The Fighting Vapourbots Association League 2 - A fresh start
    Re: The Fighting Vapourbots Association League 2 - A fresh start
    At the moment it looks like me, Kody, Andy, Steve, Jack and Martijn wish to write.
    Here's the lineup - writers, feel free to bagsy any fights you wish to write (maximum of two per person please):
    Gabriel V vs. B.I.A.C.S.-I.S
    Dervish: The 1337 Generation vs. Mornington Crescent
    E Clawdius Unum vs. Gehenna - Joey
    Under Pressure vs. Jinx
    Shovearound 3 vs. Back To Rock III
    CroOkED eVo vs. Assegai
    N³ vs. Axeon 4.0
    O.I.D. vs. G.B.O.D.
    Skullcrusher vs. Lethal Weapon
    Black Panther vs. Seung Mina VI
    The Kill Point vs. Monsoon Season
    Holepunch 2.0 vs. Darkestar - Joey
    Please be fair and impartial in your writing, and don't do your own fights
    EDIT: Steve has just informed me we forgot about arenas.
    So...uh...well...we'll get back to you on that tomorrow-ish, until then don't write the fights :P
      I'd quite like Black Panther vs. Seung Mina VI and O.I.D. vs. G.B.O.D. if everyone is fine with that.
        Skullcrusher vs. Lethal Weapon and The Kill Point vs. Monsoon Season please
          Ouch, helluva draw. Tictacs up later once you figure out what arena you'll actually be using. :wink:
          I'm quite intrigued by BIACS-is VS Gabriel and Jinx VS Under Pressure myself. Mind if I have a bash at writing those, lads?
            Sounds good!
            Whiplash and Theseus for me please.
            Theseus
            Weight: 100kg
            Shape: Atomic (Series 7 Version)
            Colour: Unpainted, but the weapon is blue
            Dimensions: 100 X 79 X 36
            Power: 2 X LEM-130's @ 36v powered by several NiCad's
            Wheels: 4 X Aluminium Tyres with Urethane rubber for more grip
            Armour: 4mm Hardox Moncoque
            GC: 5mm Everywhere Except for the front, which is 0mm
            Speed: 19mph
            Weapon: Mainly relies on pushing power, but there IS an extremely powerful Atomic-like flipper, also made completely of 4mm Hardox, powered by 2 X 2kg CO2 Tanks. It can flip 1000kg with ease and it can also self-right the robot as well.
            Strengths: Powerful Flipper, Great Pusher, Always Reliable
            Weaknesses: Limited to 38 flips
            Notes: Possibly the first time I built a NON-SPINNER?
            Whiplash
            Weight: 100kg
            Body Shape: Pentagonal Pyramid with skirts
            Dimensions: 100 X 85 X 38
            Power: 2 X LEM-130's at 36v powered by 4 X Nicads
            Tyres: 4 X Asmaprene Urethane Rubber Tyres
            Speed: 15 mph
            Armour: 4mm Hardox
            Ground Clearence: 0mm with skirts, and 5mm without skirts
            Weapon 1: SHEER PUSHING POWER
            Weapon 2: At the front there is a 7kg Terrorhurtz-Like BattleAxe (made out of hardox, even the handle) powered by 2 X 2kg CO2 Tanks, 200 PSI, diamond tipped, has over 1500 joules of force when it comes down. It can also attack from both ends. Heavily Shock-Proofed, as well.
            Srimech: The axe can easily self-right it (even when it's on its side), and it can also self-right even after the axe has fired, ala Killerhurtz.
            Strengths: PSYCHOTIC AXE AND PUSHING POWER
            Weaknesses: NONE AT ALL! (Except for Limited Co2)
              Originally posted by samuel3764
              Sounds good!
              Theseus
              Weight: 100kg
              Speed: 19mph
              Whiplash
              Weight: 100kg
              Speed: 15 mph
              Armour: 4mm Hardox
              Never mind.
