Re: ROBOBASH SERIES 2!!!!
Justine: Right Liam, Fissure is your opponent for this battle.
Liam: Very good robot, so it'll probably be a difficult fight. Apocalypse will use its agility and zero-ground clearence on the front to get under the side or back of Fissure, (any part will do) and flip it out ASAP. If that doesn't work, Apocalypse will dump Fissure down the pit hopefully.
Justine: You confident?
Liam: Not VERY, but I'm thinking I can take him on.
Justine: All right, good luck.
Liam: Ta.
Justine: And we now go to Andy, and Fissure is up against Apocalypse!
AJ: Right... Apocalypse is pretty much Ziggy as a heavyweight, so it's going to be pretty difficult...
Justine: Mkay, tactics?
AJ: Avoid the front like mad, and lift Apocalypse from the side to either flip it into the wall and pin it there, or dump it into the pit.
AJ: Thanks.
Sam: Hey, four bots have made it alive, but now it's crunch time! Get ready for ROUND 2!!!!
(BATTLE 3!!!)
Ladies and Gentlemen, please welcome...
APOCALYPSE!!!
FISSURE!!!
Roboteers, Stand by...
Let's have a look at the teams; Liam Eliot is at the controls of Apocalypse... and there's Andy Jackson in the other control booth, controlling Fissure. Presenting your house robots for this battle... The big daddies, KING ARTHUR AND MR. PSYCHO!
3... 2... 1... ACTIVATE!!!
Refbot's giving the green light for go. Apocalypse immediately goes searching for Fissure, but Fissure finds Apocalypse first, and tries to get underneath! However, Apocalypse is quick at 15mph, and gets away! Fissure is slightly slower at 12mph, but not to be underestimated of course. Now, here comes Apocalypse, getting underneath Fissure and flipping it-- OH!!! Apocalypse flips Fissure 10 feet in the air and it lands back on its wheels with a stomach-wrenching thud! Apocalypse is looking very good here, and now Fissure fights back! Fissure gets under the skirts of Apocalypse and lifts it up! Now it SLAMS Apocalypse into the wall, with massive force! Apocalypse does not like it one bit, and backs into the pit button! The pit goes down, and Apocalypse gets under Fissure! Now it SLAMS the machine from Shrewsbury RIGHT INTO KING ARTHUR'S FLYWHEEL!!!
CRASH!!!
The armour has a scratch in it, and Fissure gets tossed right onto its back! However, the lifting arm rights Fissure back onto its wheels! Now, Fissure slams into Apocalypse! It gets underneath, and Apocalypse is in peril here! Fissure lifts up Apocalypse, and drags it towards the pit of doom! Apocalypse needs to get away and fast, but it is very near the pit-- OH! Apocalypse gets away by the skin of its teeth, an outstanding defense there by Liam Eliot! Apocalypse and Fissure are still duking it out, but Apocalypse has the advantage as is getting underneath Fissure and SLAMMING it into Mr. Psycho's CPZ! The hammer comes down from Mr. Psycho!
WHAM!!!
The armour takes a beating, but surprisingly, it's withstanding the blows well here. Fissure gets away from the CPZ, and rams Apocalypse and gets underneath the skirts! Now, it lifts Apocalypse up in the air, and right into King Arthur's arse goes Apocalypse!
CRASH!!!
OH!!! King Arthur just tosses the Welsh machine into the air and one skirt is totally bent! Now, Apocalypse is okay, and it gets away, attacking Fissure! Fissure gets flipped-- OH!!! Lord have mercy, that robot is flying, and almost out of the arena! Fissure is okay, it self-rights and retaliates! Now, it gets underneath the damaged skirt of Apocalypse, and lifting it up! Apocalypse is in peril here again, and tries frantically to get away! Fissure is just determined to end this fight once and for all, as it drags Apocalypse ever closer to that pit of oblivion! Apocalypse is on the brink of defeat! Fissure is now about to end this battle! Will Apocalypse go down... YES! It's over!
CEASE!
The Apocalypse didn't happen unfortunately.
Fissure goes through to the Heat C Final!
Liam: Ta.
AJ: Thanks.
(BATTLE 3!!!)
APOCALYPSE!!!
FISSURE!!!
CRASH!!!
WHAM!!!
CRASH!!!
CEASE!
Well, it's going to be a quite difficult match, because it's more fast and manueverable than 101.
Nice piece off of there, Andy, but you'll end up paying for it later. Anyway, Psyclonizer and SOTAR collide again at full speed!
