weapon that can be chosen is a double-headed horizontal axe shaped like that of Terrorhurtz, which will spin around on the turret, enabling him to do both damage by spinning and hammering. This should be enough to cut thin titanium, and dent the thicker sheets. The turret is powered by a LEM 130 geared at 4:3 giving good speed it spins at around 2000rpm and reaches it in around 3-4seconds
                        SRIMECH- the lifting arm which can self right from any position due to the turret
                        STRENGTHS- good weapons, good pushing power
                        WEAKNESSES- if the arm is spinning round slowly it may topple
                        Name- Panicking (previously panic 3 GTI 2)
                        SHAPE- Low invertible box
                        COLOUR- Yellow except for the lifting forks which are black
                        WEIGHT- 98kg
                        DIMENSIONS- 65cm x 60cm x 15cm (Length x Width x Height)
                        SPEED- 23mph
                        TURNING CIRCLE- 0 mm
                        GROUND CLEARANCE- 0 mm at front due to forks, 0 mm at sides and rear due to skirts 5 mm with out, the skirts are hinged so flop over when the robot is flipped
                        ARMOUR- 12mm polycarbonate
                        MOVEMENT- panic now uses 6 Vulcalon wheels to give extra pushing power
                        POWER- 2 x LEM130€™s on 36 volts
                        WEAPONS- on the front the robot has a pair of invertible lifting forks, the forks are like those on panic attack, the forks are powered by 2 linear actuators
                        STRENGTHS- Low ground clearance, reliable weapon
                        WEAKNESSES- previously lost to spinners
                        Record- 17-9
                        Name- Take me out (thanks to Dave for naming the robot for me)
                        SHAPE- Wedge
                        COLOUR- Dark grey
                        WEIGHT- 100kg
                        DIMENSIONS- Height: 20cm, Length: 80cm, Width: 65cm
                        SPEED- around 18mph
                        TURNING CIRCLE- 0mm
                        GROUND CLEARANCE- 0mm at the front due to wedge extender, 5mm at sides and rear
                        ARMOUR- 4mm Aluminium Boron Carbite
                        MOVEMENT- 4 inner vulcalon wheels, it uses a skid steer system like tornado
                        DRIVE- 2 LEM 130€™S on 36 volts
                        BATTERIES- custom 3300mAh NiCad Cell 36v BotPack
                        WEAPONS- The robot has a 1000psi nitrogen flipper on a 80mm bore on a 100-stroke ram which should make around 3.5 tones at the ram (if I am incorrect please correct me) the nitrogen is stored in 2, 2.2kg canisters, the robot has around 25 flips in a fight, the flipper is on high pressure
                        STRENGTHS- Powerful weapon, good drive
                        WEAKNESSES- limited supply for the weapon
                        • #27
                          Aaron+Tom - Razer has already been taken by Scott.
                          I have been thinking to up the entries to 16 people to allow Matt M and Tom B to enter, because I am not in a rush to do this, I will get the list of entries up later I hope.
                          • #28
                            Scott -
                            Which of your vapours is a newbie?
                            Kody -
                            Storm 2 has been taken by Richard.
                            Can the people entered please check http://farr.proboards21.com/index.cgi?board=NSTTStatshttp://farr.proboards21.com/index.cgi?board=NSTTStats to see if I have the right stats, ta
                            • #29
                              All right Ive got Mute
                              Team Gore
                              • #30
                                The armour on Orka MK4 has changed. It is now 7mm titanium, not 6mm steel. And the first three bots have magmotors