              Anyway, predictions:
              Gabriel V vs. B.I.A.C.S.-I.S - Probably Gabriel.
              Dervish: The 1337 Generation vs. Mornington Crescent - MC will win here, probably.
              E Clawdius Unum vs. Gehenna - Razer showed great power in its match against Firestorm, so I think Clawdius ftw.
              Under Pressure vs. Jinx - Under Pressure will probably pull a TAN and pit Jinx.
              Shovearound 3 vs. Back To Rock 3 - Haven't a clue.
              CroOkED eVo vs. Assegai - Crooked Evo FTW.
              N³ vs. Axeon 4.0 - A repeat of Razer VS Terrorhurtz. N³ FTW.
              O.I.D. vs. G.B.O.D. - GBOD ftw.
              Skullcrusher vs. Lethal Weapon - Lethal Weapon ftw.
              Black Panther vs. Seung Mina VI - Flipper vs axe... very one sided here, but I'll go for the Flippability factor of Seung Mina.
              The Kill Point vs. Monsoon Season - Monsoon Season will win here.
              Holepunch 2.0 vs. Darkestar - Holepunch ftw.
              i'd like to write N³ VS Axeon and Dervish vs Mornington Crescent, if its ok with u guys.
              Good luck to all.
                I'd like to write the 2 remaining battles, Shovearound 3 vs. Back To Rock III and CroOkED eVo vs. Assegai, if everyone is fine with that
                • #23
                  Joey, I'm using my newest versions of TKP and Skullcrusher. If the ones on the old FVAL are not good, I'll take the old versions then
                  As for tactics, I'll try and push Monsoon Season into the pit and hit Lethal Weapon with the spinning ring until it breaks
                  • #24
                    Sam, I'll have to check but I think you need to have entered the tourney to be able to write battles, sorry
                    • #25
                      Just realised the old FVAL 2 thread has been destroyed, so I'll give you the new stats if you don't have them
                      • #26
                        Originally posted by majinb
                        I'd like to write the 2 remaining battles, Shovearound 3 vs. BACK TO ROCK III and CroOkED eVo vs. Assegai, if everyone is fine with that
                        No writing your own fights, Marti. :wink:
                        • #27
                          Hi all.
                          I just returned from Germany where I couldn't log in, but Kody has already confirmed I will be attending. I would also like to write one of the battles. Only thing is I just have time to wash my clothes and do some forum reading and in 2 days time I will be on a plane again to Thailand for a week of work. I would like to start the writing after that so I can focus on the task at hand if that is all right.
                          • #28
                            Well, while I missed out, it's time for predictions!!!
                            Gabriel V to finally put an end to Bull in a China Shop.
                            I actually see Mornington Crescent willing this battle, since its twin rings should survive Dervish
                            The revised SOR to kill the freshening of Clawdius Decimus Murderous.
                            Under Pressure to crush the new girl.
                            Shovearound 3 doesn't have stats yet. The champ to go through.
                            Assegai to kill the revision of CrOoKeD.
                            N3 vs. Axeon 4.0
                            N3 to crush the new bot.
                            O.I.D. vs. G.B.O.D.
                            OID to somehow survive a judges' decision.
                            Skullcrusher Evo vs. Lethal Weapon
                            I actually see the new design eliminating Lethal Weapon.
                            SMVI to remove the Panther from power.
                            The Kill Point II vs. Monsoon Season
                            Monsoon to pit The Kill Point II.
                            Darkestar to somehow pit Holepunch.
                            • #29
                              I was wondering if someone'd notice, you passed my little test real well mr. McGregor
                              ok, I can write CroOkED eVo vs. Assegai but if you guys want me to write 2 matches we will have to do some swapping around, or I just write 1 match and a currently jobless writer takes Shovearound 3 vs Back To Rock III
                              • #30
                                your more than welcome to take one of my fights if you want to write 2 mate im not as good a writer as you guys
