The Crash & Burn Tournament 5
    Re: The Crash & Burn Tournament 5
    Yeah, that'd be fine thanks.
      Presenting... Team Bloodmage AKA Team Legion's bots!
      HW
      Dranzer Spiral (Stats to come soon) No bonus points for those who recognize the name :wink:
      Druid 3.0.
      Weight: 100kg
      Shape: Mortis in its Battlebots, season 2 guise, for those who dont know what it looked like, think Series 4 but with protective/anti wedge plates on the sides
      Colour: Black at the front, and gold at the back.
      Dimensions: 100cm x 80cm x 30cm
      Drive: 4x 24v S28-400 Magmotors, powered by 5x 3000mAh NiCad Battlepacks
      Locomotion: Mortis-style titanium tank tracks.
      Armour: 6mm hardox
      Speed: 18mph
      Ground Clearance: 0mm at front and sides, 5mm at the rear.
      Turning Circle: 0m
      Weapon: The weapon is a full-pressure Co2 flipper running off of a fire extinguisher, using 2 70mm bore 90mm stroke rams. the flipper is not only the front wedge, but also the top of the robot.
      It should flip about 750kg half a meter into the air.
      Srimech: Flipper
      Strengths: decent flipper, good traction and good armour all round
      Weaknesses: Inexperienced, weak at the rear
      Bio: Druid is dusted down and improved and is back once more
      Win/Loss Ratio: N/A
      Pyrrha
      Weight: 80-100kg, depending on the setup used.
      Shape: The robot without any setup on it is shaped like Tornado, back when they didn't have the interchangeable weapons.
      Colour: White with a blue and gold trim on the edges, and a picture of Pyrrha on the top
      Dimensions: 85cm x 75cm x 25cm
      Drive: 4x S28-400 Magmotors, powered by 3x 25.9v 5000mAh LiPo battery packs.
      Locomotion: 4 Goodyear go-kart wheels.
      Armour: 4mm titanium
      Speed: 15mph
      Ground Clearance: 0mm at sides and back due to skirts. 5mm without skirts. The front ground clearance varies with the setups, but unless otherwise noted is 5mm.
      Turning Circle: 0m
      Weapon: 2 different interchangeable setups.
      1: A set of Panic Attack-style lifting forks, powered by a 50:1 reduced 25.9v S28-400 Magmotor. It can lift 250kg. 0mm ground clearance under the forks.
      2: A Behemoth-style lifting scoop, using a 75mm bore 100mm stroke ram and a 2kg Co2 tank running at 150psi. It can flip 400kg and lift 500kg. 0mm ground clearance at the front.
      Srimech: Invertible in all setups Setups 1 and 2 can self-right the robot.
      Strengths: More simplified and efficient than Sauron
      Weaknesses: It was designed by me
      The Servant's Assistant
      Weight: 100kg
      Shape: Box with a wedge on the front ala Mortis
      Colour: Behemoth style yellow and black stripes
      Dimensions: 0.36m x 0.76m x 0.91m
      Locomotion: 6 internally mounted solid rubber wheels.
      Armour: 6mm thick Titanium all over. 3mm Polycarbonate baseplate
      Speed: Limited to 18 mph. Can reach 40mph.
      Turning Circle: Zilch
      Ground Clearance: 0mm at the front. 8mm elsewhere
      Weapons: A full-pressure rear-hinged Co2 flipper which starts off from the back of the robot and finishes at the bottom of the front wedge powered by a fire extinguisher using a 70mm bore 100mm stroke ram. It can flip 500kg.
      Srimech: The flipper of course. Hubs on the sides to stop it being stranded
      Strenghs: Fast despite speed cap. Good flipper
      Weakness: Not sure
      Bio: The Servant takes on a new shape and armour. Will do proud. Or will it flop. Only time will tell
      Win/Loss Ratio: 3/2
      AW
      Anticide (Realie)
      FW
      Archmage 1.1
      Weight: 13.6kg
      Shape: An invertible box with a wedge at the front. It looks like Pillow Torque, except for the lifter which partially sticks out the front.
      Colour: Apple green all over. Lifting arm has the words Don't give in scribed in gold.
      Dimensions: 47cm x 30cm x10cm
      Drive: 2 Astroflight C40 motors, using a 15:1 reduction, powered by a 19.2V 3700mAh NiMh Battlepack.
      Locomotion: 4 Pillow Torque-style wheels.
      Armour: 3mm titanium
      Speed: 10mph
      Ground Clearance: 0mm at front. 4mm elsewhere.
      Turning Circle: 0m
      Weapon: A 4-Bar electric lifter, powered by an Astroflight C90 motor. It can lift 75kg. The lifer now has 2 small spikes on it to stop opponents from getting away whilst it slams them around
      Srimech: Invertible, but the lifting arm can self-right it.
      Strengths: Fast. Reliable lifter.
      Weaknesses: Exposed wheels.
      Bio: Its exactly the same as the old one, but with a new paint job and modification for the lifter.
