Re: The Vapourbot Grand Prix 2010
Ladies, gentlemen and imaginary remote-controlled death machines, I bid you welcome to the VAPOURBOT GRAND PRIX 2010!
Over the next few weeks, eight vapourbots from as far apart as Britain, Holland and Canada will be duking it out to win our coveted invisible trophy. This will be a contest not just of strength, but of strategy and endurance. Our eight competitors will duel each other simultaneously in ten different arenas all over the world. At the end of each fight, points will be awarded based on the position each robot finishes in. The robot with the most points by the end of the contest will be the crowned the Vapourbot Grand Prix champion of 2010.
The first battle venue will be announced momentarily, but before we do let's take a closer look at this year's competitors:
AXEON 4.0
OWNER: Andrew Jackson
HOME: Bourne, Lincolnshire
With previous versions of Axeon proving very successful in other tournaments, Andy will be hoping that Version 4.0 makes a big impact on the VGP in more ways than one. This latest incarnation is an angular box shape with a pair of front wedges and a powerful axe designed to bludgeon rather than puncture. The axe is made entirely of Hardox and runs on liquid carbon dioxide, allowing for plenty of powerful strikes per match. Axeon ranks high on defense with its wedged body and 8mm titanium/vanadium alloy monocoque shell (now there's a mouthful). Its pushing power is decent, but the front-mounted wheels could affect control and with so many bots running around at once, Axeon may risk spending its CO2 too rashly.
DELIRIUM TREMORS
OWNER: Matthew Fowler
HOME: Dadford
The best way I feel I can describe this entry is 'The Disc on steroids'. Delirium Tremors is essentially an enormous spinning drum with three wheels on each side mounted in a Y-shaped housing. Said wheels are each protected by narrow hinged skirting hanging down over the top of them. It might look a bit silly, but it could prove very effective. The 29kg drum is made of 10mm thick aluminium and spins at over 3000rpm. Touch those four rows of teeth at your peril. It's destructive, it's invertible, but its pushing power is weak and its wheels could well be in danger from another robot's blades.
EYE OF RAN II
OWNER: Joey McConnell
HOME: Pontefract, West Yorkshire
Here's an entry with its eye firmly on the prize. This unsual T-shaped machine has as its weapon of choice a frightening meter-long Hardox spinning blade with hooked claws. Mounted on the underbelly of its flat front, it weighs 30kg, spins at 2500rpm and can produce over 90kj of energy at its full speed. I hope everyone's brought extra tyres with them. Eye of Ran can run upside-down and is well protected with a mixture of polycarbonate and Hardox armouring and a titanium/vanadium chassis. It's a decent pusher too, but its unusual shape could hinder its control and its invertible frame leaves it wide open to a bird's eye attack.
FLICK OF THE WRIST
OWNER: Martijn Benschop
HOME: Enschede, The Netherlands
This is one of the toughest bots in vaporboteering today and it's easy to see why. Flick of the Wrist's design is simplistic in appearance, a basic invertible box with an angled rear and a pair of lifting spikes on the front, but what's important is the execution. The spikes are made of Hardox with diamond tips and the box itself runs on a grand total of six wheels at speeds of up to 22mph. Hardox + Diamond + (6 X 22) = OUCH. Flick of the Wrist makes for a great rammer with its top-notch traction and 7mm titanium shell, but the powerful wheels are vulnerable to axes and crushers, and its defensive weaponry may not be as effective in our more airtight arenas.
KILLOBITE SIGMA
OWNER: Kody Kunz
HOME: Toronto, Canada
This is the seventh member in the Killobite family, and clearly Kody's hoping it'll be the luckiest one. Like its last two incarnations, this high pentagonal wedge is armed with a horrible hardened steel crushing claw, but now it's even bigger and more powerful than ever. How powerful? How does 15 tonnes of pressure at the tip and 25 at the ram sound? In addition to the claw, Killobite has a pair of lifting forks powered by a lightweight linear actuators making for a very efficient weapons combo. Four wheel drive and speeds of 12mph make it strong and nimble, but that weapons combo is pretty slow and the 20mm ground clearance could be exploited by the others.
OOH! I'M DIZZY...
