crazy steam train vapour
  • crazy steam train vapour
    hi guys im deciding to enter a vapourbot (if it gets done but it wont be now :P ) which mixes my 2 intrests
    steam trains (does that make me sad )
    and robotics
    ive already made one (merry hampton but its a tornado style)
    but im wondering is it possible to make a heavyweight out of the pic in this link
    http://www.germansteam.co.uk/FastestLoc ... oco-09.jpg
    hope you can give me advice on trying this wild idea
    Re: crazy steam train vapour
    Perfectly do-able.
    Just make the robot look like a stram train
      i think it might be a clusterbot due to the tender :P
        Something with a cow catcher might be good as it can be turned into a lifter/ flipper whilst still looking like a train.
        Also, this thing looks like it will be very long and not particularly wide so it will probably not turn as well as something shorter/wider than it and could be very easy to turn over sideways.
          im thinking for the turning that the wheels will twist
          and the cow catcher idea will be a good idea :P
            I'd be more inclined to opt for a 0-6-0 arrangement with cowcatcher as it's shorter so can steer more effectively and gives you a managable number of wheels.
              thats the kind of arrangement im going for now
              are you a steam enthusiast? just curious as i didnt think anyone on this forum would be intrested in trains
                Yep, I'm a fellow rail enthusiast
                  yay
                  on a serious note the smoke deflectors will be pneumatically powerd as self righters :P
                    I'm not an extremely knowledgable rail enthusiast but I do love trains. Something about them is just really appealing. I don't know if it's the way they look, the way they snake about the tracks or whatever but they're awesome. Makes me want to get my model railway set back up and running.
                      show us a vid of it jamie when you set it back up
                      is still trying to figure out how to not go over the weight limit but the wheel arrangement has changed from
                      4-6-2 to 0-6-0
                        If you need to lose weight in the machine try only making the top bit a facade and have the drive and weapons base armoured, still looks like a train but it will be less easy to kill.
                        * Wonders whether CO2 piston exhaust will look like steam *
                          i think im gonna need all the help i can get but jordan that sounds like a good idea
                          also dimension problems
                          by the way jordan if you want this can be a shared bot between you and me
                            How about instead of using an 0-6-0 arrangement, how about you use a 2-2-2 arrangement? That way, you would save weight, seeing as you wouldn't need to use a mock-Stephenson-Link mechanism on the wheels.
                            Yes, I know what that is, so give me my sadness badge!!!
                              Thing is with a 2-2-2 though, would the look of the steam train not be lost a bit? With a 0-6-0 it's got the distinctive look of a steam train but I've not seen many (if any) 2-2-2 setups so I don't know if people would associate that with trains. Just my thoughts. Either way, it should hopefully look like a cool robot
