Velociraptor's Fanfic Tournament - Series 6!
  • #91
    Velociraptors Fanfic Tournament - Series 6!
    Oh, OK, heres my final list
    My entries are
    Terrorhurtz (RW7, see http://www.robotcrusade.comwww.robotcrusade.com for pic & stats)
    Hassocks Hog 2 (RW7)
    Dantomkia (RW7)
    Infernal Contraption (RW7)
    Little Sister (BB4)
    Aces & Eight (BB5)
    Killer B (BB4)
    & for a bit of fun with this last entry, Bender (BB4). BTW, in the pic on http://www.robotcombat.comwww.robotcombat.com on the Nov2001 heavyweight robots report, in the pic of Bender, is the (how shall I describe it?) flappy thing a lifter?
    My entries for the side events are
    Football: Little Sister & I need a partner for this. Any takers?
    Challenge Belt: Hassocks Hog 2
    • #92
      It doesnt mention any lifter on Benders profile on battlebots.com, Tom, so I imagine its just a wedge. And your battle record last tournament is correct, but 2 of your wins came from Marabunta being a heat finalist, so your Vapourbots obviously arent that bad!
      • #93
        Infusion will be a little late. I have to draw it up to find out if it will fit in the weight limit.
        Will try to get the others in here tonight.
        • #94
          Sorry Tom, as much as Id have loved too, Ive already picked two robots that work together, so, Im sorry, I cant join you.
          Also, its great youre back.
          • #95
            Thanks guys, BTW, my other win came from (the recently demised) Octopush in Round 1 of its heat. When battleboard is posted, Ill make my tactics. Now on the football matter, is there anyone who would like to be my team-mate please?
            • #96
              I will, i will enter with panic 3 gti 2
              • #97
                Done!! OK, Martyn, Ill accept.
                • #98
                  Rich, Bender did have a lifter in BB 5.0, at the back to lift the rear end up to lower the disc at the front.
                  • #99
                    Yep, Matt, but the version of Bender Im using is from BB4.
                    • Velociraptors Fanfic Tournament - Series 6!
                      It had it in BB4 as well, when it fought Little Sister in Round 1.
                        Ladies and gents, the Doomsday Project is now complete! In a few moments, Andy J will post the stats (many thanks!), but first a little challenge for you:
                        The proper inspiration behind The Doomsday Project is not from an RW or BB source, but something more unusual. Whoever can discover the true origin of Doomsday will receive 300 of my Virtual Pounds and 2 million Brownie points. The stats will give away a clue or two to aid your quest :wink:
                        So here you all go...and HUGE thanks to Scott Anderson for helping with construction
                          NAME- The Doomsday Project (HW)
                          SHAPE- tall scooped front with a front Bigger Brother-style spatula, sloped sides and a steep wedged rear. Basically, think along the lines of La Machine or Tsunami with fixed skirts and youve got the jist of it
                          COLOUR- deep black with a gleaming red eye on either side of the main weapon
                          WEIGHT- 95.9kg. Weight check below
                          DIMENSIONS- about 95cm X 75cm X 40cm
                          SPEED- 15mph
                          TURNING CIRCLE- 0m
                          GROUND CLEARANCE- virtually 0mm at the front (due to the scoop and blade) and at the sides and rear (due to side skirts, 10mm underneath)
                          ARMOUR- 4mm monocoque Hardox all over, including the skirts
                          WHEELS- inside robot, 4 x custom aluminium wheels
                          POWER- uses 2 x LEM-130s running on 24v for the main drive motors and 4 x 36v Battlepacks for batteries
                          WEAPONS- The fun part. The key feature of the Doomsday Project is a large vertical disc sticking out of the scoop with holes drilled in to keep the weight down. Weighing about 20.4kg and composed of 4mm Hardox, the 50cm diameter flywheel has 2 teeth and is powered by a 48v Etek motor. It can reach top speeds of 3000rpm in approximately 4 seconds...and can produce round about 149kj. Ouch. Past cool, eh?
                          SRIMECH- Down the rear wedge and stretching a little bit onto the top of the bot is a Cassius-style CO2 arm. Powered by 2 x 2.2kg CO2 fire extinguisher tanks, the 145psi buffer tank (1.1kg) can last for around 30-35 flips, which should be more than enough for self-righting in your average fight. If things get really bad as well, the arm can be used to flip robots attacking from the rear, before swinging around and bringing the disc into play. The sloped sides also prevent the bot being beached.
                          NOTES- flies the Scotland flag. Also, written in red on the underbelly is Today, Knothole. Tomorrow, the world!
                          STRENGTHS- VERY powerful weapon thats damned hard to damage, tough construction, good traction, fast & effective srimech, tricky to get under, pretty good control
                          WEAKNESSES- so-so manoueverability
                          WEIGHT CHECK:
                          DISC:
                          Total Weight = 30.9kg
                          Total Weight with holes = around 20.4kg
                          Weight of Etek = around 10kg
                          TOTAL WEAPON WEIGHT = 30.4kg
                          MOTION:
                          Wheels = 1.5kg each, 6kg overall
                          Motors = 3kg each, 6kg overall
                          Batteries = 2.85kg each, 11.4kg overall
                          TOTAL MOTION WEIGHT = 23.4kg
                          ARMOUR:
                          TOTAL ARMOUR WEIGHT = around 37kg including side skirts
                          SRIMECH:
                          Canisters = 4kg
                          Ram = 1.1kg
                          TOTAL SRIMECH WEIGHT = 5.1kg
                          FINAL WEIGHT: 30.4kg (weapon) + 23.4kg (wheels & motors) + 37kg (armour) + 5.1kg (srimech)
                          = 95.9kg
                            Robotica?
                              Its not the original American RW, is it Steve (you compared it to La Machine, but apart from its shape, its not much like La Machine)?
                              Will this replace Chameleon in the football as well?
                              Entries to the Football are now closed, but any people yet to enter (Aaron, Scott and possibly Alex) can still enter the Challenge Belt.
                                This may sound daft, but is it Steve thats the Sherlock Holmes fan? Hound of the Baskerville?
