x-mas crazy bots 2
  • x-mas crazy bots 2
    Hey all. It seems ive got 3 tournies to do now
    The christmas tourney is back with a BANG!!!!!
    This time we go into an annihalator format
    6 entrants. 1 heavyweight and 1 featherweight
    So lets get festively violent
    EDIT: Yay 600th post
    Re: x-mas crazy bots 2
    Sure you can manage 3? I found that I couldn't. :P Anyway I'm in.
    Heavyweight - Wedginator X
    Featherweight - Heretic
    Stats for both are on my forum.
      Count me in!
      Heavyweight: Gehenna
      Featherweight: OverDrive
        Ok 4 more spots guys
        Then the festivities can begin :twisted:
          yo :-)
          I.A.N (heavy) and pure evil (feather) for me please!
          http://www.youtube.com/watch?v=mRdMt_xINvM
            SOTAR and Innis. Acceptable?
              Accepted.
              2 more spots left!
                After recieving a PM, Mark has entered Bandwagon 3 and Starfighter
                1 spot left folks, who will grab it
                  Oh, what the heck....I'll enter Spring-BOK! and Bulldozer.
                  I believe Bulldozer's stats are in the PTT return tournament, or whatever it's called...I'll fish up Spring-BOK!'s when I can.
                    OK thanks Chris
                    Heres the draws of course
                    Wedginator X vs Gehenna vs I.A.N vs S.O.T.A.R vs Bandwagon 3 vs Spring-BOK
                    Tactics predictions and Santa's head on a pike please :P
                      I can't be arsed to find the stats for IAN or Bandwagon right now so I'll ignore them. :P Anyway, I doubt Gehenna can damage my 6mm G9 Titanium exterior armour that much so I'll primarily be going after that this match. SOTAR's powerful and invertible so avoid that myself any way I can...Spring-BOK! doesn't seem like much of a threat right now but avoid it anyway. I have decent and reliable enough drivetrain to do this.
                      Main tactics: Avoid Gehenna's font-higed fipper :P (I should be able to get under it anyway but still), try and wedge Gehenna and drive it straight into SOTAR, damaging the pair of them. Primarily focus on doing this the entire match, or otherwise just be a nuisance to Gehenna any way I can. Use the flipper only for self-righting. Only attack the others if they attack me, and once they're distracted go after Gehenna again.
                      Best of luck all.
                        It's too late or early or odd ball hour-y in the morning for me to think of a proper stratagy, or to find and read up on the other bots I'm up against, so I will run thusly:
                        Be a jerk. Attack everything that could possibly look at SOTAR funny (if robots could be said to look.). Try to not be so agressive though that any other bot can turn around and half kill mine before I get a shot in. Take advantage of any opening wherein someone's weapon is compromised/half crippled/flipped over and can't self right right away for some reason, ect.
                        Hit and run tactics are fun.
                        Good luck, other people who probably have a better plan then I do.
                          half arsed tactics, brought to you by L'Oral, because your worth it
                          right, i would be more than willing to team up with anybody here should they want my help :P, im not really researching this one so im just assuming everyone is better than me :P IIRC bandwagon was easy pray back when mark was active, so il defo keep an eye on that, might be able to get in a quick attack in with my flipper, same ol' hit n' run tactics basicly :P
                          Jack
                            OK due to limited time, this will still happen, except it will be a massive free for all
                            On that note, LET THE WARS BEGIN!!!!!!
                            Gehenna vs Wedginator X vs Bandwagon 3 vs SOTAR vs Spring BOK vs IAN
                            OK 3....2....1 ACTIVATE
                            Bandwagon starts us off by charging IAN towards the OOTA zone and flips, but IAN stays in and self rights, now IAN
                            tries to come back into this fight, flipping Spring-BOK over, Wedginator X Gets under Gehenna and drives into a fully
                            spinning SOTAR, the impact has flung Gehenna across the arena and SOTAR's disc has stopped working, for the moment
                            anyways, Gehenna comes back in on IAN, flipping him over as Spring-BOK flips Gehenna over as the pit descends, now
                            Wedginator X gets under Gehenna and rams it into the pit, oh dear AJ is out, meanwhile, SOTAR is still having trouble
                            spinning up as Bandwagon 3 charges in and smashes it against the wall, now the blades have stopped working entirely
                            Spring-BOK comes in and flips SOTAR out of the arena, Tracy is now eliminated as IAN gets round the side of Spring-BOK
                            and flips it over, IAN now tries to get him in the pit but Spring-BOK self rights and gets away, Bandwagon gets to the
                            side of Wedginator X and flips it over, Wedginator self rights and charges Bandwagon down and flips it over into the side
                            of the arena and pins him down. Spring-BOK now rams IAN in the corner with the pulverizer pounding away on him, IAN
                            is in a sticky situation here as Wedginator backs off Bandwagon who self rights and flips Spring-BOK up and over, this is
                            turning out to be a great fight as Wedginator rams Spring-BOK down the pit, 3 left as IAN flips itself back over and gets
                            under Bandwagon 3 and flips it over, but Wedginator comes in, charges IAN to the OOTA zone and flips, OOOH, that was
                            close as IAN just survives, but Bandwagon 3 comes in and miss-times his flip and luanches himself over, Wedginator now
                            takes advantage and flips it out, the champ has gone as IAN takes on Wedginator and flips him over, Wedginator flips
                            back over but IAN gets underneath and shoves Wedginator towards the pit, Wedginator is forcing back, Look at those
                            tyres screeching trying to get some traction, look at the marks left on the arena, IAN backs up and rams Wedginator
                            once again at full speed to the pit, but Wedginator drives over the top of IAN, and turns round, flips IAN and dumps him
                            in the pit. Kody is screaming with delight as he does a victory spin, Poor old IAN fought hard and well, but was undone
                            when Wedginator get behind him
                            Congrats Kody, enjoy the trohpy, but its not over yet.....
                              ITS THE FEATHERWEIGHTS!!! (Sorry for that, its cos i was listening to the mad noddy holder again)
                              Innis vs Heretic vs Bulldozer vs Starfighter vs Pure Evil vs Overdrive
                              3...2...1.. ACTIVATE
                              Overdrive gets us kicked off by slamming Starfighter around the arena, Bulldozer hits the release on the pit, Innis hits
                              Pure Evil, who is shot away, Heretic hits Bulldozer, Starfighter gets under bulldozer from the side and dumps it in the pit
                              Overdrive gets a few shots on the top by Pure Evil as Innis slams into Heretic, who is sent out of control and into the
                              pit, Overdrive shoves Starfighter around the arena, Starfighter flips itself over and Overdrive takes advantage and puts
                              it into the pit as Pure Evil puts a few shots in on Overdrive, it appears that Overdrive has stopped moving, Overdrive is
                              out, now Pure Evil must face the deadly Innis and rams it, Pure Evil's front is heavily damaged in the attack, but Innis'
                              has stopped completly, Pure Evil comes in and hammers the top a few times, it seems that Innis has also stopped movin
                              Pure Evil puts it down the pit.
                              Pure Evil is our champ, Jack takes the feathers by storm once more and picks up another trophy. So the bots that win
                              the awards are
                              Heavy Champ: Wedginator X
                              Heavy Runner up: IAN
                              Feather Champ: Pure EVIL
                              Feather Runner UP: Innis
                              Join us next year when i actually have time on my hands. CYA
