A New Start A New Show
    Re: A New Start A New Show
    Seeing as that last post is being a pain to edit I'll put my tactice in a new post.
    All Bar One vs IAN
    Run away until up to full spinning speed then aim to hit IAN square on the sides or the back. Try to stay in the middle(ish) of the arena and avoid that flipper on the front of IAN.
    If I happen to be stopped from spinning use the normal drive mode to run away and spin up again or ram him into hazards etc if he's too agressive and repeatedly stops me from spinning up.
    Cassius II vs Panic Attack
    Try to stack it and use the very large spike on the back of Cassius II to give Panic Attack a good poking if I can stack him.
      Predictions:
      Heat One:
      Equinox VS Absolution: Absolution has around 100kj of power less then my own 1-hit Wonder. However, it's still enough to smash up Equinox.
      All Bar One VS IAN: All Bar One's been a pretty successful design. It can ram, and it can spin. The fact that Jordan can do both and keep Jack on his toes will win the battle here.
      N3 VS Wedga Triton: Wedga looks like a good choice.
      Heat Two:
      Stinger VS Gravity: Gravity can OOTA Stinger.
      Cassius II VS Panic Attack: And Rex has a chance to get some revenge. And I think he will, as Cassius is low enough to get under Panic's skirts.
      Orrion VS Bodyhammer: The former Iron Awe 4 to beat Bodyhammer to a pulp, even if the Team Cold Fusion's machine's hammer is working.
        Equinox vs. Absolution
        Ram in backwards at full speed, it should KO itself.
        Equinox stats are in signature, as previously mentioned.
        Panic Attack vs. Cassius 2
        Cassius 2 was no good at getting under things in the 2 battles it had, and I have a 20kg weight advantage. Lift and pit.
          The first battles will be on the weekend. Tactics in by then, please
            Additional tactic:
            If I do go down the pit with Cassius II then attempt to catapult myself out with the massive spike
              i.a.n: all bar 1 eh? hmm i havnt faught a translational spinner befor, but having built one i know that they dont like being flipped while spinning, and my armor should hold, so just flip flip flip
                orrion: err....flip :P i dont think he has a shrimec? flip him over/around/oota or smash him with the axe
                • #23
                  N^3 will try to lift, clamp and pit Wedga, avoiding the flipper, and under no circumstances will I mess around trying to cause excess damage or crushing it without taking it to the pit; just grab it and drop it down the pit.
                  Bodyhammer will ram Orrion around using the power from the Bosches, and remind Mark this is the series 2 version. Avoid the flipper if I can.
                  Good luck everyone?
                  • #24
                    Tactics:
                    Gravity vs. Stinger
                    Remember how high Chaos 2 flipped this thing? :wink:
                    Wedga Triton vs. N³
                    This should be good. No time for hanging around though. Go straight in, get under that 10mm clearance and start launching. If I can keep this battle short and fast-paced I should be able to dominate it. Once the first flip is in, I can take control of the match and try and throw it over the fence as soon as possible. Big and powerful flips, please. I hate crushers.
                    Good luck everyone.
