crazy bots 2.0.
  • #76
    Re: crazy bots 2.0.
    woo awsome fight man, short but sweet, i still think you can make them longer though!
    o.i.d vs compression:
    compression is a nice bot, but i recon if i hit him from the side he wont be able to defend, rack up points and mangle his armor, avoiding the jaws and barbed wedge, keep going till he dies...spin 2 win
    jack
    • #77
      Re: crazy bots 2.0.
      We return
      Gabriel V vs Axe To Fall
      3....2...1 ACTIVATE
      Gabriel races out of the traps on Axe To Fall, shoving it into the wall. Axe To Fall tries to hit
      Gabriel, but due to his shape he can't hit him. Gabriel now gets under Axe To Fall and flips it
      over. Axe To Fall tries to self right, but Gabriel is foiling almost every attempt to do so. Now
      Axe To Fall finally self rights. But Gabriel gets under him once more and pushes him into the
      flipper. Axe To Fall is now trapped on his side. But Axe To Fall starts firing the axe rapidly to
      try and get himself back on his wheels, and finally succeeds. Gabriel though has other ideas.
      Flipping Axe To Fall over once more. Axe To Fall self rights again and gets under Gabriel and
      props him up against the wall. But Axe To Fall doesn't seem to be bringing the axe in. I think
      the c02 has gone. Gabriel flips itself off the wall and self rights. But lands on right on the front
      of Axe To Fall. But the axe still aint coming down. Gabriel flips him over. It definatly looks like
      the c02 has gone 1 2 3 4 5 6 7 8 9 10. CEASE
      Next fight will be longer, i promise
      • #78
        Re: crazy bots 2.0.
        Im breathing life back into this forum
        Compression vs OID
        3 2 1 ACTIVATE
        Compression comes racing out of the traps to clamp OID. But OID moves quickly to the side and tries to hit a wheel.
        But just missed. Compression now gets round the back of OID and clamps him. Compression now takes OID to the
        pulverizer in the corner. BANG BANG BANG!!!!. The pulverizer pounds on the top OID for 15 seconds. Compression now
        backs off, letting OID have some breathing space, OID now gets round the back of Compression and hits the rear end so
        hard it rips off the back panel. Compression is now being extra careful. OID tries to continually get round the rear end of
        Compression. But Compression keeps his front facing OID. So OID charges Compression at full speed, ripping the hinged
        wedge off. Compression now dodges off to the side and clamps onto OID and pushes it towards the flipper and it flips
        OID into the air. Taking Compression with it, as it forgot to let go. They both land with a crash, but OID is still clamped
        from behind by Compression. Compression shoves OID into the wall so hard the disc stops working. Compression lets go.
        But is seems Compression can only go in circles and OID is moving very slowly. But still has enough power to push its
        nearly lifeless opponent towards the pit. OID has stopped moving completly and so has Compression the Refbot comes in
        to check them bot. Hes shakin his head, clueless about who to count out. He looks at Compression. No life whatsoever,
        now looking at OID. There is movement. But at about 0.25mph. The Refbot counts out Compression 1 2 3 4 5 6 7 8 9 10.
        CEASE.
        We go back to the pits to see that all of OID batteries and motors are dead and gone. They still have the weapon.
        Roboteers Joey,Kody,Martijn others and even his opponent Lewis pile in to help repair OID. Within 15 minutes they have
        repaired OID.
        So out heat final is OID vs Gabriel V
        • #79
          Re: crazy bots 2.0.
          O.I.D. vs. Gabriel V
          I'll remove the spikes for this fight as they'll probably just get in the way. My tactics will be to get under it at somewhere that isn't nasty and discy, and flip it over, down the pit, and/or out of the arena in some fashion.
          Best of luck Jack
          • #80
            Re: crazy bots 2.0.
            cool fight
            oid: erm, hmmmm lets see, i recon i should just keep hitting him with the disk, and then pit him :P but if i cant do that just keep hittin him and shove him 2wards housebots
            best of luck joey
            • #81
              Re: crazy bots 2.0.