OWNER: Jack Orr
HOME: Richmond-Upon-Thames
Better known on the fighting circuit as O.I.D., 'dizzy' won't begin to describe how you'll feel after clashing with Jack's entry. This equilateral triangle's primary weapon is a vicious horizontal spinning disc mounted on the front. Weighing in at 20kg and constructed from 8mm Hardox, it can reach speeds of 2000rpm and tear a hole in most anything. O.I.D's shell is also made of Hardox, offering plenty of protection from its fellow spinners, and has a hinged wedge on the back for extra defense. It's invertible and highly manoueverable, though it's possible this might sacrifice its controlability and pushing power.
SLAMMER VI
OWNER: Alex Holt
HOME: Northants
Certainly the oldest robot here in terms of its heritage. This sixth incarnation of the Slammer dynasty remains much the same as its predecesors in its basic design - a squat axlebot with a front scoop, flipping arms on top and bottom, and a variety of interchangeable add-ons. Slammer VI features three such devices - a pair of crushing pincers, a vertical flywheel or a protective 'mask' to defend itself from powerful spinners. Such interchangability will prove very useful in a contest like this and its unique ability to self-flip makes it highly manoeverable. Its pushing power is comparatively weak however and those big wheels are a bit too exposed for my liking...
9.9 ON THE RICHTER SCALE
OWNER: Daniel Stickler
HOME: Merthyr Tydfil
Last, and by no means least, we have the most recently-built robot in the contest, having been constructed specially for this contest. Reminiscent of Tornado, 'Richter' is an invertable box with tapered sides and a 10kg rectanglar spinning bar (the eggbeater) mounted on the front. The blade runs at 2400rpm, but can be geared up to as high as 12,000rpm if need be! Pity the poor egg that gets beaten by this beast. It's a solidly-built bot with titanium/vanadium and polycarbonate armour and 15mph makes Richter a nimble machine. Its four wheels are exposed to aerial attacks, though, and its low 4mm ground clearance could prove troublesome later on.
Best get used to those bots, folks, because we'll be watching them beating the snot out of each other for a good long while. But now that we've met the bots, let's say hello to our first arena. The Vapourbot Grand Prix hath begun!
THE VAPOURBOT GRAND PRIX 2010
ROUND 1/10: THE BRITISH GRAND PRIX
ARENA: The Robot Wars UK Arena
We're going to kick things off with something nice and familiar to get our competitors settled down. The Robot Wars UK Arena has been the homeground of British robotic combat since 1998 and seen many alterations over the years. Our eight entries will be playing in the most recent incarnation of the warzone, the home of cutting discs, Flame Grills, the Drop Zone and of course the Pit of Oblivion. Our special thanks to the International Imaginary Planning Committee for expanding the arena to comfortably fit in all of our competitors.
The UK Arena is, of course, home to the House Robots, the superheavyweight monsters specifically created to make the life of any robot foolish enough to stray into their Corner Patrol Zones a living hell. Typically only two House Robots are allowed in the arena at one time these days, but today we're going to be doing something a little different. We're going to be throwing four House Robots into the ring to play with our competitors, and not just any four - the original four. Welcome back Shunt, Matilda, Dead Metal and Sergeant Bash!
Your arena plan badly drawn in Paint may be found below:
Everyone have a good hard think about your tactics and post them in ASAP. The sooner you all get something in, the sooner we can get started. Don't forget you'll all be fighting at once till only one remains, so you'll have to take all of your rivals into consideration, not just one or two.
Aaaand that's it. Good luck, all.
AXEON 4.0
DELIRIUM TREMORS
HOME: Dadford
EYE OF RAN II
FLICK OF THE WRIST
KILLOBITE SIGMA
OWNER: Kody Kunz
OOH! I'M DIZZY...
OWNER: Jack Orr
SLAMMER VI
OWNER: Alex Holt
HOME: Northants
(though virtualy :P)
so it's gonna be an all out slog for us, spin up from the start, get up to speed and start smashing things, id like to offer a team up with joey (seeing as we were both shoved down that bloody pit :P) until the others are destroyed/immobile/drowned? :P stake out the top corner of the arena but if that begins to look hostile and a: i cant fight my way out if i wait or b: somthing big is happening elsewhere that catches my eye/i could take advantage of then leg it :P
