War of the Writers
    Re: War of the Writers
    @Martijn - Comments in Blue
    Originally posted by majinb
    Name - Back to Rock III
    Power - 2x LEM130s at 48v [Can you change this field to Drive? Power kinda puts it like your talking about batteries (Can you add some batteries too!). I would also be very wary of running the LEM130's on 48V without a form of current limiting on them.]
    Movement - 6 wheels, about 12 cm diameter [Put this information under drive ]
    Weaponry - A big rear-hinged lifting arm, basically the red part of the picture. It is powered by a single LEM130 at 36 V, which a €œpinion and rack€-mechanism. A pinion around the LEM€™s axle moves up a rack that€™s joint to the lifter about halfway its length. The fancy part is that this runs through a gearbox, with 2 gears. One gear is for powerful and controlled lifting and moves up the arm in about 2-3 seconds, another gear is for quick self-righting and moves up the arm in 1 second. [The drive LEM130's run on 48V and this one runs on 36V, does it use a separate battery pack to the drives?]
    The two plates at the bottom run almost parallel to the ground and are arranged in the way they are (split in the middle, see picture) for the secondary weapon to come into play, a Pussycat-style vertical diamond-edged sawblade, powered by a S28-150 Magmotor at 24 V spinning at 4000 rpm. The blade is part of the lifter and thereby damages the opponent€™s underbelly while lifting it. The sawblade slicing its way INTO (more or less) my opponent will enhance my grip on it and increase my control over my opponent, which is good. [This comment is more of a recommendation, I reckon ditch the little blade, it's too small to do any real damage (featherweights have bigger weapons) and it uses up some valuable weight that you could use for more armor. Also, the magmotor runs on 24V? Another separate battery?]
    Really want those battery stats, as it's a big decider on how this bot could perform and if it fits within the weight limit.
    @Jack - Comments in Blue
    Originally posted by team_orr
    power: 1x a123 36v pack [Bit more information, is this pack a single 10cells pack ie: 33V @ 2.3Amp or is there a few packs in parallel?]
    drive: 2x mag motors [What type of magmotors? what voltage? what sized wheels?]
    weapon: a forward hinged flipper consisting of the whole front pallel, can oota with ease, and can get about 30-40 flips running on 750psi with one 2kg tank and a 750g buffer tank, there are two 110mm rams [Are these 110mm bore rams? 110mm stroke? Have you run this through the flipper calculator to get those amount of flips?]
    locomotion: 2 solid steels wheels, with vulconized rubber tyres for maximum grip [Put this in the drive section]
    ground clearance: 0mm at the 1mm at the sides and 3mm at the back [A bit more ground clearance would be sensible unless you want to get stuck on the first bit of debri on the floor]
    Missing some important information in there, I can't really gauge how well this design will do without the information, and therefore can't write super awesome battles*!
    @Lian - Comments in Blue
    Originally posted by death robotics
    Nurse Pain
    Weight: 150kg [Too heavy, 100kg entries only please]
    Read the rules please
    * - super awesome battles may or may not be contained in this product...
      hi
      ye its 1 10cell pack
      they are mags s20-400's, on 36v, with 150mm wheels
      its 110 bore, and yes i know it does those amount flips because a: i have run it thru the calculator and b: its the same setp i use in my heavyweight
      okay then , the new ground clearacnce is 0mm at the front, 3mm at the sides and 5mm at the back
      that all?
      ta
      jack
        Intriguality
        Shape: Box. Yep, a plain ol' boring box.
        Colour: The main body is black...most of everything else is pretty much light green.
        Weight: ~100kg
        Drive: LEM130 Lynch motors run @ 36.3v, geared 9:1 for better control.
        Power: 5 packs of 11 M1 A123 Lithium-Ion cells run in parallel.
        Motivation: 4WD; features go-kart tires soaked in polyurethane, and custom-made CNC aluminium hubs.
        Speed: 12mph
        Armour: 6mm Ti/V framework surrounding a 3.2mm Hardox 400 monocoque. The front wedge plates (top and bottom) are 6mm Ti/V, while the sides of them are 4mm Ti/V. The axe shaft is bored through to lighten the load, and is made of Grade 5 titanium, while the axe head is sharpened Hardox. Hinges, inner bulkheads and bearings are 10mm aluminium.
        Ground Clearance: 0mm under the wedges, 15mm under the sides and rear, even inverted.
        Turning Circle: 0
        Dimensions in CM (LxWxH): 151.5 x 83 x 23 (length is 103cm without wedges)
        Weaponry: Pneumatic axe mechanism powered by a 150mm stroke 100mm bore double-acting ram, 2kg CO2 tank, and 4L buffer tank. Shots are fired at 900psi and it can fire about 20 times per fight, weakening at about 14 shots (only an estimate though)
        Srimech: Axe. Because the ram is double-acting, it can right Intriguality if the shaft is fired before being flipped.
