crazy bots 2.0.
  • #31
    Re: crazy bots 2.0.
    ...ah, I was thinking of one of Dave Lawrie's ants as that's the only one I know XD
    • #32
      Re: crazy bots 2.0.
      Lian, much like I did on ARC Im also gonna confirm here that Im fine with the otherweights you gave me, and thanks to Kody for pointing out I was in need of them
      • #33
        Re: crazy bots 2.0.
        Ok draws for the 1st 8 heats
        Apocalypse II vs Eternia vs Jinx
        Megaroll II vs Flirty Skirty vs orrion
        heat b
        Frustum vs Axe to Fall vs Compression
        Fissure vs oid vs Gabriel V
        heat c
        Helix vs pickaxe vs Illusion of Dread
        Gehenna vs V for Vendetta vs Road Block
        heat d
        Bandwagon 3 vs N³ vs razer
        Crushtacean vs Flick of the Wrist vs Comengetorix
        heat e
        Exotherm vs The Final Cut vs Mantis mk2
        ian vs Wedginator 9.0 vs Minesweeper 4
        heat f
        Loki vs Volde vs Scrap Daddy HW
        Panic Attack vs Sheer Heart Attack 2 vs Wedga Triton
        heat g
        LockJaw v3 vs Walkies vs Absolution
        The Clones That Weren't There vs crooked evo vs Eye of Ran II
        heat h
        Tazbot vs Holepunch 2.0 vs Maximum Genocide
        bigger brother vs Reptirron the 2nd vs Extreme Gyration
        Tactics. Predictions and who you think will win the heats so far :P
        • #34
          Re: crazy bots 2.0.
          Heat A
          I still question Apocalypse II's realism here, and if possible I'd like Liam to assuage my fears of its unrealism. Other than that, I shall attack it right away. My forks should get right underneath its front end, while I grapple'n'pit it. Avoid Eternia any way possible except if I'm in a dangerous position (then grapple'n'pit it instead :P)
          Megaroll II vs Flirty Skirty vs Orrion
          lol Flirty Skirty I think will skirt the issue and go home. :P
          Heat winner: Eternia I think.
          Heat B
          As good as Frustum is, its weight disadvantage I think may do it in. Hopefully it might pull a Chaos 2 and prove me wrong. :P
          Fissure vs O.I.D. vs Gabriel V
          Gabriel and Fissure are pretty tough machine, Jack's got his work cut out for him.
          Heat winner: Gabriel V
          Heat C
          Helix vs Pickaxe vs Illusion of Dread
          Circular skirts do not work as they cannot have a fully zero ground clearance, and if it did it wouldn't be able to move. :P Turn Pickaxe over with the lifter and smack it with the bar until he dies. Encourage Helix to assist me with this and avoid him if otherwise.
          Gehenna vs V for Vendetta vs Roadblock
          lol Roadblock
          Heat winner: I actually think I have a decent chance here, but I think Gehenna will cut me down if I meet it. Which is likely. :P
          Heat D
          Bandwagon 3 vs N³ vs Razer
          Whoever Nidhogg decides to go after will die. Neither other competitor can stack up to him I'm afraid.
          Likewise. They can't do much to Flick here. It'll be whomever Flick decides to go after.
          Heat winner: Out of a N³ vs. Flick of the Wrist heat final, I'll go with N³.
          Heat E
          Exotherm vs The Final Cut vs Mantis Mk 2
          Mantis confuses me. Unless Leo or someone else shows me exactly how it works, I deem it ineffective and I say it will go out, sorry. :P
          I.A.N. vs Wedginator 9.0 vs Minesweeper 4
          Hey, it's the Minesweeper with the stackable sides! Stack it. If he sneakily put spikes on the sides, however, I'm not sure how those scoops will fare. I can push my lifter into the ground too. :P Get under it, lift it, and pit it. I suggest I.A.N. helps me with this.
          Heat winner: The Final Cut is lookin' good, WARGH!
          Heat F
          ...Scrap Daddy??? LMAO.
          Poor Panic Attack is getting on in years I reckon.
          Heat winner: Loki looks good, but SHA2 and Wedga are real threats too.
          Heat G
          No, I'm not going to kill myself. :P Reason being, the shell shall be locked at 1500RPM. It'll still belt opponents across the arena and spin back up ferociously quick for another blow. Because I don't know Walkies' stats yet, I can't give proper tactics, so I'll just spin up and destroy anything that comes near.
          The Clones That Weren't There vs CrOoKeD eVo vs Eye of Ran II
          20kg against 236kJ? Jack should be smart enough to sit by sidelines and watch this unfold. :P Goodbye Mark.
          Heat winner: IJ of Ran t00 ;D
          Heat H
          It's not my match, so I'm not too concerned, but I still would like to say Maximum Genocide is overweight with all that weaponry and those motors/batteries. It to go out, or Tazbot if this unrealism goes unnoticed. :P
          Bigger Brother vs Reptirron the 2nd vs Extreme Gyration
          When Aaron made Gyrate, he didn't intend it to really WIN, per say. It was made to just to achieve a huge, huge kJ count and prove a point (correct me if I'm wrong, though, Aaron ). It was borderline in the weight limit as it is, and when Mark adds armour/shockproofing to it, he just makes it overweight, so Mark should be DQ'd or forced to change his stats. Again, not my match, but writers should really watch for these things.
