AJWars Christmas Rumble
Ohhh boy, am I gonna love this.
The weapon, as it sits at least 36cm off the ground, is already 23cm too high to hit me; even the bar at the back only goes up 24cm and as such is 10+cm too low to be contacted.
We also have almost identical pushing power; he has 4 S28-150 (the smaller ones that CANNOT be used in Heavyweights due to their tendency to blow up under such loads) MagMotors at 24V producing 9.6MPH; I have 4 S28-400s at 24V producing 15MPH. The loss in torque should make it match his while allowing me extra speed. My wheels are hugely wide as well.
The wedges are both to my knowledge as low as possible (his skirts, my wedges) and if his are 7mm, then well be on similar terms. My extra momentum may allow me to slip under, but even so if I cant, I wont go flying up his sides.
My main tactic is to annoy him as much as possible by taking my free cheapshots at his skirts, whichll eventually rip them off from shcok at the hinges and give me wide open spaces to chew. He cant go underneath me anywhere (neither can I on him), so it makes his weapon completely ineffective. The extra momentum I have mauy be the only thing allowing me to go under him; at 9.6MPH he cannot do the same.
Good luck, Matty. Unlucky that youve drawn a bot your weapon is completely and utterly ineffective against.