        ROUGH WEIGHT CHECK
        ARMOUR
        Framework = ~16.1kg
        Monocoque = ~31.25kg
        Wedges and hinges = ~6kg
        TOTAL ARMOUR = ~52.35kg
        DRIVETRAIN
        Motors = 6.2kg
        Batteries = 3.85kg
        Wheels = ~6kg
        TOTAL DRIVETRAIN = ~16kg
        WEAPONRY
        Axe shaft = ~8kg
        Axe head = ~7kg
        Gears = ~500g
        Weapon power = ~6kg
        TOTAL WEAPONRY = ~21.5kg
        Other bits = ~10kg
        TOTAL WEIGHT = ~99.85kg or ~100kg
        I spent a while on the stats, so if you've got a beef with the stats, do spill please, I want them to be as good as they can be made.
          hi
          ye its 1 10cell pack [You'll need more then that, my featherweight MBX flattens a single 10cell pack in just over 3 minutes. I'd suggest 4 x 10 cell packs minimum]
          its 110 bore, and yes i know it does those amount flips because a: i have run it thru the calculator and b: its the same setp i use in my heavyweight [What stroke is the ram and is it a full pressure system?]
          that all?
          ta
          jack
            Urgh, should have mentioned in the stats that it's invertible. *facepalm* There go the 'perfect stats'. :P
              lol, sorry *facepalm* thats what i meant
              yeah...anyway up it to 4x 10cell packs svp
              EDIT: OOPS forgot the pneumatic system, its a full pressure system and the stroke is 65mm
                I gathered it was invertible since you provided a render
                • #23
                  Ah, all is well, then. It has the same ground clearance either way up, by the way.
                  • #24
                    Current places
                    1. N3 - Joey
                    2. Wedge Devolution - Steve
                    3. Gehenna - AJ
                    4. Intriguality - Kody
                    5.
                    6.
                    7.
                    8
                    Pendings Places
                    Back to Rock III - Martijn - Stat fix required
                    IAN - Jack - Need time to process stats
                    Equinox - Lewis - Need time to process stats
                    • #25
                      Builder: Leo van Miert
                      Robotname: Sideswipe
                      Weightclass: Heavy
                      Dimensions: 90cm x 125cm x30cm
                      Shape: T-frame-ish
                      Weight: 99kg total. Brushless and weapon 28kg, batteries 8kg, drive 16kg, esc's and electronics 5kg, Aluminium and bisalloy 42kg
                      Weapon: 12kg Spinning object, powered by a Plettenberg Predator 30/8 Brushless motor on 39.6V giving 6000rpm and 11kw
                      Batteries: 6 packs 12cells A123 39.6V 13.8Ah
                      Drive: 2x S28-400 Magmotors with TW TWM3 Gearbox
                      method of motivation: 10 flatless wheels
                      Top speed: 32km/hour
                      Ground Clearance: 10mm all round
                      Armour: Base 6 mm 7075-T6 aluminium, Top 5mm Bisalloy chromed steel
                      Srimech: the spinner bar knocks it back over
                      Strength: Wide wheels, less gyroscopic effect.
                      Weakness: vulnerable at the back.
                      Picture: http://www.youtube.com/watch?v=4rnClqCv0C8&fmt=18
                      • #26
                        Weightclass: Heavy
                        Shape: T-frame-ish
                        Sorry Leo, this little series is for those who have written a fanfiction tournament, unless you've written a tournament I've missed in my occasional sweep of these forums
                        • #27
                          Well, I haven't been around much recently, so lets get back into the swing of things by entering Achilles. It's not like I have anything *that* up to date, but it'll probably require less work than anything else to get it up to Aaron submission standards. Odd though, I could have sworn I had a bot which included more technical stats in my roster as I remember actually doign a weight breakdown for a change. Oh well.
                          http://alexjholt.com/achillesd.htm
                          • #28
                            No problem.
                            • #29
                              Hazzah the legend is back :P :wink:
                              Anywho i'd like to enter my newest creation
                              Druid 2.0
                              Weight: 100kg
                              Shape: Reptirron the 2nd (S6)
                              Colour: Black on the right-hand side. Gold on the left.
                              Dimensions: 82cm x 90cm x 60cm
                              Drive: 4x 24v S28-400 Magmotors, powered by 4x 3000mAh NiCad Battlepacks
                              Locomotion: 4 internally mounted Biohazrd-style wheels.
                              Armour: 3mm Hardox
                              Speed: 12mph
                              Ground Clearance: 0mm at front. 9mm elsewhere.
                              Turning Circle: 0m
                              Weapon: The weapon is a rear-hinged flipper, powered by 2 2kg Co2 tanks at 750psi via a 100mm bore 150mm stroke ram. It can lift 800kg, and can flip 500kg.
                              Srimech: The flipper can self-right it.
                              Strengths: Tough, decent flipper.
                              Weaknesses: Previous incarnation had a habit of going out of control.
                              Bio: A slower, but tougher incarnation of Druid.
                              Win/Loss Ratio: N/A
                              • #30
                                Little swamped with work and personal commitments lately, should be able to spend a night or two this week going over those entries in processing stage and start aiming to get this show on the road