          As for the match? EG to explode on contact with something instantly, and BB and Reptirron to advance.
          Heat winner: Holepunch 2.0 looks to be the only one to stand a chance here, lol
          • #35
            Re: crazy bots 2.0.
            Whoops that reminds me.
            Otherweights
            Heat A
            feathers
            Stiff Breeze vs Redemption vs Small System Shock
            lightweights
            Anti-Virus 3.0 vs Hit 'em Hard vs Sergeant Slaughter
            middleweights
            Hazard vs t-Minus vs Maxus
            Super-Heavyweights
            Puzzel vs Shovelhead vs UberForce 2.0
            Heat B
            Featherweights
            Starfighter(1#) vs Skink vs Micro Gore Evo
            Lightweights
            No Redemption vs Lightning LW vs Minilith
            Middleweights
            259 vs Terminus vs sub-zero
            Super Heavyweights
            UberForce 2.0 vs Inflammatory Slammer 2 vs Tax Cutter's Return
            Heat C
            Featherweights
            flow vs Storm Vortex vs Scoopy Doo
            Lightweights
            Fang vs Fuzzel vs Wedgehog
            Middleweights
            The Unnamed Feeling vs Gamma-Rex vs Striker
            Super-Heavyweights
            Tetris vs Drive vs Omega-Rex
            Rest to follow :P
            • #36
              Re: crazy bots 2.0.
              Originally posted by death robotics
              Ill put the rest in a bit :P
              In that case I'll wait a bit.
              • #37
                Re: crazy bots 2.0.
                Heat D
                Redemption vs NCC 1701 vs OverDrive
                Lightweights
                Fuzzel vs typhoon thunder vs Gamma Raptor
                Middleweights
                Nuzzel vs Heroin vs Hyper-Ventilate
                Super-Heavyweights
                Vladiator vs Demon Duck vs Ziggy
                That should do it
                • #38
                  Re: crazy bots 2.0.
                  Just need to formalise Murdertrain and Walkies stats and if people think they're ok then that will be them.
                  • #39
                    Re: crazy bots 2.0.
                    Heat I
                    Sideswipe vs Killertron vs Liar 2
                    All Bar One vs Frenzy vs Axeon 4.0
                    Heat J
                    7roubloon vs No Consequences vs Skull
                    Splinter vs Pussycat vs S3
                    Heat K
                    Wheely Big Cheese vs Obsidian vs Exertion II
                    Apples & Pears vs Darkwing 3 vs ia5
                    Heat L
                    behemoth vs Magnitude vs Symmetry
                    Fissure vs The Subjugator vs Firestorm
                    Heat M
                    Goldigger vs Murder Train vs The Alexandra Sisters: Retribution
                    Annihilation vs TAN vs M.O.E
                    Heat N
                    Matador vs GBOD vs Under Pressure
                    Spawn Again vs Super Gore Septua vs Thiwon
                    Heat O
                    Ge5orce vs Equinox vs Surgeon General
                    Still Hurting vs System Shock 5.1 vs Diotoir
                    Heat P
                    Back to Rock III vs PsycloniZer vs Voltronic
                    Nightmare vs Storm 2 vs Nemesis
                    Final predictions in for me
                    Oh yeah Jordan. You have to use Nemesis due to Liam chosing Diotor :wink:
                    • #40
                      Re: crazy bots 2.0.
                      Revised seedings include other tournies
                      1: Apocolypse 2
                      2: Iron-Awe 5
                      3: Anihalation
                      4: Sergeon general
                      5: Exotherm
                      6: Megaroll 2
                      7: Helix
                      8: OID
                      9: Mineweeper 4
                      10: Loki
                      11: Crooked Evo
                      12: Gabriel V
                      13: Jinx 1.2.
                      14: I.A.N.
                      15: Bandwagon 3
                      16: Alexandra Sisters
                      17: Skull
                      • #41
                        Re: crazy bots 2.0.
                        Sorry to be annoying, but Fissure and UberForce 2.0 both appear twice...
                        • #42
                          Re: crazy bots 2.0.
                          Originally posted by kodster
                          Heat A
                          Huh? You've seen Mantis before.
                          http://www.youtube.com/watch?v=I1jGE4YcYaY
                          • #43
                            Re: crazy bots 2.0.
                            Ahh. The previous pic had confused me because it looked as though it had crushing arms from all four angles. Now I see that it is not so.
                            Still, not sure it can get a good hold if at all on either of the spinners in its melee.
                            • #44
                              Re: crazy bots 2.0.
                              Oh fudge let me fix that
                              Uberforce 2.0 the accidental one will be replaced by Disector
                              The other Fissure will be replaced by Chompalot
                              • #45
                                Re: crazy bots 2.0.
                                Which heats would those be? It's not exactly obvious which ones were accidental.
