My first fan fic
  • My first fan fic
    Hey
    I've decided to make my first fan fic tornie after Jack (team_orr) said how good it is.
    i will need 6 people to enter 2 vaperbot each 100kg for rollers, 110kg for shufflers and tracks and 200kg for walkers.
    The areana is the robot wars extreme 2 areana and the house robots are the original house robots sir killalot, dead metal, matilda, shunt and sgt. Bash!
    Get entering now!
    Regards
    Harry
    Re: My first fan fic
    Eye Of Ran II and No Consequences please
    Stats can be found on my board at ZED: http://strickenone.proboards.com/index.cgi?board=chevhw
      o.i.d and CrOoKeD EvO plz both on zed
        Welcome to FanFic, Harry!
        I'll enter Wedga Triton and Fissure please.
          Sure, Harry!
          Wedginator 9.0 and Jinx, please. Stats can be found on the Team Zlayerz link in my signature.
            I feel I should try entering one of these...
            Gross Surgical Malpractice and Vertical Limit both posted at the end of http://www.fightingrobots.co.uk/foru...2107&start=720
            Should be as destructive as spinners get, really...
              Ok we only need 1 more person to enter their 2 robots!
              This may not be the best fan fic ever but it may be quite good for my first one...
              regards
              Harry
                Don't worry. Everybody has to start somewhere.
                  here's your final entry! looking forward to this
                  Sheer Heart Attack 2 and Flick of the Wrist http://strickenone.proboards.com/index. ... =thvapours
                    Ok no more entries!
                    Here is the draw:
                    Eye of ran 2 vs Gross surgical malpractise
                    Wedginator 9.0 vs CrOoKeD EvO
                    Vertical limit vs No Consequences
                    Fissare vs O.I.D
                    Wedga Triton vs Flick Of The Rist
                    Jinx vs Sheer Hart Attack 2
                    We'll probally get the 1st Battle done by about Wednesday at the max
                    Regards
                    Harry
                      Fissure vs. OID
                      Hopefully my sloped sides will stop OID causing too much damage. I will use the lifting arm to get under the side ground clearance and lift OID up, preferably onto its side. Then either stack it against the arena wall or put it down the pit.
                      Wedga Triton vs. Flick of the Wrist
                      I€™ll attach the side skirts for this battle. This should stop Flick of the Wrist getting under me from side-on. Ideally it will just ride up the side wedges and onto the top of my flipper. Meanwhile, I€™ll target its own sides and the 10mm clearance. Get under with the front wedge, push it towards the walls and try and throw it out of the arena.
                      Good luck Jack and Marti. I hope you enjoy this, Harry!
                        INCREDIBLY VAGUE TACTICS FOR BOTH NO CONSEQUENCES AND EYE OF RAN II
                        Spin up, and then do...something...it goes into uncharted waters from there really, considering I'm up against the most overkill spinning objects since Dave and Derek Rose had a mad idea.
                          Eye of Ran II vs Gross Surgical Malpractice
                          GSM through unless it mysteriously breaks down.
                          CrOoKeD eVo, ThOuGh ImPrOvEd, WiLl LoSe ThE mAtCh.
                          Vertical Limit vs No Consequences
                          See prediction for Eye of Ran II vs Gross Surgical Malpractice.
                          Fissure vs O.I.D
                          Fissure to overpower the newbie.
                          Wedga Triton vs Flick Of The Wrist
                          Wedga to OOTA FOTW.
                          Jinx vs Sheer Heart Attack 2
                          The new girl to immobilize one of SHA2's tracks.
                            Gross Surgical Malpractice vs Eye of Ran II: Simple - box rush him with the weapon motor at full throttle, as my blade spins up a lot faster than his does (5 times as much power in the engine). Once that's done, just keep hitting him, hopefully getting past the blade and trashing his more exposed parts.
                            Vertical Limit vs No Consequences: He's only powered by a couple of Magmotors, so i've got nearly 14 times as much power in terms of spinning up - so just rev it up, keeping the disc pointed at him, and slam him as soon as I get some speed into it. Hopefully he'll fly right out of the arena and/or be disabled, if not keep trying
                              So Here it is round 1!
                              Harry: Hello and welcome to MFFF i'm your host Harry Orr! Tonight you will see mayhem,
                              tonight you will see destruction...and tonight you will see robots get there royal metal ass kicked!
                              Tonight the 2 robots fighting are Eye Of Ran 2 entered by Joey!
                              And GSM entered by Nick!
                              So now lets get on with the FIGHTING!
                              3...2...1...ACTIVATE! and straight away EOR2 zooms down the arena with its blade spinning at full
                              pelt and....BAM! EOR2 smashes into GSM's armor and the armor gets SHREDED! armor flying everywhere!
                              But a bad mistake by Joey! he has driven backwards to try and get some more armor off GSM but accidently drove to far backwards! now he has driven in to a wall and got stuck on it! Now GSM's blade has got up to speed and VROOOOOOM! BANG!
                              Armor goes everywhere! but by doing that EOR2 has driven of the wall and got away from the danger. Both disks now spinning at full speed at each other and...BOOOOOOOOOOOM! both robots go flying out of the arena! CEASE! Now, who flew out first?
                              it has gone to a judges decision and the winner is................................EYE OF RAN 2!!!!!!!!
                              So the winner is Joey with Eye Of Ran 2! Well done Joey!
                              Bad luck Nick but you still have a chance of winning!
                              Do you want to see more distruction? then tune in next time on MFFF goodnight!
                              Regards
                              Harry