              It's the heat final
              Gabriel vs OID
              3 2 1 ACTIVATE!!
              Gabriel charges OID from the start, a shower of sparks litter the arena, OID comes back strongly though, but Gabriel is
              just too fast for OID who flips it over. Gabriel now shoves OID towards the arena wall, Gabriel gets to the side of OID
              and flips him on his side, OID keeps on using the disc to get it off, but just keeps on ripping into the arena floor. OID has
              finally got himself down, but landed straight on Gabriel's flipper. Gabriel now charges OID to the OOTA and flips, OID hit
              the wall and landed back onto Gabriels flipper. Gabriel tries again but OID only ends up being propped up against the wall
              with no means of getting off. Gabriel reverses away but backed to far and is launched by the floor flipper, Gabriel flips
              back over and does a victory spin as poor old OID is counted out 1 2 3 4 5 6 7 8 9 10!!, Sir Killalot now picks up OID and
              parades it around the arena, and takes it, still in it's claw, to the pulverizer, which proceeds to bash the living hell out of
              it. Sir Killalot now dumps him in the pit. CEASE
              • #82
                Re: crazy bots 2.0.
                Along with this series. There will be a point system for Vapourboteer of the tournie
                1 point for winning in round 1
                2 points for winning in round 2
                3 points for winning in round 3
                4 points for winning in 1st round semi-finals
                5 points for winning in 2nd round semi-finals
                6 points for finishing 4th in the play-offs
                7 points for finishing 3rd in the play-offs
                8 points for 2nd place
                10 points for the champion
                So, the points so far
                Liam- 0
                Mark- 1
                joey- 6
                Jack- 4
                Kody- 6
                Martijn- 1
                AJ-0
                Leo- 3
                Jordan- 0
                Lewis- 0
                So it look's like Joey and Kody are top of the leaderboard. But for how long?
                Also their will be bonus points for the otherweights :P
                Next battle up in a sec :P
                • #83
                  Re: crazy bots 2.0.
                  Tactics for Illusion of Dread were on page 3, I believe. For convenience, they are of the kill Pickaxe because its circular skirt does f***-all variety :P
                  • #84
                    Re: crazy bots 2.0.
                    Heres our next battle.
                    Pickaxe vs Helix Vs Illusion of Dread
                    3 2 1 ACTIVATE
                    Pickaxe starts off by chasing Helix, slamming the axe when it gets the chance, Helix turns round and starts to slam the
                    top of Pickaxe. Pickaxe fights back, Helix slams it's axe into Pickaxe, now the axe head is stuck in Pickaxe's skirt. Helix
                    tries to shake himself free, Illusion of Dread now gets into the action and lifts up Pickaxe into the air. Helix gets his axe
                    head out of the skirt. The pit decends, Helix hits Pickaxe whilst Illusion of Dread holds him aloft, Pickaxe is firing its axe
                    to desperately get off. Illusion of Dread is now facing the pit, and is taking Pickaxe there, Pickaxe is firing is axe rapidly
                    to get off the arm, it's successful in doing so. But Helix begins to hit the underbelly and preventing Pickaxe from righting
                    itself, Pickaxe now gets back up and begins to run away. But Illusion of Dread chases him down and flips him over once
                    again. Helix now turns its attention to Illusion of Dread and begins to hammer away at the top, Illusion of Dread now lifts
                    up the arm and begins spinning up the bar, its now at full speed. Illusion of Dread now runs away and turns round and it
                    charges at Pickaxe, what a hit, Pickaxe is sent backwards with a shower of sparks, Pickaxe's c02 blew out cos of the hit
                    Helix gives chase to Pickaxe, hammering the top whilst catching up, Helix gets Pickaxe onto its wedge and pushes it into
                    the floor flipper, Pickaxe is sent flying into the arena wall and onto its side. Illusion of Dread spins round in celebration as
                    Helix does a Terrorhurtz style victory spin with its axe as poor old Pickaxe is counted out 1 2 3 4 5 6 7 8 9 10!!! As Helix
                    decides to push illusion of Dread into the pit for some fun
                    CEASE!