      Win/Loss Ratio: N/A
      LW
      The Prosecutor (The Judge's LW version, if not allowed then go for the LW Typhoon)
      MW
      Blaster
      Weight: 54KG
      Shape: A low, invertable box with a wedge on the front
      Colour: Silver with a golden lifter
      Armour: 5mm thick titanium all around
      Dimensions: L(75) W(50) H (30)
      Traction: 4WD urethane rubber wheels
      Motor's: 4 S28-400's powered by 36v NiCad battlepacks
      Speed: 10MPH
      Turning Circle: 0m
      Ground Clearance: 0mm at the front, 5mm elsewhere
      Weapons: It is a rambot as its main weapon, but the front wedge is actually also a lifter powered by a regular linac motor.
      Should be able to lift 75KG
      Scrimech: None, its invertable
      Strengths: Fast, reliable lifter
      Weakness: Not effective when inverted
      Notes: Inspired by FW robot L.A.S.E.R.
      Win/loss ratio: N/A
      SHW
      Metallic Doom
      Weight: 150kg
      Shape: A low box ala Drillzilla.
      Colour: The left half is red, while the right half is black.
      Dimensions: 107cm x 95cm x 17cm
      Drive: 2 36.3v LEM-130 motors powered by 11x A123 Battlepacks
      Locomotion: 2 Drillzilla-style shuffling feet, giving Metallic Doom good traction and pushing ability.
      Armour: 3.25mm hardox
      Speed: 20mph
      Ground Clearance: 0mm at the front, 5mm elsewhere.
      Turning Circle: 0m
      Weapon: A pair of horizontal crushing jaws, each which looks like the one used by Suicidal Tendencies, powered by a Vivoil Pump and LEM-130. Each jaw has a 2:1 ratio giving it 9 tonnes at the ram and 4.5 tonnes at the tip.
      Srimech: Invertible.
      Strengths: Nothing wrong overall.
      Weaknesses: Average everything.
      Bio: The 6th Team Blood Mages(a subsidiary of Death Robotics) creation is rather average overall...
      Win/Loss Ratio: 5/2
        Okay guys, Mark Elam wanted to join again. We've had our differences in the past but I'm allowing him access again. Since he is still currently banned from here, I'm allowing him to sign-up here instead:
        http://z10.invisionfree.com/Drowning_Ci ... st=0&#last
        So, he now has a reserved space. Also, Zarte Siempre wishes to enter. Realies have been doled out for him due to previous otherweight stats not being found.
        Other reservations will be found below. Josh and GF93 are from ARC and reserved spots there. If I'm incorrect, let me know post-haste and I'll correct the issue.
        Entrants
        Heavyweights
        1. [Nick Schuch entry]
        2. [Nick Schuch entry]
        3. [Nick Schuch entry]
        4. [Nick Schuch entry]
        5. Gabriel V (Joey McConnell)
        6. N³ (Joey McConnell)
        7. Eye of Ran II (Joey McConnell)
        8. Broken Wings (Joey McConnell) ^
        9. [Badnik96 entry]
        10. [Badnik96 entry]
        11. [Badnik96 entry]
        12. [Badnik96 entry]
        13. Dranzer Spiral (Lian Walsh) ^
        14. Druid 3.0 (Lian Walsh)
        15. Pyrrha (Lian Walsh)
        16. The Servant's Assistant (Lian Walsh)
        17. Achilles (Alex Holt)
        18. Black Panther (Alex Holt)
        19. Slammer VI (Alex Holt)
        20. Darkestar (Alex Holt)
        21. Hypertension 4 (Zarte Siempre)
        22. Delirium Tremors 1.42 (Zarte Siempre)
        23. BIACS By Popular Demand (Zarte Siempre)
        24. Assegain (Zarte Siempre)
        25. [Andrew Jackson entry]
        26. [Andrew Jackson entry]
        27. [Andrew Jackson entry]
        28. [Andrew Jackson entry]
        29. [Tracy Farber entry]
        30. [Tracy Farber entry]
        31. [Tracy Farber entry]
        32. [Tracy Farber entry]
        33. [Martijn Benschop entry]
        34. [Martijn Benschop entry]
        35. [Martijn Benschop entry]
        36. [Martijn Benschop entry]
        37. [Steven McGregor entry]
        38. [Steven McGregor entry]
        39. [Steven McGregor entry]
        40. [Steven McGregor entry]
        41. [Josh Noel entry]
        42. [Josh Noel entry]
        43. [Josh Noel entry]
        44. [Josh Noel entry]
        45. [GF93 entry]
        46. [GF93 entry]
        47. [GF93 entry]
        48. [GF93 entry]
        49. [Mark Elam entry]
        50. [Mark Elam entry]
        51. [Mark Elam entry]
        52. [Mark Elam entry]
        53-64. [empty]
        Antweights
        2. Jigsaw V (Joey McConnell)
        3. [Badnik96 entry]
        4. Anticide [realie] (Lian Walsh)
        5. Razzler [realie] (Alex Holt)
        6. Kwijebo [realie] (Zarte Siempre)
        8. [Tracy Farber entry]
        9. [Martijn Benschop entry]
        10. [Steven McGregor entry]
        11. [Josh Noel entry]
        12. [GF93 entry]
        13. [Mark Elam entry]
        14-16. [empty]
        Featherweights
        2. Redemption (Joey McConnell)
        3. [Badnik96 entry]
        4. Archmage 1.1 (Lian Walsh)
        5. Sith (Alex Holt)
        6. Aargh [realie] (Zarte Siempre)
        12. [GF93 entry]
        14-16. [empty]
        Lightweights
        2. Falling Down (Joey McConnell)
        3. [Badnik96 entry]
        4. The Prosecutor [realie] (Lian Walsh)
        5. Tiny Tengu (Alex Holt)
        6. Toe Crusher [realie] (Zarte Siempre)
        12. [GF93 entry]
        14-16. [empty]
        Middleweights
        2. Heroin (Joey McConnell)
        3. [Badnik96 entry]
        4. Blaster (Lian Walsh)
        5. Blizzard MW (Alex Holt)
        6. Deadblow [realie] (Zarte Siempre)
        12. [GF93 entry]
        14-16. [empty]
        Superheavyweights
        2. Drive (Joey McConnell)
        3. [Badnik96 entry]
        4. Metallic Doom (Lian Walsh)
        5. Red Knight (Alex Holt)
        6. Diesector [realie] (Zarte Siempre)
        12. [GF93 entry]
        14-16. [empty]
        ^ - bots that need complete stats
        So that's how things are panning out thus far. Need three more entries people.
