FRA Royal Robot Rumble: 30 enter, 1 leaves
  • FRA Royal Robot Rumble: 30 enter, 1 leaves
    With the Addition of AJ, I need 6 more robots (3 more people). I am waiting on Ben, so really we only need 2 more. Come on, I wanna write this fight already!!
      STATS: Robo-Goat
      Shape: A wedge with angled sides
      Colour: Grey-White
      Speed: 20MPH
      Weight: 100KG
      Armour: 7MM Titanium
      Drive: 2 C40-300 Magmotors @ 48V
      Power: 5 NiCad Battlepacks @ 48V
      Locomotion: 2 Vulkalon coated wheels
      Ground Clearance: 0MM at front, 1-2MM on sides, 3MM at back
      Turning Circle: 0
      Dimensions: 110X40X25
      Weapons: 1) A angled front-hinged flipper powered by 3 100X80 rams
      2) 2 Linear actuated hardox goat horns to hold opponents in place
      Srimech: The flipper
      Strengths: Powerful flipper, Quick
      Weaknesses: Not good at pushing
      Robo-Hedgehog:
      Shape: Box
      Colour: Yellow and Black danger stripes
      Speed: 25MPH
      Weight: 110KG
      Armour: 5MM Titanium
      Drive: 4 LEM130s @ 36V
      Power: 8 NiCad Battlepacks @ 36V
      Locomotion: titanium tracks with a vulkalon coating
      Ground Clearance: 0MM at front, 4MM everywhere else
      Turning Circle: 0
      Dimensions: 120X70X20
      Weaponry: 1) A 15KG pointed sledgehammer, powered by pneumatics that comes down in 0.8 seconds
      The next three weapons are interchangeable
      2) A static Hardox wedge at the front
      3) 5 static Hardox forklift arms at the front
      4) A hinged Hardox scoop
      5) 8 rows of 5 curved teeth, the first 6 rows face the rear and collapse when you drive forward and become rigid and damage the tyres of other robots when you drive backwards, the last row faces the opposite way and are fixed in place
      Srimech: Axe, can run inverted if axe is taken off
      Strengths: powerful weapons, weapons synergy and is capable of 1 or 2 hit KOs
      Weaknesses: Thin armour, easily flipped and sides and rear are vunerable
        Ben: Robo goat seems...plausable, so Ill enter him, just curious about the goat horns. Do they go over the top of the robot or beside the flipper (IE: to hold the robot in place so you can flip him whenever, like close to the wall or the pit) ?
        Robo-Hedgehog is a little confusing. First, which set up will you be using for the rumble ? Second (and only answer if you plan to use it): can you elaborate on the curved teeth a bit ? Not sure I understand, and third: your batteries; 8 packs @ 36v = 2 sets of 4, 9v batteries. I am guessing the extra set for capacity benefits, but I dont think you can make a 9v pack from Nicads. You can get 9.6v Nicad packs. Up the operating voltage to 38.4v, then its based on real packs.
        Cheers
          deleted.
          (Message edited by leorcc on August 17, 200
            Oh yeah, aiall add 20kg extra of NiCads to both my bots
              Ben, would you mind me doing some CADs for you? (the robots you entered here for starters...)
                Thats great Martijn, I was hoping someone would offer
                  For the CAD Ben, I have the same questions Dave had. Can you describe the goat horns a bit better? Are they part of the flipper or part of the main body? And can you describe setup 5 of the Hedgehog please?
                    On Robo-Goat the horns are part of the body
                    on Robo-Hedghog I think that I have described setup 5 to the best of my knowledge
                      Is that 8 teeth high 5 teeth wide or 8 teeth wide and 5 teeth high? Teeth in vapourbots are mostly meant to describe those things you use on your disc, blocks of metal mostly. Are they curved blocks of metal? How do they face the rear (they are on the front of the robot right?) and if they face the rear than what does the rest face?
                        The way I have interpreted the weapon is...
                        the teeth are similar to Mutes barbs, in that they can trap opponents when they are trying to drive off the front wedge. However, according to Robo-Hedgehogs stats the shape is a box so I dont see how they would work...
                          and research told me goat horns face backwards, lol
                            no, they face forwards, they do not get in the way of the flipper, they are more for use when i face invertible or robots able to self-right, thay are used to grab and hold while I drive towards the pit and then pit them
                              http://i74.photobucket.com/albums/i268/_MadBull_/goat.jpghttp://i74.photobucket.com/albums/i2...Bull_/goat.jpg
                              Ben?
                                Nice CAD, reminds me of Seung Mina III
