Fanfic Wars - Series 1
    Re: Fanfic Wars - Series 1
    Typhoon 2, Darkestar, E Clawdius Unum, The Deer
      Typhoon 2 (1) vs. Obsidian vs. Darkestar vs. Intensity
      Robochicken Evo (32) vs. E Clawdius Unum vs. 0001 vs. The Deer
        This is of course, sheer speculation - I don't even know anything about four of these robots, and I'm a bit distracted at the minute to look them up.
          Ehhhhhh....
            Heat A
            Round 1
            The series starts with a bang. The realies take each other on immediately and Obsidian keeps getting pounded by Typhoon 2, taking hit after hit while trying to line up a proper shot. Intensity's spring-powered flipper doesn't do much against Darkestar's invertibility and after several blows from the vertical blade, Intensity's weaponry is inoperable. He does however manage to keep Darkestar's own weapon stalled a lot as he basically rams Darkestar around the arena. Meanwhile Obsidian is completely unable to get the axe into play and gets KO'd mid-way through the match. Typhoon 2 then goes off to attack the other two, deciding on Intensity. With its weaponry out Intensity can't flip over Typhoon 2 and takes more damage but manages to get Darkestar into the flame pit, angle grinders, and Sir Killalot. However it's just not enough and Darkestar inches past Intensity in the JD, Typhoon 2 having swept it.
            In a fight of clampers, the flipper-and-axe clad 32nd seed is plucked immediately by The Deer, who manages to pull off what TAN couldn't, and pit Robochicken. Then the clampers/crushers fight each other. Ultimately, 0001's polycarb armour is no match for the remaining robots and he gives out near the mid-way point.
            Round 2
            Typhoon 2 (1) vs. The Deer
            E Clawdius Unum vs. Darkestar
            SCOREBOARD
            AJ - 5
            Martijn - 5
            Lewis - 5
            Alex H - 5
            Joey - 4
            Dan - 4
            Jack - 4
            A Wafer Thin Mint - 4
            Tracy - 4
              Hmm...good start, although not the best for me from a points perspective :P
                • #23
                  I think The Deer and Darkestar will win this
                  • #24
                    • #25
                      Lets go.... Typhoon and Clawdius. I have a feeling I might regret voting against myself but nevermind.
                      • #26
                        Ehhh, Typhoon and Darkestar.
                        • #27
                          Round 2
                          The champ proved too quick and rather controlled, avoiding the claws the entire match and battering The Deer into submission before the full 5 minutes had gone.
                          Alex's fear of Darkestar's exposed tracks was unneeded. Clawdius did get a grip on them but only very late during the match, and was unable to snap it anyway. Clawdius itself took several blows from Darkestar's triangular flywheel and survived only to see Darkestar get the hefty JD.
                          Heat A Final
                          Typhoon 2 (1) vs. Darkestar
                          SCOREBOARD
                          Joey - 9
                          Tracy - 9
                          AJ - 8
                          Martijn - 8
                          Alex H - 8
                          Dan - 7
                          Lewis - 5
                          Jack - 4
                          • #28
                            • #29
                              Typhoon 2.
                              • #30
                                Typhoon 2 vs. Darkestar