                    • #85
                      Re: crazy bots 2.0.
                      w00t...don't remember attacking Helix as part of my tactics, but then I don't remember the tactics for Helix, so :P good fight regardless
                      • #86
                        Re: crazy bots 2.0.
                        Next up we have.
                        Gehenna vs V for Vendetta vs Roadblock
                        3 2 1 ACTIVATE
                        Gehenna chases V for Vendetta and flips him over, V for Vendetta self rights and goes after Roadblock and begins its
                        brutal attack on Roadblock, causing damage, Gehenna now charges Roadblock and slams him against the wall. Now it
                        seems Gehenna is trying to prop up Roadblock but to now avail. V for Vendetta comes in and hits Roadblock, who is now
                        stuck on top of Gehenna. Gehenna now turns and charges towards the OOTA zone to flip out Roadblock. Roadblock is
                        stacked up againts the wall. But V for Vendetta has its own idea's and pounds Gehenna with its axe. Gehenna runs away
                        but V for Vendetta keeps following and hitting the top of it. V for Vendetta pushes Gehenna onto the floor flipper and is
                        flipped into the air and near the pit as V for Vendetta hits the top of Gehenna, it looks like gehenna is on one wheel, it
                        seems to me that V for Vendetta is trying to get rid of Gehenna before Roadblock is counted out. V for Vendetta now
                        drives up the front wedge of Gehenna who procceds to flip them over. V for Vendetta had its axe out so it might be a
                        bit difficult for it to self right. How stupid of me as it self rights and pushes Gehenna into the arena wall to pin him there
                        as poor old Roadblock is counted out, it never stood a chance 1 2 3 4 5 6 7 8 9 10!!! Whats this V for Vendetta is now
                        pushing Gehenna to the arena wall were Roadblock is. V for Vendetta now pushes Gehenna underneath Roadblock. And
                        Gehenna proceeds to flip them out. CEASE
                        2nd round draws
                        V for Vendetta vs Illusion of Dread
                        Helix vs Gehenna
                        • #87
                          Re: crazy bots 2.0.
                          Rely on the flipper mostly for offense, and the bar for defense. Get under and toss him over as many times as necessary. If he tries to axe the body, the spinning bar will rip the axe straight off!
                          Helix vs Gehenna
                          Seeing a win for Gehenna here via Mr. Pit.
                          nice work Lian
                          • #88
                            Re: crazy bots 2.0.
                            Thanks Kody
                            This is the series theme song
                            http://www.youtube.com/watch?v=c436AdCv_3I
                            • #89
                              Re: crazy bots 2.0.
                              We are back
                              The fixture list is changed so instead of Illusion of Dread vs V for Vendetta in the 1st of the 2nd round clashes. It will be
                              Gehenna and Helix instead
                              Gehenna vs Helix
                              3 2 1 activate
                              Gehenna gets us underway by hitting the pit release. Helix now starts moving towards Gehenna and slams the axe onto
                              the top of Gehenna, Gehenna now turns to get under Helix and flips him. Helix tries to self right but Gehenna foils the
                              attempt, Gehenna now shoves Helix who is sent skidding arcoss the arena floor still on its back though, as soon as it
                              stops skidding, Helix self rights. Helix now gets Gehenna back by landing numerous axe blows on the top of Gehenna, this
                              is a good performance by Helix who now shoves Gehenna onto the floow flipper and is flung through the air and lands on
                              it's back. Helix takes advantage of the situation and pushes Gehenna towards the pit. Gehenna flips himself back over as
                              he gets away just in time. Now Gehenna gets under Helix and rams him into the OOTA zone and Sir Killalot is waiting and
                              he plucks Helix into the air. Sir Killalot now takes Helix to the pulverizer and it pounds away at the top of Helix. Killalot
                              now puts Helix down, but Helix is moving round in circles as Gehenna comes in and flips it back towards the OOTA zone.