          Okay, I am reserving this spot to post my entries. I am working on stats and working on getting the other entries in.
          Antweight -
          Featherweight - Skate
          Lightweight - Annoying Box Rush
          Middleweight - Stingray
          Heavyweight 1 - Parasite
          Heavyweight 2 - Exotherm Mk III
          Heavyweight 3 -
          Heavyweight 4 -
          Superheavyweight - Modest Discomfort Usherer
            If theres a space left il'l happily enter something, reserve for me SVP?
            Entry's soon
              No probs. And Lewis (since he can't post on FRA at the mo') has also reserved a spot. So...1 spot left!
                *looks around suspiciously, reserves spot*
                • #23
                  Well, I guess that's all spots taken then, yes?
                  I will hold reserved spots until further notice. People who have currently reserved spots, but without any entries are:
                  Andrew Jackson
                  Tracy Farber
                  Martijn Benschop
                  Steven McGregor
                  Lewis Matthews
                  Jordan Brown
                  Jack Orr
                  Josh Noel
                  Badnik96
                  GF93
                  Mark Elam
                  In other words, there's a LOT of people who need to get their bots in! Come on, peeps!
                  • #24
                    I can confirm that I will enter Under Pressure and Sheer Heart Attack, be it in their current forms or new incarnations.
                    Working on 2 new bots, but in a pinch when a deadline draws near I can call on Plan B and enter 4 of my excisting bots.
                    I don't expect to get 'round designing a whole otherweight fleet and will probably enter realies in most otherweight spots.
                    • #25
                      That's fine Marti.
                      I will be checking for BIIBI bots soon.
                      • #26
                        Other three bots ARE on the way. Don't worry.
                        • #27
                          Not worrying.
                          • #28
                            Perhaps you should. :twisted:
                            • #29
                              *is worried about what sort of antweight Nick might come up with *
                              A few addenda to my entries:
                              > Broken Wings' stats are up in Alex's Oddbots thread, and may be found by means of this link. Although it 'walks', it's not a proper walker and more of a shuffler; however it weighs 100kg and is made of fibreglass so this should probably not be an issue.
                              > For people who are unaware of what Jigsaw is, I have derived some stats for it:
                              Name: Jigsaw V mk. III
                              Weight: ~150g (it depends whose scales are being used, which battery pack is in it, and possibly on the phases of the moon)
                              Dimensions: 145mm x 100mm x 40mm
                              Drive: 2 x 50:1 Pololu 'HP' gearmotors run at 7.4v from a 2 cell 135mah lithium polymer battery pack, driving two 32mm wheels with quite grippy rubber tyres.
                              Speed: Very fast, but top speed of about 1m/s hardly ever used as I tend to drive it in a far more controlled manner
                              Ground clearance: 0 at the front due to both the wedge, and then a strip of acetate (not pictured) which runs along the ground at the front of the wedge for maximum lowness - up to 10mm elsewhere
                              Chassis: Folded 1mm polycarbonate
                              Armour: 0.9mm grade 2 titanium, with the top windows being protected and strengthened with 0.3mm carbon fibre sheet
                              Weapon: Forward hinged flipper driven from a Hitec HS82MG servo, run at full battery voltage, which can lift up to 500g
                              Srimech: The flipper (for the purposes of fanfic, this works every time - in real life I need to fiddle with the transmitter settings more...)
                              Notes: Antweight World Series 33 champion (somehow!) and has placed quite highly in every AWS since. No sides...
                              • #30
                                Heavyweights:
                                Shego
                                All Bar One
                                Munch
                                Frustum
                                Antweight: Black box vaguely statted in the link
                                The rest shall follow.