                              Now Helix has stopped completely. Has it?. Gehenna gives it a nudge, it's definatly stopped moving. But down comes the
                              axe, so they have still got the weaponry, but the drive has completely gone, the cant move. The Refbot comes in to
                              check, now begins the countdown 1 2 3 4 5 6 7 8 9 10!!! Helix is out as Killalot closes in on Helix, Helix still carries on
                              using the axe to defend itself and hits Killalot's chestplate, he wont be happy with that as Dead Metal grabs hold of the
                              winner known as Gehenna and begins whirring the saw up and ouch!!, sparks fly off Gehenna. Helix is still defending in
                              the corner, but Killalot finally picks them up into the air and takes them back to the pulverizer, its a honourable end for
                              Helix who fought so well in this battle, falls at the same hurdle as they did the 1st series. Now Killalot places Helix onto
                              the floor flipper and is flung through the air as Gehenna comes in and flips it onto its back. CEASE
                              A well fought battle. But it Gehenna emerges the victor of this battle and proceed to the heat final
                              • #90
                                Re: crazy bots 2.0.
                                Seriously? Were back? Damn i thought this show was cancelled a long time ago.
                                To make up for lost time, here we go
                                3...2...1..KILL!
                                Illusion of Dread comes flying out at V for Vendetta and gets underneath quite quickly. V for Vendetta slams its hammer
                                down on the lifting arm. It has no effect though and is flipped over by Illusion of Dread. Illusion of Dread lifts the arm up
                                and gets that disc up to speed. V for Vendetta self rights (Curse you lot, why are all the names so long?!) but it backs
                                too far by accident and reverses straight into Illusion of Dreads disc!. A shower of sparks litter the arena. It seems to
                                have slowed down the disc, but not by much as V for Vendetta swings around and and slams ints axe into the disc. Its
                                caused the Illusion of Dread to bounce around for a sec then. Illusion of Dread recovers and begins the game of cat and
                                mouse with V for Vendetta. V for Vendetta turns akwardly and gets pushed into the OOTA zone, where Shunt is waiting.
                                BANG! What a hit by Shunt, but V for Vendetta hits back with one of his own. Illusion of Dread comes in to spoil it and it
                                flips V for Vendetta onto his back with the axe extended. V for Vendetta tries to self right. but has stacked itself on the
                                wall and cannot get away. Meanwhile. Shunt's having a pop at Illusion of Dread. This is carnage out there now. Shunt's
                                front plow accidently knocks V for Vendetta away from the wall and back into the fray. The fan's look confused at that
                                but Illusion of Dread has been cornered by Shunt and Sir Killalot. Sir Killalot picks up Illusion of Dread with the claw and
                                begins to spin him around., and around and around. What great strength Sir Killalot has. He finally lets go. Watch him fly
                                as Illusion of Dread is flung across the arena. V for Vendetta comes back and delivers a hit to the arm again. Illusion of
                                Dread tips him over once more. Illusion of Dread now reverses into the pit release as V for Vendetta self rights. Who's
                                going into that pit, none of them as V for Vendetta is taken to the hammer in the corner of the arena to pound away. It
                                looks like V for Vendetta has stopped dead in it's tracks.... or wheels so to speak. Are they immobilized. Nope it is not as
                                V for Vendetta comes smashing back with the hammer again on Illusion of Dread, but now Illusion of Dread is fully under
                                V for Vendetta and charges toward the OOTA zone and flips!. V for Vendetta survives but the axe head is stuck on the
                                outside of the arena. V for Vendetta tries to self right again but cant do so. RefBot comes in to have a check. He takes
                                a look, and he begins the countdown. 1..2...3...4...5..6..7..8..9..10!. V for Vendetta goes out in very hard though match
                                . The house robots are closing in. But Illusion of Dread flips V for Vendetta out to spare them anymore punishment. CEASE!
                                Wow what a battle. Up next, the heat final between Gehenna and Illusion of Dread :P
